3.6. Three Dimensional DEM Hopper¶
5 cm diameter hopper |
10 x 25 x 10 |
0.003 m |
NA |
NA |
3.6.1. Create a new project¶
Model
drop-down menuCheck the
Disable Fluid Solver (Pure Granular Flow)
check-box.
3.6.3. Enter the geometry¶
wizard menu and select the
hopper
wizardSelect
apply
to build the hopper stl filePress the
Autosize
button to fit the domain extents to the geometryPress the
3.6.4. Enter the mesh¶
pane, Background
25
for the y cell valueEnter
for the z cell value
pane, Mesher
0.0
in theFacet Angle Tolerance
Select the Regions
click the
name
such as “walls”Check the
Select Facets (STL)
check-box to turn the region into a STL region. The facets of the hopper should now be selected.
Y Min
domain extent value on the geometry pane by a small amount so that those facets fall outside the simulation domain (for example, change the value to-0.0974
).Change the
Y From
region extent value on the regions pane for this STL region by a small amount so that those facets fall outside the region (for example, change the value toymin+0.0001
)Or, use the
Filter facets based on normals
option on the region pane.
the Y
direction by:
box
from theSelection method
drop-down.Uncheck
Slice facets
.Check the
check-boxEnter a vector pointed in the positive
Y
direction by entering0
,1
, and0
in the x, y, z fields, respectivelyCheck the
Include equilibrant vector
to include facets with normals in the opposite direction of the vector (-x, -y, -z)Enter an angle of
in theangle
field to include facets with normals within 10 degrees of the filter vectorCheck the
Invert Selection
check box to de-select facets that fall along the filter vector and select all the other facets
field (“outlet”)
field (“solids”)Enter
ymin/3
in theFrom Y
fieldEnter
in theTo Y
3.6.6. Create a solid¶
pane
button to create a new solid
field (“solids”)Keep the model as “Discrete Element Model (MFiX-DEM)”)
0.003
2500
kg/m2 in theDensity
In the DEM
sub-pane, check Enable automatic particle generation
check-box
pane
button to create a new initial condition
Select Region
dialog, select the “solids” region and clickOK
solids
sub-pane, enter0.4
in theVolume fraction
the hopper by:
clicking the
Select Region
drop-down menuSelect the “walls” region and click
clicking the
Select Region
dialog, select “Pressure Outflow” from theBoundary type
3.6.9. Select output options¶
Output
paneOn the
checkbox
On the “select region” dialog, select “particle data” from the
output type
drop-down menuSelect the “Background IC” region from the list to save particle data over the entire domain
to0.01
secondsSelect the
Diameter
andTranslational velocity
check-boxes
Stop Time
to2.0
secondsChange the
to1e-3
secondsChange the
to1e-2
seconds
3.6.11. Run the project¶
Save project by clicking
Run
dialog, select the default solverClick the
Run
3.6.12. View results¶
