Hi, everyone. I have chose to output reaction rates in VTK file in MFIX 21.2. However, no results about reaction rates are found. Is there something I ignore?
test-press-v1-8MPa.zip (26.4 MB)
I am not able to open your zip file. Please verify and send again.
The file uploaded was actually a rar file, I was able to extract it with unrar. Here’s the contents re-packaged as a zip.
test-press-v1-8MPa.zip (31.2 MB)
While running this job I saw a message get printed to the controlling terminal:
mfix - WARNING - Could not find BC
this message is not in any of the logs, and is not printed in the internal GUI console - this is a potential issue (separate from the rrate issue that Yajing reported).
I can confirm the reported behavior. VTK output #2 is configured as Particle data and RX1 rate is checked - this sets the keyword vtk_part_rrate(2,1) = .True.
But looking at the output file BACKGROUND_IC_1_0000.vtp
strings BACKGROUND_IC_1_0000.vtp |grep Name
<DataArray type="Float32" Name="coordinates" NumberOfComponents="3" format="appended" offset=" 0 " />
<DataArray type="Float32" Name="Diameter" format="appended" offset=" 3172" />
<DataArray type="Float32" Name="Velocity" NumberOfComponents="3" format="appended" offset=" 4232" />
<DataArray type="Float32" Name="Temperature" format="appended" offset=" 7404" />
<DataArray type="Float32" Name="X_s(1)" format="appended" offset=" 8464" />
the reaction rate is not there.
As an experiment I increased nrr - this shouldn’t matter, and it didn’t.
I also tried saving the reaction rate as cell data, as part of VTK output region #1 - this worked. This sets vtk_des_rrate(1,1) = .True. and RRates_RX appears in the VTU file:
strings BACKGROUND_IC_0000.vtu |grep Name
<DataArray type="Float32" Name="coordinates" NumberOfComponents="3" format="appended" offset=" 0" />
<DataArray type="Int32" Name="connectivity" format="appended" offset=" 976" />
<DataArray type="Int32" Name="offsets" format="appended" offset=" 2004" />
<DataArray type="Int32" Name="types" format="appended" offset=" 2136" />
<DataArray type="Float32" Name="EP_G" format="appended" offset=" 2268" />
<DataArray type="Float32" Name="P_G" format="appended" offset=" 2400" />
<DataArray type="Float32" Name="Gas_Velocity" NumberOfComponents="3" format="appended" offset=" 2532" />
<DataArray type="Float32" Name="Gas_temperature" format="appended" offset=" 2920" />
<DataArray type="Float32" Name="H2O_Gas_mass_fractions_1" format="appended" offset=" 3052" />
<DataArray type="Float32" Name="CH4_Gas_mass_fractions_2" format="appended" offset=" 3184" />
<DataArray type="Float32" Name="RRates_RX1" format="appended" offset=" 3316" />
So it looks like VTK rrates works for cell data but not particle data.
Thanks Charles for converting the zip file.
It is a bug and will be fixed in the next release. In the meantime, if you feel comfortable editing the source code, go to line 469 of model/check_data/check_output_control.f and replace SAVE_DES_RRATES by SAVE_PART_RRATES. The screenshot below shows line 469 (with bug, commented out) and the correct version on line 470
Thanks very much for your help!
Thanks very much for your valuable instruction!
Thanks very much! It really helps me.
