3.2. Two Dimensional Fluid Bed, Two Fluid Model (TFM)¶
This tutorial shows how to create a two dimensional fluidized bed simulation using the two fluid model. The model setup is:
10 cm x 30 cm |
20 x 60 |
0.25 m/s |
3.2.1. Create a new project¶
fig_new_project
): On the main menu selectNew project
(fig_model_param
): On the Model
drop-down menu.
3.2.3. Enter the geometry¶
2 Dimensional
checkboxEnter
10/100
30/100
meters for the maximum y value
3.2.4. Enter the mesh¶
pane, Background
20
60
for the y cell value
Select the Regions
visualize the results.
click the
button to create a new region to be used for the bed initial condition.
Color
buttonEnter
xmin
ormin
in theFrom X
fieldEnter
xmax
ormax
in theTo X
fieldEnter
ymin
ormin
in theFrom Y
fieldEnter
ymax/2
ormax/2
in theTo Y
fieldEnter
zmin
ormin
in theFrom Z
fieldEnter
zmax
ormax
in theTo Z
button to create a new region with the
From
andTo
fields already filled out for a region at the bottom of the domain, to be used by the gas inlet boundary condition.From Y
andTo Y
should equalymin
, defining an XZ-plane.Enter a name for the region in the
field (“inlet”)
From
andTo
fields already filled out for a region at the top of the domain, to be used by the pressure outlet boundary condition.From Y
andTo Y
should equalymax
field (“outlet”)
3.2.6. Create a solid¶
button to create a new solid
field (“glass beads”)Keep the model as “Two-Fluid Model (MFiX-TFM)”)
200e-6
2500
kg/m2 in theDensity
101325
Pa in thePressure (optional)
button.
0.4
in theVolume Fraction
Select Region
Y-axial velocity
field of “0.25” m/s
Select Region
dialog, select “Pressure Outflow” from theBoundary type
On the Numerics
pane, Residuals
in theFluid Normalization
field.
checkbox
to create the output
*.vtu
files in theFilename base
fieldChange the
to0.1
secondsSelect the
Volume fraction
,Pressure
, andVelocity vector
check-boxes on theFluid
sub-sub-pane
to1e-3
secondsChange the
to1e-2
seconds
3.2.12. Run the project¶
Save project by clicking the
Run Solver
Run
3.2.13. View results¶
3D view
Change frames with the
, and
buttons
section on the sidebar.
Mesh
pane, change theX Cells
to 80 and theY Cells
to 180On the
Output
pane,VTK
sub-pane, change the write interval to0.01
Save and run the project.
