3.1. First Tutorial¶
It is also assumed that the terminal shell on Linux and Mac is bash. If
this is not the case, type bash at the prompt before activating the
environment.
3.1.1. Starting the MFiX GUI¶
On Windows, open the Anaconda Prompt and activate the mfix environment
On Linux open a terminal and activate the mfix environment from bash.
On macOS open a terminal and activate the mfix environment from bash.
# Windows
conda activate mfix-21.2
(mfix-21.2) C:\> mfix
# Linux or Mac
(mfix-21.2) > mfix
3.1.2. Creating a Project¶
(New)
Icon |
Single phase Model |
Two Fluid Model (TFM) |
Hybrid Model (TFM + DEM) |
Chemistry |
(single phase), and
(chemistry) icons
Double-click on
Click Ok
3.1.3. Running the Solver¶
(Start) button to open the Run Dialog.
[default]/mfixsolver
3.1.4. View results¶
VTKresults tab. The visibility and representation of the*.vtkfiles can be controlled with the menu on the side.Change frames with the
, and
buttons
section on the sidebar.
3.1.5. Pausing/Unpausing¶
stop timeto another value to have the solver run for a different amount of time.Click the
3.1.6. Stopping/Resuming¶
(stop) button to stop the solver.
Clicking the
(run) button to open the Run Dialog.
