I have followed the procedure of heat transfer from rotating drum but I am getting error to output the heat flux for this geometry.
Only rear wall is heated to a temperature. I want to output the heat flux from this wall.
Please help me to rectify the error.
I have attached the file below:
You have stl files but did not assign any BC to them so the cartesian grid cut cell is turned off (see output message). The side effect is DEBUG_CG is not allocated. You can allocate is manually:
ALLOCATE(DES_QwFlux_Avg(DIMENSION_3, DIMENSION_M))
if(.not.allocated(DEBUG_CG)) allocate(DEBUG_CG(DIMENSION_3,15))
! Zero arrays
DES_QwFlux_Avg(:,:)=ZERO
QW_SAMPLE_TIME = ZERO
DEBUG_CG = ZERO
