Frontend testing standards and style guidelines
There are two types of test suites encountered while developing frontend code at GitLab. We use Jest for JavaScript unit and integration testing, and RSpec feature tests with Capybara for e2e (end-to-end) integration testing.
Unit and feature tests need to be written for all new features. Most of the time, you should use RSpec for your feature tests. For more information on how to get started with feature tests, see get started with feature tests
Regression tests should be written for bug fixes to prevent them from recurring in the future.
See the Testing Standards and Style Guidelines page for more information on general testing practices at GitLab.
Vue.js testing
If you are looking for a guide on Vue component testing, you can jump right away to this section.
Information on testing Vue 3 is contained in this page.
Jest
We use Jest to write frontend unit and integration tests.
Jest tests can be found in /spec/frontend
and /ee/spec/frontend
in EE.
jsdom
Jest uses jsdom
instead of a browser for running tests.
Known issues include:
See also the issue for support running Jest tests in browsers.
Debugging Jest tests
Running yarn jest-debug
runs Jest in debug mode, allowing you to debug/inspect as described in the Jest docs.
Timeout error
The default timeout for Jest is set in
/jest.config.base.js
If your test exceeds that time, it fails.
If you cannot improve the performance of the tests, you can increase the timeout
for the whole suite using jest.setTimeout
jest.setTimeout(500);
describe('Component', () => {
it('does something amazing', () => {
or for a specific test by providing a third argument to it
}, 500)
Remember that the performance of each test depends on the environment.
Test-specific stylesheets
To help facilitate RSpec integration tests we have two test-specific stylesheets. These can be used to do things like disable animations to improve test speed, or to make elements visible when they need to be targeted by Capybara click events:
app/assets/stylesheets/disable_animations.scss
app/assets/stylesheets/test_environment.scss
Because the test environment should match the production environment as much as possible, use these minimally and only add to them when necessary.
What and how to test
Before jumping into more gritty details about Jest-specific workflows like mocks and spies, we should briefly cover what to test with Jest.
Don't test the library
Libraries are an integral part of any JavaScript developer's life. The general advice would be to not test library internals, but expect that the library knows what it's supposed to do and has test coverage on its own. A general example could be something like this
import { convertToFahrenheit } from 'temperatureLibrary'
function getFahrenheit(celsius) {
return convertToFahrenheit(celsius)
It does not make sense to test our getFahrenheit
function because underneath it does nothing else but invoking the library function, and we can expect that one is working as intended.
Let's take a short look into Vue land. Vue is a critical part of the GitLab JavaScript codebase. When writing specs for Vue components, a common gotcha is to actually end up testing Vue provided functionality, because it appears to be the easiest thing to test. Here's an example taken from our codebase.
// Component script
computed: {
hasMetricTypes() {
return this.metricTypes.length;
<!-- Component template -->
<template>
<gl-dropdown v-if="hasMetricTypes">
<!-- Dropdown content -->
</gl-dropdown>
</template>
Testing the hasMetricTypes
computed prop would seem like a given here. But to test if the computed property is returning the length of metricTypes
, is testing the Vue library itself. There is no value in this, besides it adding to the test suite. It's better to test a component in the way the user interacts with it: checking the rendered template.
// Bad
describe('computed', () => {
describe('hasMetricTypes', () => {
it('returns true if metricTypes exist', () => {
factory({ metricTypes });
expect(wrapper.vm.hasMetricTypes).toBe(2);
it('returns true if no metricTypes exist', () => {
factory();
expect(wrapper.vm.hasMetricTypes).toBe(0);
// Good
it('displays a dropdown if metricTypes exist', () => {
expect(wrapper.findComponent(GlDropdown).exists()).toBe(true);
it('does not display a dropdown if no metricTypes exist', () => {
factory();
expect(wrapper.findComponent(GlDropdown).exists()).toBe(false);
Keep an eye out for these kinds of tests, as they just make updating logic more fragile and tedious than it needs to be. This is also true for other libraries. A suggestion here is: if you are checking a wrapper.vm
property, you should probably stop and rethink the test to check the rendered template instead.
Some more examples can be found in the Frontend unit tests section
Don't test your mock
Another common gotcha is that the specs end up verifying the mock is working. If you are using mocks, the mock should support the test, but not be the target of the test.
const spy = jest.spyOn(idGenerator, 'create')
spy.mockImplementation = () = '1234'
// Bad
expect(idGenerator.create()).toBe('1234')
// Good: actually focusing on the logic of your component and just leverage the controllable mocks output
expect(wrapper.find('div').html()).toBe('<div id="1234">...</div>')
Don't use imported values in assertions
Prefer literal values in assertions rather than importing constants. This makes tests easier to read, and resilient to changes. This is discussed further in internationalization recommendations.
// Bad: MY_CONSTANT could accidentally be set to undefined, have a typo etc. and test would still pass
import { MY_CONSTANT } from '../constants';
it('returns the correct value', () => {
expect(ding()).toBe(MY_CONSTANT);
// Good: explicit value is asserted
expect(ding()).toBe('expected literal value');
Follow the user
The line between unit and integration tests can be quite blurry in a component heavy world. The most important guideline to give is the following:
- Write clean unit tests if there is actual value in testing a complex piece of logic in isolation to prevent it from breaking in the future
- Otherwise, try to write your specs as close to the user's flow as possible
For example, it's better to use the generated markup to trigger a button click and validate the markup changed accordingly than to call a method manually and verify data structures or computed properties. There's always the chance of accidentally breaking the user flow, while the tests pass and provide a false sense of security.
Common practices
These some general common practices included as part of our test suite. Should you stumble over something not following this guide, ideally fix it right away.
How to query DOM elements
When it comes to querying DOM elements in your tests, it is best to uniquely and semantically target the element.
Preferentially, this is done by targeting what the user actually sees using DOM Testing Library.
When selecting by text it is best to use the byRole
query
as it helps enforce accessibility best practices. findByRole
and the other DOM Testing Library queries are available when using shallowMountExtended
or mountExtended
When writing Vue component unit tests, it can be wise to query children by component, so that the unit test can focus on comprehensive value coverage rather than dealing with the complexity of a child component's behavior.
