I am using MFiX Batch solver (versions 19.3.1 / 2016.1 / 2013.2) with cylindrical coordinates for modelling vertical transport. I am using Ubuntu 18.04.5 with GNU 7.5.0.
When I try to visualize the results with the .RES reader of ParaView (versions 5.8.1 / 5.4.1), the wall cells are not seen. As you can see in the attached screenshots: whereas I have 8 cells in the radial direction only 7 are seen. Also, the diameter of the pipe as is displayed is only 0.035 m as against 0.04 m used.
I tried VisIt (version 3.4.1) subsequently and the wall cells could be seen (screenshot attached).
Is this an error in the ParaView’s .RES reader or am I missing something?
Thank you.
Prabu
