What's the unit of enthalpy?
Hey guys,
What is the unit of enthalpy in TFM please? I saw the documentation said J/mmol. The temperature in my simulation blew up using this unit. I could have the wrong enthalpy or I could have the wrong unit. Should I use J/mmol in my TFM model? Thank you!
Jack
Enthalpy should be in Joule, where in the documentation does it say J/mmol?
However the thermo database uses the ratio H/R where R is in cal/(mol.K)
https://mfix.netl.doe.gov/doc/mfix/21.3/html/reference/faq.html#what-system-of-units-does-mfix-use
https://mfix.netl.doe.gov/doc/mfix/21.3/html/reference/thermochemical_properties.html?highlight=enthalpy
Thank you Jeff! Sorry I should have said heat of reaction instead of the enthalpy. In the user manual it says
4.13.1.11. Specify Heat of Reaction
Check this checkbox to optionally specify the user-defined heat of reaction for the currently selected reaction (Joules/kmol).
Is this J/kmol the correct unit? If it is, I am getting unphysical temperature for my reaction based on the enthalpy change provided by this paper. https://pubs.acs.org/doi/pdf/10.1021/jp205499e So i’m just trying to figure out if I understood the MFiX unit incorrectly or the paper incorrectly.
Thanks,
Jack
Yes, J/kmol is the correct unit for heat of reaction
