Hello, everyone. I met two problems about particles in DEM simulations, such as 3.6. Three Dimensional DEM Hopper — MFiX 21.3 documentation. My panel settings are basically consistent with those in toturial 3.6.
(1) The diameters of the lower cylinder and the particles are respectively 15mm and 3mm. Namely, d_cylinder/d_particle=5. However, as can be seen from the following figure, the diameter of lower cylinder only nearly 3 times larger than that of particles in the VTK, instead of 5 times. I am confused about this.
My case file is Hopper_3D_DEM.mfx (17.1 KB)
(2) In some cases, individual particles are unexpectedly outside the domain during the iteration (see the attached figure below). What cause this nonphysical phenomenon? How to overcome this problem?
