I’m working on DEM model and I have this issue when I try to visualize the “points” data as you can see in the attached photo. What happens is the color bar updates but the geometry doesn’t and it only shows the “cells/nodes” data.
Kindly help me with this problem.
Thanks,
– Mariam
You are displaying both cell and points (particles) data, each represents a different variable and uses its own color range. Currently, we can only display one color bar and here it references the points data. Changing the points data variable, range or color scheme won’t affect the cell data. If you hide the cell data (click on the icon to the left of “Cells/Nodes” text), you will see the points data better (particles are fairly small).
Ok. Now I get it. Thanks a lot
