Does anyone know what does this warning mean? Thanks a lot!!
When you set a value for RO_g0, the gas phase is incompressible, and you do not need the molecular weight MW_AVG. If you do not set RO_g0, you will use the ideal gas law which need the molecular weight. This is just a warning notifying you that even though MW_AVG is defined, it is not needed and it won’t be used.
