calc_e.f
1 ! TO DO:
2 ! Check the formulation based on MCp
3 !
4 !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvC
5 ! C
6 ! Subroutine: CALC_e_e C
7 ! Purpose: Calculate coefficients linking velocity correction to C
8 ! solids volume fraction correction -- East C
9 ! C
10 ! Author: M. Syamlal Date: 1-JUL-96 C
11 ! Reviewer: Date: C
12 ! C
13 ! Literature/Document References: C
14 ! Variables referenced: C
15 ! Variables modified: C
16 ! Local variables: C
17 ! C
18 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^C
19
20  SUBROUTINE calc_e_e(A_M, MCP, E_E)
21
22 !-----------------------------------------------
23 ! Modules
24 !-----------------------------------------------
25  USE param
26  USE param1
27  USE parallel
28  USE fldvar
29  USE geometry
30  USE indices
31  USE physprop
32  USE run
33  USE constant
34  USE compar
35  USE sendrecv
36  USE fun_avg
37  USE functions
38  IMPLICIT NONE
39 !-----------------------------------------------
40 ! Dummy arguments
41 !-----------------------------------------------
42 ! Septadiagonal matrix A_m
43  DOUBLE PRECISION, INTENT(IN) :: A_m(dimension_3, -3:3, 0:dimension_m)
44 ! Index of close packed solids phase. note mcp is the lowest index of
45 ! those solids phases that have close_packed=t and of the solids
46 ! phase that is used for the solids correction equation (when mmax=1).
47  INTEGER, INTENT(IN) :: Mcp
48 ! Coefficient for solids correction equation. These coefficients are
49 ! initialized to zero in the subroutine time_march before the time loop.
50 ! Note that the E_e coefficients are only used when mcp is assigned
51 ! (when any solids phase has close_packed=T).
52  DOUBLE PRECISION, INTENT(INOUT) :: e_e(dimension_3)
53 !-----------------------------------------------
54 ! Local variables
55 !-----------------------------------------------
56 ! Indices
57  INTEGER :: IJK
58 !-----------------------------------------------
59
60 ! returning if mcp is not defined.
61  IF (mcp == undefined_i) RETURN
62
63 ! returning if the x-momentum equation of this phase is not to be
64 ! solved.
65  IF (.NOT.momentum_x_eq(mcp)) RETURN
66
67 !!$omp parallel do private(ijk)
68  DO ijk = ijkstart3, ijkend3
69  IF (sip_at_e(ijk) .OR. mflow_at_e(ijk)) THEN
70  e_e(ijk) = zero
71  ELSE
72  IF (a_m(ijk,0,mcp) /= zero) THEN
73 ! calculating the correction coefficient
74  e_e(ijk) = ayz(ijk)/(-a_m(ijk,0,mcp))
75  ELSE
76  e_e(ijk) = large_number
77  ENDIF
78  ENDIF
79  ENDDO
80
81  RETURN
82  END SUBROUTINE calc_e_e
83
84 !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvC
85 ! C
86 ! Subroutine: CALC_e_n C
87 ! Purpose: Calculate coefficients linking velocity correction to C
88 ! solids volume fraction correction -- North C
89 ! C
90 ! Author: M. Syamlal Date: 1-JUL-96 C
91 ! Reviewer: Date: C
92 ! C
93 ! Literature/Document References: C
94 ! Variables referenced: C
95 ! Variables modified: C
96 ! Local variables: C
97 ! C
98 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^C
99
100  SUBROUTINE calc_e_n(A_M, MCP, E_N)
102 !-----------------------------------------------
103 ! Modules
104 !-----------------------------------------------
105  USE param
106  USE param1
107  USE parallel
108  USE fldvar
109  USE geometry
110  USE indices
111  USE physprop
112  USE run
113  USE constant
114  USE compar
115  USE sendrecv
116  USE fun_avg
117  USE functions
118  IMPLICIT NONE
119 !-----------------------------------------------
120 ! Dummy arguments
121 !-----------------------------------------------
122 ! Septadiagonal matrix A_m
123  DOUBLE PRECISION, INTENT(IN) :: A_m(dimension_3, -3:3, 0:dimension_m)
124 ! Index of close packed solids phase. note mcp is the lowest index of
125 ! those solids phases that have close_packed=t and of the solids
126 ! phase that is used for the solids correction equation (when mmax=1).
127  INTEGER, INTENT(IN) :: Mcp
128 ! Coefficient for solids correction equation. These coefficients are
129 ! initialized to zero in the subroutine time_march before the time loop.
130 ! Note that the E_n coefficients are only used when mcp is assigned
131 ! (when the solids phase has close_packed=T)
132  DOUBLE PRECISION, INTENT(INOUT) :: e_n(dimension_3)
133 !-----------------------------------------------
134 ! Local variables
135 !-----------------------------------------------
136 ! Indices
137  INTEGER :: IJK
138 !-----------------------------------------------
139
140 ! returning if mcp is not defined.
