3.9. DEM Initial Conditions¶
3.9.1. Open the 3d hopper tutorial¶
Double click on the “3D DEM granular flow hopper” tutorial and specify the project location.
3.9.2. Change the initial condition configuration¶
Initial conditions
pane, select the “initial solids” region.Change the Solid 1 volume fraction to 0.4. Note that we are using an hexagonal lattice.
Run
pane, changeStop time
to 0.001. We are only interested to look at the initial conditions.Run the simulation. Visualize the particles and take a look at the output in the console and verify that seeding was successful:
| IC Region: 2 |
Phase 1: Successful seeding
Initial conditions
pane, select the “initial solids” region.Change the lattice configuration to “Cubic”.
| IC Region: 2 |
Phase 1: Unsuccessful seeding
Initial conditions
pane, select the “initial solids” region.In the drop down menu, select “Inventory” and enter
100.0
.Run the simulation and verify seeding was successful.
Initial conditions
pane, select the “initial solids” region.In the drop down menu, select “Particle count” and enter
10000
Initial conditions
0.1
.Change the spacing to
0.5
, run the simulation and observe how particles are more spaced out.Change the random factor to
1.0
, run the simulation and observe how particles have randomly shifted from their lattice positions.
3.9.3. Particle size distribution¶
Initial conditions
pane, select the “initial solids region.Make sure the Solid 1 volume fraction is
0.1
, and the lattice isHexa
.Change the spacing back to
0.05
, and the random factor back to1.0
.In the Solids>DEM pane, Click the
Fig. 3.1 PSD table.¶
Define a Normal psd:
Name:
Normal (mean = 0.01 m)
(use a descriptive name).Distribution type:
Normal
Mean:
0.01
Standard deviation:
0.001
Minimum:
0.005
Maximum:
0.015
Plot from 0 to
0.020
Fig. 3.2 Normal PSD definition.¶
Plot the psd by clicking on
Plot distribution
. Verify the plot corresponds to the parameters.
Fig. 3.3 Normal PSD plot.¶
We now have a psd that we can use in initial or mass inlet boundary conditions.
Go to the
Initial condition
pane, go to the drop down menu under ‘Particle size distribution’ and select the psd we just defined,Normal (mean = 0.01 m)
.Run the simulation and visualize the particles.
Fig. 3.4 Example of a Custom file used to define a Particle Size Distribution.¶
Name:
Bimodal psd
Custom
Select file: Choose
bimodal_psd.txt
in the project directory.Click
Plot distribution
Fig. 3.5 Custom PSD.¶
0.02
, run the simulation and verify that we get a volume fraction of 0.1 (or near 0.1).While the simulation is running, we can visualize a histogram showing the particle size distribution. Open a new visualization viewport by clicking on the
Fig. 3.6 Opening a histogram view.¶
Fig. 3.7 Visualizing particle diameter histogram.¶
3.9.4. Reading initial particle data from a text file¶
We can read the initial particle data from a text file, called particle_input.dat
Below is an example of a particle_input.dat
file (the line number is shown on the left and it
not part of the data itself):
Lines 32-34: Data header
1 Version 2.0
3 Instructions:
19 Dimension: 3
20 Particles: 35361
25 Phase_ID: F 1
26 Diameter: T
27 Density: F 2500.0
28 Velocity: F 0.0 0.0 0.0
, and enter a data file particle count of35361
. An entry is required to maintain compatibility with the old format, but the value on line 20 of the version 2.0 file will actually be used.In the
Initial condition
pane, delete theInitial solids
initial condition.In the
Run
pane, set the stop time to 1.0 seconds.Run the simulation. You should see the initial configuration shown below:
Fig. 3.8 Example of a DEM initial condition using particle_input.dat version 2.0.¶