Sometimes, neither of the above are feasible. In these cases, adding test attributes to simplify the selectors might be the best option. A list of possible selectors include:
- A semantic attribute like
name
(also verifies thatname
was setup properly) - A
data-testid
attribute (recommended by maintainers of@vue/test-utils
) optionally combined withshallowMountExtended
ormountExtended
import { shallowMountExtended } from 'helpers/vue_test_utils_helper'
const wrapper = shallowMountExtended(ExampleComponent);
it('exists', () => {
// Best (especially for integration tests)
wrapper.findByRole('link', { name: /Click Me/i })
wrapper.findByRole('link', { name: 'Click Me' })
wrapper.findByText('Click Me')
wrapper.findByText(/Click Me/i)
// Good (especially for unit tests)
wrapper.findComponent(FooComponent);
wrapper.find('input[name=foo]');
wrapper.find('[data-testid="my-foo-id"]');
wrapper.findByTestId('my-foo-id'); // with shallowMountExtended or mountExtended – check below
// Bad
wrapper.find({ ref: 'foo'});
wrapper.find('.js-foo');
wrapper.find('.gl-button');
You should use kebab-case
for data-testid
attribute.
It is not recommended that you add .js-*
classes just for testing purposes. Only do this if there are no other feasible options available.
Avoid using Vue template refs to query DOM elements in tests because they're an implementation detail of the component, not a public API.
Querying for child components
When testing Vue components with @vue/test-utils
another possible approach is querying for child
components instead of querying for DOM nodes. This assumes that implementation details of behavior
under test should be covered by that component's individual unit test. There is no strong preference
in writing DOM or component queries as long as your tests reliably cover expected behavior for the
component under test.
Example:
Naming unit/component tests
Unit/Component tests should be named ${componentName}_spec.js
If the test name is not specific enough, consider renaming the component.
For Example:
diff_stats_dropdown.vue
should have a unit/component test named diff_stats_dropdown_spec.js
Describe block naming
When writing describe test blocks to test specific functions/methods, use the method name as the describe block name.
Bad:
describe('#methodName', () => {
it('passes', () => {
expect(true).toEqual(true);
describe('.methodName', () => {
Good:
describe('methodName', () => {
Testing promises
When testing Promises you should always make sure that the test is asynchronous and rejections are handled. It's now possible to use the async/await
syntax in the test suite:
it('tests a promise', async () => {
const users = await fetchUsers()
expect(users.length).toBe(42)
it('tests a promise rejection', async () => {
await expect(user.getUserName(1)).rejects.toThrow('User with 1 not found.');
You can also return a promise from the test function.
Using the done
and done.fail
callbacks is discouraged when working with
promises. They should not be used.
Bad:
// missing return
it('tests a promise', () => {
promise.then(data => {
expect(data).toBe(asExpected);
// uses done/done.fail
it('tests a promise', done => {
promise
.then(data => {
.then(done)
.catch(done.fail);
Good:
// verifying a resolved promise
return promise
.then(data => {
// verifying a resolved promise using Jest's `resolves` matcher
return expect(promise).resolves.toBe(asExpected);
// verifying a rejected promise using Jest's `rejects` matcher
it('tests a promise rejection', () => {
return expect(promise).rejects.toThrow(expectedError);
Manipulating Time
Sometimes we have to test time-sensitive code. For example, recurring events that run every X amount of seconds or similar. Here are some strategies to deal with that:
setTimeout()
/ setInterval()
in application
If the application itself is waiting for some time, mock await the waiting. In Jest this is already done by default (see also Jest Timer Mocks).
const doSomethingLater = () => {
setTimeout(() => {
// do something
}, 4000);
in Jest:
it('does something', () => {
doSomethingLater();
jest.runAllTimers();
expect(something).toBe('done');
Mocking the current location in Jest
NOTE:
The value of window.location.href
is reset before every test to avoid earlier
tests affecting later ones.
If your tests require window.location.href
to take a particular value, use
the setWindowLocation
helper:
import setWindowLocation from 'helpers/set_window_location_helper';
setWindowLocation('https://gitlab.test/foo?bar=true');
expect(window.location).toMatchObject({
hostname: 'gitlab.test',
pathname: '/foo',
search: '?bar=true',
To modify only the hash, use either the setWindowLocation
helper, or assign
directly to window.location.hash
, for example:
window.location.hash = '#foo';
expect(window.location.href).toBe('http://test.host/#foo');
If your tests need to assert that certain window.location
methods were
called, use the useMockLocationHelper
helper:
import { useMockLocationHelper } from 'helpers/mock_window_location_helper';
useMockLocationHelper();
window.location.reload();
expect(window.location.reload).toHaveBeenCalled();
Testing clean-up of event listeners and timeouts
Often times in components we create event listeners or timeouts on the beforeDestroy
(beforeUnmount
for Vue 3) hooks. It is important to test that both listeners and timeouts are cleared when the component instance is destroyed, as forgetting to clean up these events can cause problems like memory leaks and broken references on event listeners.
Consider the following example:
beforeDestroy() {
removeEventListener('keydown', someListener)
clearTimeout(timeoutPointer)
In the above example, a component is both clearing a keydown
event listener and a timeout that was created elsewhere.
Let's take a look at the relevant tests.
describe('Cleanup before destroy', () => {
beforeEach(() => {
createComponent()
// Destroy the component immediately to invoke the `beforeDestroy` hook
wrapper.destroy()
it('removes the event listener', () => {
const spy = jest.spyOn(window, 'removeEventListener')
expect(spy).toHaveBeenCalledTimes(1)
expect(spy).toHaveBeenCalledWith('keydown', expect.any(Function))
it('clears the pending timeouts', () => {
const spy = jest.spyOn(window, 'clearTimeout')
The above example does not explicitly check for the function that is called on the keydown
listener as it will normally be an implementation detail. The same happens with the clearTimeout
call, as the parameter will be a pointer to a timer created internally in the component.
Due to this, it is normally sufficient to check that the spies have been called, with the recommended addition of checking the times that they have been called.
Waiting in tests
Sometimes a test needs to wait for something to happen in the application before it continues.
You should try to avoid:
setTimeout
because it makes the reason for waiting unclear. Additionally, it is faked in our tests so its usage is tricky. -
setImmediate
because it is no longer supported in Jest 27 and later. See this epic for details.
