MP-PIC | Solid-gas simulation | Velocity blowing up but not pressure - which is weird!
So I am running a MP-PIC simulation for the NETL CFB Riser problem.
I have mentioned the initial conditions in the figures.
After a successful run on HPC - when I visualize the results they are weird.
The velocity seems fine until 30 s, and then suddenly it blows up.
However, the pressure does not blow up - which is weird because if the velocity blows up then due to the navier stokes and other transport equations - the pressure should also blow up. I have added photos for both these issues.
The maximum time-step is 1 ms, the minimum time-step is 10^{-12}. The mesh is 50x500x50 [cell size is around 1 mm] - so its fine meshing to maintain the cylindrical shape of the geometry.
Initial conditions and set-up
Velocity blow up issue
Pressure not blowing up
MFIX files:
geometry_0001.stl (5.6 MB)
own_STL_file.mfx (18.3 KB)
