Hello all,
I am attempting to set up a CFD-DEM (CGP) to simulate biomass pyrolysis in a fluidized bed reactor with a relatively large cross-sectional area. Consequently, I am inputting heat via a constant flux across the reactor wall. The problem however is that the temperature gradient value (ratio of experimental heat flux to the product of wall area and gas thermal conductivity) causes the simulation to fail. See the error message below. Values lower than 1e5 K/m typically runs well but heat input is not enough to maintain the desired reactor temperature.
I was wondering if anyone has dealt with a similar setup and has some tips to getting the heat flux to the desired level without crashing the simulation.
ERROR check_data_30.f:299
Unphysical field variables detected on one or more processes.
Note: The following floating-point exceptions are signalling: IEEE_UNDERFLOW_FLAG IEEE_DENORMAL
ERROR STOP 1
ERROR STOP 1
Note: The following floating-point exceptions are signalling: IEEE_OVERFLOW_FLAG IEEE_UNDERFLOW_FLAG IEEE_DENORMAL
ERROR STOP 1
ERROR STOP 1
ERROR STOP 1