Promises and Ajax calls
Register handler functions to wait for the Promise
to be resolved.
const askTheServer = () => {
return axios
.get('/endpoint')
.then(response => {
// do something
.catch(error => {
// do something else
in Jest:
it('waits for an Ajax call', async () => {
await askTheServer()
If you cannot register handlers to the Promise
, for example because it is executed in a synchronous Vue lifecycle hook, take a look at the waitFor
helpers or flush all pending Promise
s with:
in Jest:
synchronousFunction();
await waitForPromises();
Vue rendering
Use nextTick()
to wait until a Vue component is
re-rendered.
in Jest:
import { nextTick } from 'vue';
it('renders something', async () => {
wrapper.setProps({ value: 'new value' });
await nextTick();
expect(wrapper.text()).toBe('new value');
Events
If the application triggers an event that you need to wait for in your test, register an event handler which contains the assertions:
it('waits for an event', () => {
eventHub.$once('someEvent', eventHandler);
someFunction();
return new Promise((resolve) => {
function expectEventHandler() {
resolve();
In Jest you can also use a Promise
for this:
const eventTriggered = new Promise(resolve => eventHub.$once('someEvent', resolve));
someFunction();
return eventTriggered.then(() => {
gon
object
Manipulate gon
(or window.gon
) is a global object used to pass data from the backend. If your test depends
on its value you can directly modify it:
describe('when logged in', () => {
beforeEach(() => {
gon.current_user_id = 1;
it('shows message', () => {
expect(wrapper.text()).toBe('Logged in!');
gon
is reset in every test to ensure tests are isolated.
Ensuring that tests are isolated
Tests are typically architected in a pattern which requires a recurring setup of the component under test. This is often achieved by making use of the beforeEach
hook.
Example
let wrapper;
beforeEach(() => {
wrapper = mount(Component);
With enableAutoDestroy, it is no longer necessary to manually call wrapper.destroy()
However, some mocks, spies, and fixtures do need to be torn down, and we can leverage the afterEach
hook.
Example
let wrapper;
afterEach(() => {
fakeApollo = null;
store = null;
Testing local-only Apollo queries and mutations
To add a new query or mutation before it is added to the backend, we can use the @client
directive. For example:
mutation setActiveBoardItemEE($boardItem: LocalBoardItem, $isIssue: Boolean = true) {
setActiveBoardItem(boardItem: $boardItem) @client {
...Issue @include(if: $isIssue)
...EpicDetailed @skip(if: $isIssue)
When writing test cases for such calls, we can use resolvers to make sure they are called with the correct parameters.
For example, when creating the wrapper, we should make sure the resolver is mapped to the query or mutation.
The mutation we are mocking here is setActiveBoardItem
const mockSetActiveBoardItemResolver = jest.fn();
const mockApollo = createMockApollo([], {
Mutation: {
setActiveBoardItem: mockSetActiveBoardItemResolver,
In the following code, we must pass four arguments. The second one must be the collection of input variables of the query or mutation mocked. To test that the mutation is called with the correct parameters:
it('calls setActiveBoardItemMutation on close', async () => {
wrapper.findComponent(GlDrawer).vm.$emit('close');
expect(mockSetActiveBoardItemResolver).toHaveBeenCalledWith(
boardItem: null,
expect.anything(),
expect.anything(),
Jest best practices
toBe
over toEqual
when comparing primitive values
Prefer Jest has toBe
and
toEqual
matchers.
As toBe
uses
Object.is
to compare values, it's faster (by default) than using toEqual
While the latter eventually falls back to leverage Object.is
for primitive values, it should only be used when complex objects need a comparison.
Examples:
const foo = 1;
// Bad
expect(foo).toEqual(1);
// Good
expect(foo).toBe(1);
Prefer more befitting matchers
Jest provides useful matchers like toHaveLength
or toBeUndefined
to make your tests more
readable and to produce more understandable error messages. Check their docs for the
full list of matchers.
Examples:
const arr = [1, 2];
// prints:
// Expected length: 1
// Received length: 2
expect(arr).toHaveLength(1);
// prints:
// Expected: 1
// Received: 2
expect(arr.length).toBe(1);
// prints:
// expect(received).toBe(expected) // Object.is equality
// Expected: undefined
// Received: "bar"
const foo = 'bar';
expect(foo).toBe(undefined);
// prints:
// expect(received).toBeUndefined()
// Received: "bar"
const foo = 'bar';
expect(foo).toBeUndefined();
toBeTruthy
or toBeFalsy
Avoid using Jest also provides following matchers: toBeTruthy
and toBeFalsy
. We should not use them because
they make tests weaker and produce false-positive results.
For example, expect(someBoolean).toBeFalsy()
passes when someBoolean === null
, and when
someBoolean === false
toBeDefined
matcher
Tricky Jest has the tricky toBeDefined
matcher that can produce false positive test. Because it
validates
the given value for undefined
only.
// Bad: if finder returns null, the test will pass
expect(wrapper.find('foo')).toBeDefined();
// Good
expect(wrapper.find('foo').exists()).toBe(true);
setImmediate
Avoid using Try to avoid using setImmediate
. setImmediate
is an ad-hoc solution to run your callback after
the I/O completes. And it's not part of the Web API, hence, we target NodeJS environments in our
unit tests.
Instead of setImmediate
, use jest.runAllTimers
or jest.runOnlyPendingTimers
to run pending timers.
The latter is useful when you have setInterval
in the code. Remember: our Jest configuration uses fake timers.
Avoid non-deterministic specs
Non-determinism is the breeding ground for flaky and brittle specs. Such specs end up breaking the CI pipeline, interrupting the work flow of other contributors.
- Make sure your test subject's collaborators (for example, Axios, Apollo, Lodash helpers) and test environment (for example, Date) behave consistently across systems and over time.
- Make sure tests are focused and not doing "extra work" (for example, needlessly creating the test subject more than once in an individual test).
Date
for determinism
Faking Date
is faked by default in our Jest environment. This means every call to Date()
or Date.now()
returns a fixed deterministic value.
If you really need to change the default fake date, you can call useFakeDate
within any describe
block, and
the date will be replaced for that specs within that describe
context only:
import { useFakeDate } from 'helpers/fake_date';
describe('cool/component', () => {
// Default fake `Date`
const TODAY = new Date();
// NOTE: `useFakeDate` cannot be called during test execution (that is, inside `it`, `beforeEach`, `beforeAll`, etc.).
describe("on Ada Lovelace's Birthday", () => {
useFakeDate(1815, 11, 10)
it('Date is no longer default', () => {
expect(new Date()).not.toEqual(TODAY);
it('Date is still default in this scope', () => {
expect(new Date()).toEqual(TODAY)
Similarly, if you really need to use the real Date
class, then you can import and call useRealDate
within any describe
block:
import { useRealDate } from 'helpers/fake_date';
// NOTE: `useRealDate` cannot be called during test execution (that is, inside `it`, `beforeEach`, `beforeAll`, etc.).
describe('with real date', () => {
useRealDate();
Math.random
for determinism
Faking Consider replacing Math.random
with a fake when the test subject depends on it.
beforeEach(() => {
// https://xkcd.com/221/
jest.spyOn(Math, 'random').mockReturnValue(0.4);
Console warnings and errors in tests
Unexpected console warnings and errors are indicative of problems in our production code.
