Hi, everyone. I am puzzled what is the physical unit of VTK_P_G?
What’s more, in BC, the gas pressure of outlet is 101325 Pa by default. In paraview, the average pressure of the surface 0.25 mm below the outlet is this:
Does this mean that the output pressure is gauge pressure?
If you define a non-zero value of P_ref with incompressible flow, you will use gauge pressure.
Thanks a lot!
