Hi Dear All,
When I tried to run MFIX-TFM with cut-cell technology, the DMP programm (mpirun -np 4) often stopped with the belowing error. I was sure that I did not kill them.
Thank you so much.
Regards,
Leina
Hi Dear All,
Regards,
Leina
Check any of the .LOG files to see if there are any useful information. If you are running in a queue, also check the queue output files. You can also build with debug flags and run again, this may give you a better clue as to what is wrong.