We want our test environment to be strict, so your tests should fail when unexpected
console.error
or console.warn
calls are made.
Ignoring console messages from watcher
Since there's a lot of code outside of our control, there are some console messages that
are ignored by default and will not fail a test if used. This list of ignored
messages can be maintained where we call setupConsoleWatcher
. Example:
setupConsoleWatcher({
ignores: [
// Any call to `console.error('Foo bar')` or `console.warn('Foo bar')` will be ignored by our console watcher.
'Foo bar',
// Use regex to allow for flexible message matching.
/Lorem ipsum/,
If a specific test needs to ignore a specific message for a describe
block, use the
ignoreConsoleMessages
helper near the top of the describe
. This automatically
calls beforeAll
and afterAll
to set up/teardown this set of ignored for the test
context.
Use this sparingly and only if absolutely necessary for test maintainability. Example:
import { ignoreConsoleMessages } from 'helpers/console_watcher';
describe('foos/components/foo.vue', () => {
describe('when blooped', () => {
// Will not fail a test if `console.warn('Lorem ipsum')` is called
ignoreConsoleMessages([
/^Lorem ipsum/
describe('default', () => {
// Will fail a test if `console.warn('Lorem ipsum')` is called
Factories
TBU
Mocking Strategies with Jest
Stubbing and Mocking
Stubs or spies are often used synonymously. In Jest it's quite easy thanks to the .spyOn
method.
Official docs
The more challenging part are mocks, which can be used for functions or even dependencies.
Manual module mocks
Manual mocks are used to mock modules across the entire Jest environment. This is a very powerful testing tool that helps simplify unit testing by mocking out modules that cannot be easily consumed in our test environment.
WARNING: Do not use manual mocks if a mock should not be consistently applied in every spec (that is, it's only needed by a few specs). Instead, consider using
jest.mock(..)
(or a similar mocking function) in the relevant spec file.
Where should you put manual mocks?
Jest supports manual module mocks by placing a mock in a __mocks__/
directory next to the source module
(for example, app/assets/javascripts/ide/__mocks__
). Don't do this. We want to keep all of our test-related code in one place (the spec/
folder).
If a manual mock is needed for a node_modules
package, use the spec/frontend/__mocks__
folder. Here's an example of
a Jest mock for the package monaco-editor
If a manual mock is needed for a CE module, place the implementation in
spec/frontend/__helpers__/mocks
and add a line to the frontend/test_setup
(or the frontend/shared_test_setup
) that looks something like:
// "~/lib/utils/axios_utils" is the path to the real module
// "helpers/mocks/axios_utils" is the path to the mocked implementation
jest.mock('~/lib/utils/axios_utils', () => jest.requireActual('helpers/mocks/axios_utils'));
Manual mock examples
__helpers__/mocks/axios_utils
- This mock is helpful because we don't want any unmocked requests to pass any tests. Also, we are able to inject some test helpers such asaxios.waitForAll
__mocks__/mousetrap/index.js
- This mock is helpful because the module itself uses AMD format which webpack understands, but is incompatible with the jest environment. This mock doesn't remove any behavior, only provides a nice es6 compatible wrapper. -
__mocks__/monaco-editor/index.js
- This mock is helpful because the Monaco package is completely incompatible in a Jest environment. In fact, webpack requires a special loader to make it work. This mock makes this package consumable by Jest.
Keep mocks light
Global mocks introduce magic and technically can reduce test coverage. When mocking is deemed profitable:
- Keep the mock short and focused.
- Leave a top-level comment in the mock on why it is necessary.
Additional mocking techniques
Consult the official Jest docs for a full overview of the available mocking features.
Running Frontend Tests
Before generating fixtures, make sure you have a running GDK instance.
For running the frontend tests, you need the following commands:
rake frontend:fixtures
(re-)generates fixtures. Make sure that fixtures are up-to-date before running tests that require them. -
yarn jest
runs Jest tests.
Running CE and EE tests
Whenever you create tests for both CE and EE environments, because your changes have EE features, you need to take some steps to ensure that both tests pass locally and on the pipeline when run.
Check this section to learn more about testing both environments.
Live testing and focused testing -- Jest
While you work on a test suite, you may want to run these specs in watch mode, so they rerun automatically on every save.
# Watch and rerun all specs matching the name icon
yarn jest --watch icon
# Watch and rerun one specific file
yarn jest --watch path/to/spec/file.spec.js
You can also run some focused tests without the --watch
flag
# Run specific jest file
yarn jest ./path/to/local_spec.js
# Run specific jest folder
yarn jest ./path/to/folder/
# Run all jest files which path contain term
yarn jest term
Frontend test fixtures
Frontend fixtures are files containing responses from backend controllers. These responses can be either HTML generated from HAML templates or JSON payloads. Frontend tests that rely on these responses are often using fixtures to validate correct integration with the backend code.
Use fixtures
To import a JSON or HTML fixture, import
it using the test_fixtures
alias.
import responseBody from 'test_fixtures/some/fixture.json' // loads tmp/tests/frontend/fixtures-ee/some/fixture.json
it('makes a request', () => {
axiosMock.onGet(endpoint).reply(200, responseBody);
myButton.click();
Generate fixtures
You can find code to generate test fixtures in:
spec/frontend/fixtures/
, for running tests in CE. -
ee/spec/frontend/fixtures/
, for running tests in EE.
You can generate fixtures by running:
bin/rake frontend:fixtures
to generate all fixtures -
bin/rspec spec/frontend/fixtures/merge_requests.rb
to generate specific fixtures (in this case formerge_request.rb
You can find generated fixtures are in tmp/tests/frontend/fixtures-ee
Download fixtures
We generate fixtures in GitLab CI, and store them in the package registry.
The scripts/frontend/download_fixtures.sh
script is meant to download and extract those fixtures for local use:
# Checks if a frontend fixture package exists in the gitlab-org/gitlab
# package registry by looking at the commits on a local branch.
# The package is downloaded and extracted if it exists
$ scripts/frontend/download_fixtures.sh
# Same as above, but only looks at the last 10 commits of the currently checked-out branch
$ scripts/frontend/download_fixtures.sh --max-commits=10
# Looks at the commits on the local master branch instead of the currently checked-out branch
$ scripts/frontend/download_fixtures.sh --branch master
Creating new fixtures
For each fixture, you can find the content of the response
variable in the output file.
