Hi everyone,
I’m using MFiX 25.1 and building geometry in Geometry → Procedural → bend. I want to rotate the bend, but I cannot figure out what point the Transform filter rotates about (i.e., the rotation pivot/center).
In Geometry → Filters → transform, I can set Rotation (X,Y,Z) and Translation (X,Y,Z), but there is no option for a pivot point. When I change the rotation (e.g., Rotation Z = 90°), the bend appears to rotate around some point that is not obvious to me, and I can’t reliably keep a specific port/endpoint fixed while rotating.
Questions:
For a Procedural bend, what is the default rotation pivot for the transform filter?
The bend’s local origin?
Something else depending on the filter chain order?
Is there a way in the GUI to set a custom rotation center/pivot for the transform filter (e.g., rotate about a port center)?
If the GUI doesn’t support a pivot directly, what is the recommended workflow to rotate about an arbitrary point (e.g., using multiple transforms / translate-rotate-translate)?
Caption / explanation:
“As shown in the figure, the only parameter I changed is the rotation angle about the Z axis (Rotation Z). All other parameters (translation and other rotation components) remain unchanged.”
Thanks in advance for your help, and Merry Christmas