141  IF (mcp == undefined_i) RETURN
142 ! returning if the y-momentum equation of this phase is not to be
143 ! solved.
144  IF (.NOT.momentum_y_eq(mcp)) RETURN
145
146 !!$omp parallel do private(IJK)
147  DO ijk = ijkstart3, ijkend3
148  IF (sip_at_n(ijk) .OR. mflow_at_n(ijk)) THEN
149  e_n(ijk) = zero
150  ELSE
151  IF ((-a_m(ijk,0,mcp)) /= zero) THEN
152 ! calculating the correction coefficient
153  e_n(ijk) = axz(ijk)/(-a_m(ijk,0,mcp))
154  ELSE
155  e_n(ijk) = large_number
156  ENDIF
157  ENDIF
158  ENDDO
159
160  RETURN
161  END SUBROUTINE calc_e_n
162
163 !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvC
164 ! C
165 ! Subroutine: CALC_e_t C
166 ! Purpose: Calculate coefficients linking velocity correction to C
167 ! solids volume fraction correction -- Top C
168 ! C
169 ! Author: M. Syamlal Date: 1-JUL-96 C
170 ! Reviewer: Date: C
171 ! C
172 ! Literature/Document References: C
173 ! Variables referenced: C
174 ! Variables modified: C
175 ! Local variables: C
176 ! C
177 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^C
178
179  SUBROUTINE calc_e_t(A_M, MCP, E_T)
181 !-----------------------------------------------
182 ! Modules
183 !-----------------------------------------------
184  USE param
185  USE param1
186  USE parallel
187  USE fldvar
188  USE geometry
189  USE indices
190  USE physprop
191  USE run
192  USE constant
193  USE compar
194  USE sendrecv
195  USE fun_avg
196  USE functions
197  IMPLICIT NONE
198 !-----------------------------------------------
199 ! Dummy arguments
200 !-----------------------------------------------
201 ! Septadiagonal matrix A_m
202  DOUBLE PRECISION, INTENT(IN) :: A_m(dimension_3, -3:3, 0:dimension_m)
203 ! Index of close packed solids phase. note mcp is the lowest index of
204 ! those solids phases that have close_packed=t and of the solids
205 ! phase that is used for the solids correction equation (when mmax=1).
206  INTEGER, INTENT(IN) :: Mcp
207 ! Coefficient for solids correction equation. These coefficients are
208 ! initialized to zero in the subroutine time_march before the time loop.
209 ! Note that the E_t coefficients are only used when mcp is assigned
210 ! (when the solids phase has close_packed=T)
211  DOUBLE PRECISION, INTENT(INOUT) :: e_t(dimension_3)
212 !-----------------------------------------------
213 ! Local variables
214 !-----------------------------------------------
215 ! Indices
216  INTEGER :: IJK
217 !-----------------------------------------------
218
219 ! returning if mcp is not defined.
220  IF (mcp == undefined_i) RETURN
221 ! returning if the z-momentum equation of this phase is not to be
222 ! solved
223  IF (.NOT.momentum_z_eq(mcp)) RETURN
224
225 !!$omp parallel do private(IJK)
226  DO ijk = ijkstart3, ijkend3
227  IF (sip_at_t(ijk) .OR. mflow_at_t(ijk)) THEN
228  e_t(ijk) = zero
229  ELSE
230  IF ((-a_m(ijk,0,mcp)) /= zero) THEN
231 ! calculating the correction coefficient
232  e_t(ijk) = axy(ijk)/(-a_m(ijk,0,mcp))
233  ELSE
234  e_t(ijk) = large_number
235  ENDIF
236  ENDIF
237  ENDDO
238
239  RETURN
240  END SUBROUTINE calc_e_t
241
logical, dimension(0:dim_m) momentum_y_eq
Definition: run_mod.f:77
integer ijkend3
Definition: compar_mod.f:80
integer dimension_3
Definition: param_mod.f:11
logical, dimension(0:dim_m) momentum_x_eq
Definition: run_mod.f:74
logical, dimension(0:dim_m) momentum_z_eq
Definition: run_mod.f:80
subroutine calc_e_n(A_M, MCP, E_N)
Definition: calc_e.f:101
subroutine calc_e_t(A_M, MCP, E_T)
Definition: calc_e.f:180
Definition: geometry_mod.f:208
double precision, parameter large_number
Definition: param1_mod.f:23
Definition: param_mod.f:2
integer ijkstart3
Definition: param1_mod.f:19
subroutine calc_e_e(A_M, MCP, E_E)
Definition: calc_e.f:21
integer dimension_m
Definition: param_mod.f:18