For example, a test named "merge_requests/diff_discussion.json"
in spec/frontend/fixtures/merge_requests.rb
produces an output file tmp/tests/frontend/fixtures-ee/merge_requests/diff_discussion.json
The response
variable gets automatically set if the test is marked as type: :request
or type: :controller
When creating a new fixture, it often makes sense to take a look at the corresponding tests for the
endpoint in (ee/)spec/controllers/
or (ee/)spec/requests/
GraphQL query fixtures
You can create a fixture that represents the result of a GraphQL query using the get_graphql_query_as_string
helper method. For example:
# spec/frontend/fixtures/releases.rb
describe GraphQL::Query, type: :request do
include GraphqlHelpers
all_releases_query_path = 'releases/graphql/queries/all_releases.query.graphql'
it "graphql/#{all_releases_query_path}.json" do
query = get_graphql_query_as_string(all_releases_query_path)
post_graphql(query, current_user: admin, variables: { fullPath: project.full_path })
expect_graphql_errors_to_be_empty
end
end
This will create a new fixture located at
tmp/tests/frontend/fixtures-ee/graphql/releases/graphql/queries/all_releases.query.graphql.json
You can import the JSON fixture in a Jest test using the test_fixtures
alias
as described previously.
Data-driven tests
Similar to RSpec's parameterized tests, Jest supports data-driven tests for:
- Individual tests using
test.each
(aliased toit.each
). - Groups of tests using
describe.each
These can be useful for reducing repetition within tests. Each option can take an array of data values or a tagged template literal.
For example:
// function to test
const icon = status => status ? 'pipeline-passed' : 'pipeline-failed'
const message = status => status ? 'pipeline-passed' : 'pipeline-failed'
// test with array block
it.each([
[false, 'pipeline-failed'],
[true, 'pipeline-passed']
])('icon with %s will return %s',
(status, icon) => {
expect(renderPipeline(status)).toEqual(icon)
NOTE: Only use template literal block if pretty print is not needed for spec output. For example, empty strings, nested objects etc.
For example, when testing the difference between an empty search string and a non-empty search string, the use of the array block syntax with the pretty print option would be preferred. That way the differences between an empty string (''
) and a non-empty string ('search string'
) would be visible in the spec output. Whereas with a template literal block, the empty string would be shown as a space, which could lead to a confusing developer experience.
// bad
it.each`
searchTerm | expected
${''} | ${{ issue: { users: { nodes: [] } } }}
${'search term'} | ${{ issue: { other: { nested: [] } } }}
`('when search term is $searchTerm, it returns $expected', ({ searchTerm, expected }) => {
expect(search(searchTerm)).toEqual(expected)
// good
it.each([
['', { issue: { users: { nodes: [] } } }],
['search term', { issue: { other: { nested: [] } } }],
])('when search term is %p, expect to return %p',
(searchTerm, expected) => {
// test suite with tagged template literal block
describe.each`
status | icon | message
${false} | ${'pipeline-failed'} | ${'Pipeline failed - boo-urns'}
${true} | ${'pipeline-passed'} | ${'Pipeline succeeded - win!'}
`('pipeline component', ({ status, icon, message }) => {
it(`returns icon ${icon} with status ${status}`, () => {
expect(icon(status)).toEqual(message)
it(`returns message ${message} with status ${status}`, () => {
expect(message(status)).toEqual(message)
Gotchas
RSpec errors due to JavaScript
By default RSpec unit tests don't run JavaScript in the headless browser and rely on inspecting the HTML generated by rails.
If an integration test depends on JavaScript to run correctly, you need to make sure the spec is configured to enable JavaScript when the tests are run. If you don't do this, the spec runner displays vague error messages.
To enable a JavaScript driver in an RSpec
test, add :js
to the
individual spec or the context block containing multiple specs that need
JavaScript enabled:
# For one spec
it 'presents information about abuse report', :js do
# assertions...
end
describe "Admin::AbuseReports", :js do
it 'presents information about abuse report' do
# assertions...
end
it 'shows buttons for adding to abuse report' do
# assertions...
end
end
Jest test timeout due to asynchronous imports
If a module asynchronously imports some other modules at runtime, these modules must be transpiled by the Jest loaders at runtime. It's possible that this can cause Jest to timeout.
If you run into this issue, consider eager importing the module so that Jest compiles and caches it at compile-time, fixing the runtime timeout.
// the_subject.js
export default {
components: {
// Async import Thing because it is large and isn't always needed.
Thing: () => import(/* webpackChunkName: 'thing' */ './path/to/thing.vue'),
Jest doesn't automatically transpile the thing.vue
module, and depending on its size, could
cause Jest to time out. We can force Jest to transpile and cache this module by eagerly importing
it like so:
// the_subject_spec.js
import Subject from '~/feature/the_subject.vue';
// Force Jest to transpile and cache
// eslint-disable-next-line no-unused-vars
import _Thing from '~/feature/path/to/thing.vue';
NOTE: Do not disregard test timeouts. This could be a sign that there's actually a production problem. Use this opportunity to analyze the production webpack bundles and chunks and confirm that there is not a production issue with the asynchronous imports.
Overview of Frontend Testing Levels
Main information on frontend testing levels can be found in the Testing Levels page.
Tests relevant for frontend development can be found at the following places:
spec/frontend/
, for Jest tests -
spec/features/
, for RSpec tests
RSpec runs complete feature tests, while the Jest directories contain frontend unit tests, frontend component tests, and frontend integration tests.
Before May 2018, features/
also contained feature tests run by Spinach. These tests were removed from the codebase in May 2018 (#23036).
See also Notes on testing Vue components.
Test helpers
Test helpers can be found in spec/frontend/__helpers__
If you introduce new helpers, place them in that directory.
testAction
Vuex Helper: We have a helper available to make testing actions easier, as per official documentation:
// prefer using like this, a single object argument so parameters are obvious from reading the test
await testAction({
action: actions.actionName,
payload: { deleteListId: 1 },
state: { lists: [1, 2, 3] },
expectedMutations: [ { type: types.MUTATION} ],
expectedActions: [],
// old way, don't do this for new tests
testAction(
actions.actionName, // action
{ }, // params to be passed to action
state, // state
{ type: types.MUTATION},
{ type: types.MUTATION_1, payload: {}},
], // mutations committed
{ type: 'actionName', payload: {}},
{ type: 'actionName1', payload: {}},
] // actions dispatched
done,
Wait until Axios requests finish
The Axios Utils mock module located in spec/frontend/__helpers__/mocks/axios_utils.js
contains two helper methods for Jest tests that spawn HTTP requests.
These are very useful if you don't have a handle to the request's Promise, for example when a Vue component does a request as part of its lifecycle.
waitFor(url, callback)
: Runscallback
after a request tourl
finishes (either successfully or unsuccessfully). -
waitForAll(callback)
: Runscallback
once all pending requests have finished. If no requests are pending, runscallback
on the next tick.
Both functions run callback
on the next tick after the requests finish (using setImmediate()
), to allow any .then()
or .catch()
handlers to run.
and mountExtended
The shallowMountExtended
and mountExtended
utilities provide you with the ability to perform
any of the available DOM Testing Library queries
by prefixing them with find
or findAll
import { shallowMountExtended } from 'helpers/vue_test_utils_helper';
describe('FooComponent', () => {
const wrapper = shallowMountExtended({
template: `
<div data-testid="gitlab-frontend-stack">
<p>GitLab frontend stack</p>
<div role="tablist">
<button role="tab" aria-selected="true">Vue.js</button>
<button role="tab" aria-selected="false">GraphQL</button>
<button role="tab" aria-selected="false">SCSS</button>
</div>
</div>
it('finds elements with `findByTestId`', () => {
expect(wrapper.findByTestId('gitlab-frontend-stack').exists()).toBe(true);
it('finds elements with `findByText`', () => {
expect(wrapper.findByText('GitLab frontend stack').exists()).toBe(true);
expect(wrapper.findByText('TypeScript').exists()).toBe(false);
it('finds elements with `findAllByRole`', () => {
expect(wrapper.findAllByRole('tab').length).toBe(3);
Check an example in spec/frontend/alert_management/components/alert_details_spec.js
Testing with older browsers
Some regressions only affect a specific browser version. We can install and test in particular browsers with either Firefox or BrowserStack using the following steps:
BrowserStack
BrowserStack allows you to test more than 1200 mobile devices and browsers. You can use it directly through the live app or you can install the chrome extension for easy access. Sign in to BrowserStack with the credentials saved in the Engineering vault of the GitLab shared 1Password account.
Firefox
macOS
You can download any older version of Firefox from the releases FTP server, https://ftp.mozilla.org/pub/firefox/releases/:
- From the website, select a version, in this case
50.0.1
. - Go to the mac folder.
- Select your preferred language. The DMG package is inside. Download it.
- Drag and drop the application to any other folder but the
Applications
folder. - Rename the application to something like
Firefox_Old
. - Move the application to the
Applications
folder. - Open up a terminal and run
/Applications/Firefox_Old.app/Contents/MacOS/firefox-bin -profilemanager
to create a new profile specific to that Firefox version. - Once the profile has been created, quit the app, and run it again like usual. You now have a working older Firefox version.
Snapshots
Jest snapshot tests are a useful way to prevent unexpected changes to the HTML output of a given component. They should only be used when other testing methods (such as asserting elements with vue-tests-utils
) do not cover the required use case. To use them within GitLab, there are a few guidelines that should be highlighted:
- Treat snapshots as code
- Don't think of a snapshot file as a black box
- Care for the output of the snapshot, otherwise, it's not providing any real value. This will usually involve reading the generated snapshot file as you would read any other piece of code
Think of a snapshot test as a simple way to store a raw String
representation of what you've put into the item being tested. This can be used to evaluate changes in a component, a store, a complex piece of generated output, etc. You can see more in the list below for some recommended Do's and Don'ts
While snapshot tests can be a very powerful tool, they are meant to supplement, not to replace unit tests.
Jest provides a great set of docs on best practices that we should keep in mind when creating snapshots.
How does a snapshot work?
A snapshot is purely a stringified version of what you ask to be tested on the left-hand side of the function call. This means any kind of changes you make to the formatting of the string has an impact on the outcome. This process is done by leveraging serializers for an automatic transform step. For Vue this is already taken care of by leveraging the vue-jest
package, which offers the proper serializer.
Should the outcome of your spec be different from what is in the generated snapshot file, you'll be notified about it by a failing test in your test suite.
Find all the details in Jests official documentation https://jestjs.io/docs/snapshot-testing
Pros and Cons
Pros
- Provides a good warning against accidental changes of important HTML structures
- Ease of setup
Cons
- Lacks the clarity or guard rails that
vue-tests-utils
provides by finding elements and asserting their presence directly - Creates unnecessary noise when updating components purposefully
- High risk of taking a snapshot of bugs, which then turns the tests against us since the test will now fail when fixing the issue
- No meaningful assertions or expectations within snapshots makes them harder to reason about or replace
- When used with dependencies like GitLab UI, it creates fragility in tests when the underlying library changes the HTML of a component we are testing
When to use
Use snapshots when
- Protecting critical HTML structures so it doesn't change by accident
- Asserting JS object or JSON outputs of complex utility functions
When not to use
Don't use snapshots when
- Tests could be written using
vue-tests-utils
instead - Asserting the logic of a component
- Predicting data structure(s) outputs
- There are UI elements outside of the repository (think of GitLab UI version updates)
Examples
As you can see, the cons of snapshot tests far outweigh the pros in general. To illustrate this better, this section will show a few examples of when you might be tempted to use snapshot testing and why they are not good patterns.
Example #1 - Element visibility
When testing elements visibility, favour using vue-tests-utils (VTU)
to find a given component and then a basic .exists()
method call on the VTU wrapper. This provides better readability and more resilient testing. If you look at the examples below, notice how the assertions on the snapshots do not tell you what you are expecting to see. We are relying entirely on it
description to give us context and on the assumption that the snapshot has captured the desired behavior.
<template>
<my-component v-if="isVisible" />
</template>
Bad:
it('hides the component', () => {
createComponent({ props: { isVisible: false }})
expect(wrapper.element).toMatchSnapshot()
it('shows the component', () => {
createComponent({ props: { isVisible: true }})
Good:
expect(findMyComponent().exists()).toBe(false)
expect(findMyComponent().exists()).toBe(true)
Not only that, but imagine having passed the wrong prop to your component and having the wrong visibility: the snapshot test would still pass because you would have captured the HTML with the issue and so unless you double-checked the output of the snapshot, you would never know that your test is broken.
Example #2 - Presence of text
Finding text within a component is very easy by using the vue-test-utils
method wrapper.text()
. However, there are some cases where it might be tempting to use snapshots when the value returned has a lot of inconsistent spacing due to formatting or HTML nesting.
In these instances, it is better to assert each string individually and make multiple assertions than to use a snapshot to ignore the spaces. This is because any change to the DOM layout will fail the snapshot test even if the text is still perfectly formatted.
<template>
<gl-sprintf :message="my-message">
<template #code="{ content }">
<code>{{ content }}</code>
</template>
</gl-sprintf>
<p> My second message </p>
</template>
Bad:
it('renders the text as I expect', () => {
expect(wrapper.text()).toMatchSnapshot()
Good:
it('renders the code snippet', () => {
expect(findCodeTag().text()).toContain("myFunction()")
it('renders the paragraph text', () => {
expect(findOtherText().text()).toBe("My second message")
Example #3 - Complex HTML
When we have very complex HTML, we should focus on asserting specific sensitive and meaningful points rather than capturing it as a whole. The value in a snapshot test is to warn developers that they might have accidentally change an HTML structure that they did not intend to change. If the output of the change is hard to read, which is often the case with complex HTML output, then is the signal itself that something changed sufficient? And if it is, can it be accomplished without snapshots?
A good example of a complex HTML output is GlTable
. Snapshot testing might feel like a good option since you can capture rows and columns structure, but we should instead try to assert text we expect or count the number of rows and columns manually.
<template>
<gl-table ...all-them-props />
</template>
Bad:
it('renders GlTable as I expect', () => {
expect(findGlTable().element).toMatchSnapshot()
Good:
it('renders the right number of rows', () => {
expect(findGlTable().findAllRows()).toHaveLength(expectedLength)
it('renders the special icon that only appears on a full moon', () => {
expect(findGlTable().findMoonIcon().exists()).toBe(true)
it('renders the correct email format', () => {
expect(findGlTable().text()).toContain('my_strange_email@shaddyprovide.com')
Although more verbose, this now means that our tests are not going to break if GlTable
changes its internal implementation, we communicate to other developers (or ourselves in 6 months) what is important to preserve when refactoring or adding to our table.
How to take a snapshot
it('makes the name look pretty', () => {
expect(prettifyName('Homer Simpson')).toMatchSnapshot()
When this test runs the first time a fresh .snap
file will be created. It will look something like this:
// Jest Snapshot v1, https://goo.gl/fbAQLP
exports[`makes the name look pretty`] = `
Sir Homer Simpson the Third
Now, every time you call this test, the new snapshot will be evaluated against the previously created version. This should highlight the fact that it's important to understand the content of your snapshot file and treat it with care. Snapshots will lose their value if the output of the snapshot is too big or complex to read, this means keeping snapshots isolated to human-readable items that can be either evaluated in a merge request review or are guaranteed to never change.
The same can be done for wrappers
or elements
it('renders the component correctly', () => {
expect(wrapper).toMatchSnapshot()
expect(wrapper.element).toMatchSnapshot();
The above test will create two snapshots. It's important to decide which of the snapshots provide more value for codebase safety. That is, if one of these snapshots changes, does that highlight a possible break in the codebase? This can help catch unexpected changes if something in an underlying dependency changes without our knowledge.
Get started with feature tests
What is a feature test
A feature test, also known as white-box testing
, is a test that spawns a browser and has Capybara helpers. This means the test can:
- Locate an element in the browser.
- Click that element.
- Call the API.
Feature tests are expensive to run. You should make sure that you really want this type of test before running one.
All of our feature tests are written in Ruby
but often end up being written by JavaScript
engineers, as they implement the user-facing feature. So, the following section assumes no prior knowledge of Ruby
or Capybara
, and provide a clear guideline on when and how to use these tests.
When to use feature tests
You should use a feature test when the test:
- Is across multiple components.
- Requires that a user navigate across pages.
- Is submitting a form and observing results elsewhere.
- Would result in a huge number of mocking and stubbing with fake data and components if done as a unit test.
Feature tests are especially useful when you want to test:
- That multiple components are working together successfully.
- Complex API interactions. Feature tests interact with the API, so they are slower but do not need any level of mocking or fixtures.
When not to use feature tests
You should use jest
and vue-test-utils
unit tests instead of a feature test if you can get the same test results from these methods. Feature tests are quite expensive to run.
You should use a unit test if:
- The behavior you are implementing is all in one component.
- You can simulate other components' behavior to trigger the desired effect.
- You can already select UI elements in the virtual DOM to trigger the desired effects.
Also, if a behavior in your new code needs multiple components to work together, you should consider testing your behavior higher in the component tree. For example, let's say that we have a component called ParentComponent
with the code:
<script>
export default{
data(){
return {
internalData: 'oldValue'
methods:{
changeSomeInternalData(newVal){
this.internalData = newVal
</script>
<template>
<div>
<child-component-1 @child-event="changeSomeInternalData" />
<child-component-2 :parent-data="internalData" />
</div>
</template>
In this example:
ChildComponent1
emits an event. -
ParentComponent
changes itsinternalData
value. -
ParentComponent
passes the props down toChildComponent2
You can use a unit test instead by:
- From inside the
ParentComponent
unit test file, emitting the expected event fromchildComponent1
- Making sure the prop is passed down to
childComponent2
Then each child component unit tests what happens when the event is emitted and when the prop changes.
This example also applies at larger scale and with deeper component trees. It is definitely worth using unit tests and avoiding the extra cost of feature tests if you can:
- Confidently mount child components.
- Emit events or select elements in the virtual DOM.
- Get the test behavior that you want.
Where to create your test
Feature tests live in spec/features
folder. You should look for existing files that can test the page you are adding a feature to. Within that folder, you can locate your section. For example, if you wanted to add a new feature test for the pipeline page, you would look in spec/features/projects/pipelines
and see if the test you want to write exists here.
How to run a feature test
Make sure that you have a working GDK environment.
Start your
gdk
environment withgdk start
command. -
In your terminal, run:
bundle exec rspec path/to/file:line_of_my_test
You can also prefix this command with WEBDRIVER_HEADLESS=0
which will run the test by opening an actual browser on your computer that you can see, which is very useful for debugging.
To use Firefox, instead of Chrome, prefix the command with WEBDRIVER=firefox
How to write a test
Basic file structure
Make all string literals unchangeable
In all feature tests, the very first line should be:
# frozen_string_literal: true
This is in every
Ruby
file and makes all string literals unchangeable. There are also some performance benefits, but this is beyond the scope of this section. -
Import dependencies.
You should import the modules you need. You will most likely always need to require
spec_helper
:require 'spec_helper'
Import any other relevant module.
Create a global scope for RSpec to define our tests, just like what we do in jest with the initial describe block.
Then, you need to create the very first RSpec
scope.
RSpec.describe 'Pipeline', :js do
end
What is different though, is that just like everything in Ruby, this is actually a class
. Which means that right at the top, you can include
modules that you'd need for your test. For example, you could include the RoutesHelpers
to navigate more easily.
include RoutesHelpers
end
After all of this implementation, we have a file that looks something like this:
end
Seeding data
Each test is in its own environment and so you must use a factory to seed the required data. To continue on with the pipeline example, let's say that you want a test that takes you to the main pipeline page, which is at the route /namespace/project/-/pipelines/:id/
Most feature tests at least require you to create a user, because you want to be signed in. You can skip this step if you don't have to be signed in, but as a general rule, you should always create a user unless you are specifically testing a feature looked at by an anonymous user. This makes sure that you explicitly set a level of permission that you can edit in the test as needed to change or test a new level of permission as the section changes. To create a user:
let(:user) { create(:user) }
This creates a variable that holds the newly created user and we can use create
because we imported the spec_helper
However, we have not done anything with this user yet because it's just a variable. So, in the before do
block of the spec, we could sign in with the user so that every spec starts with an authenticated user.
before do
sign_in(user)
end
Now that we have a user, we should look at what else we'd need before asserting anything on a pipeline page. If you look at the route /namespace/project/-/pipelines/:id/
we can determine we need a project and a pipeline.
So we'd create a project and pipeline, and link them together. Usually in factories, the child element requires its parent as an argument. In this case, a pipeline is a child of a project. So we can create the project first, and then when we create the pipeline, we are pass the project as an argument which "binds" the pipeline to the project. A pipeline is also owned by a user, so we need the user as well. For example, this creates a project and a pipeline:
let(:project) { create(:project, :repository) }
let(:pipeline) { create(:ci_pipeline, project: project, ref: 'master', sha: project.commit.id, user: user) }
In the same spirit, you could then create a job (build) by using the build factory and passing the parent pipeline:
create(:ci_build, pipeline: pipeline, stage_idx: 10, stage: 'publish', name: 'CentOS')
There are many factories that already exists, so make sure to look at other existing files to see if what you need is available.
Navigation
You can go to a page by using the visit
method and passing the path as an argument. Rails automatically generates helper paths, so make sure to use these instead of a hardcoded string. They are generated using the route model, so if we want to go to a pipeline, we'd use:
visit project_pipeline_path(project, pipeline)
Before executing any page interaction when navigating or making asynchronous call through the UI, make sure to use wait_for_requests
before proceeding with further instructions.
Elements interaction
There are a lot of different ways to find and interact with elements. For best practises, refer to the UI testing section.
To click a button, use click_button
with the string of text found in the button:
click_button 'Text inside the button element'
If you want to follow a link, then there is click_link
click_link 'Text inside the link tag'
You can use fill_in
to fill input / form elements. The first argument is the selector, the second is with:
which is the value to pass in.
fill_in 'current_password', with: '123devops'
Alternatively, you can use the find
selector paired with send_keys
to add keys in a field without removing previous text, or set
which completely replaces the value of the input element.
You can find a more comprehensive list of actions in the feature tests actions documentation.
Assertions
To assert anything in a page, you can always access page
variable, which is automatically defines and actually means the page document. This means you can expect the page
to have certain components like selectors or content. Here are a few examples:
# Finding a button
expect(page).to have_button('Submit review')
# Finding by text
expect(page).to have_text('build')
# Finding by `href` value
expect(page).to have_link(pipeline.ref)
# Find by data-testid
# Like CSS selector, this is acceptable when there isn't a specific matcher available.
expect(page).to have_css('[data-testid="pipeline-multi-actions-dropdown"]')
# Finding by CSS selector. This is a last resort.
# For example, when you cannot add attributes on the desired element.
expect(page).to have_css('.js-icon-retry')
# You can combine any of these selectors with `not_to` instead
expect(page).not_to have_button('Submit review')
# When a test case has back to back expectations,
# it is recommended to group them using `:aggregate_failures`
it 'shows the issue description and design references', :aggregate_failures do
expect(page).to have_text('The designs I mentioned')
expect(page).to have_link(design_tab_ref)
expect(page).to have_link(design_ref_a)
expect(page).to have_link(design_ref_b)
end
You can also create a sub-block to look into, to:
- Scope down where you are making your assertions and reduce the risk of finding another element that was not intended.
- Make sure an element is found within the right boundaries.
page.within('[data-testid="pipeline-multi-actions-dropdown"]') do
end
You can find a more comprehensive list of matchers in the feature tests matchers documentation.
Feature flags
By default, every feature flag is enabled regardless of the YAML definition or the flags you've set manually in your GDK. To test when a feature flag is disabled, you must manually stub the flag, ideally in a before do
block.
stub_feature_flags(my_feature_flag: false)
If you are stubbing an ee
feature flag, then use:
stub_licensed_features(my_feature_flag: false)
Asserting browser console errors
By default, feature specs won't fail if a browser console error is found. Sometimes we want to cover that there are not unexpected console errors which could indicate an integration problem.
To set a feature spec to fail if it encounters browser console errors, use expect_page_to_have_no_console_errors
from
the BrowserConsoleHelpers
support module:
after do
end
end
NOTE:
will not work on WEBDRIVER=firefox
. Logs are only captured when
using the Chrome driver.
Sometimes, there are known console errors that we want to ignore. To ignore a set of messages, such that the test
will not fail if the message is observed, you can pass an allow:
parameter to
after do
expect_page_to_have_no_console_errors(allow: [
"Blow up!",
/Foo.*happens/
end
end
Update the BROWSER_CONSOLE_ERROR_FILTER
constant in spec/support/helpers/browser_console_helpers.rb
to change
the list of console errors that should be globally ignored.
Debugging
You can run your spec with the prefix WEBDRIVER_HEADLESS=0
to open an actual browser. However, the specs goes though the commands quickly and leaves you no time to look around.
To avoid this problem, you can write binding.pry
on the line where you want Capybara to stop execution. You are then inside the browser with standard usage. To understand why you cannot find certain elements, you can:
- Select elements.
- Use the console and network tab.
- Execute selectors inside the browser console.
Inside the terminal, where capybara is running, you can also execute next
which goes line by line through the test. This way you can check every single interaction one by one to see what might be causing an issue.
Improving execution time on the GDK
Running the Jest test suite, the number of workers is set to use 60% of the available cores of your machine; this results in faster execution times but higher memory consumption. For more benchmarks on how this works please refer to this issue.
Updating ChromeDriver
Starting from Selenium
4.6, ChromeDriver can be automatically managed by Selenium Manager
which comes with the selenium-webdriver
gem.
You are no longer required to manually keeping chromedriver in sync.
