3.5. Three Dimensional Fluidized Bed¶
This tutorial shows how to create a three dimensional fluidized bed simulation using the two fluid model and the discrete element model (DEM). The model setup is:
10 cm diameter x 40 cm |
20 x 60 x 20 |
0.25 m/s |
3.5.1. Create a new project¶
fig_new_project): On the main menu, selectNew projectCreate a new project by double-clicking on “Blank” template.
Solverdrop-down menu.
3.5.3. Enter the geometry¶
Add Geometrybutton ->Primitives->cylinder
40/100meters for the cylinder heightEnter
10/2/100meters for the cylinder radiusEnter
30for the cylinder resolutionPress the autosize button to fit the domain extents to the geometry
0.1meters. This will hang the stl file outside of the domain, allowing for a sharp and clean cut.Flip the normals by clicking the
button and selecting the
flip normalsfilter
3.5.4. Enter the mesh¶
On the Mesh pane:
Backgroundsub-pane
20for the x cell valueEnter
60for the y cell valueEnter
20for the z cell value
visualize the results.
ColorbuttonEnter
0in theTo Yfield
Namefield (“inlet”)
Namefield (“outlet”)
Namefield (“walls”)Click the
Select facetsbox. The region type should change from “box” to “STL”.
Namefield (“slice”)Enter
0in theFrom XandTo Xfields
3.5.6. Create a solid¶
On the Solids pane:
button to create a new solid
Namefield (“glass beads”)Accept the radial distribution setting (Carnahan-Starling)
101325Pa in thePressure (optional)fieldCreate a new Initial Condition by pressing the
Select the region created previously for the bed Initial Condition (“bed” region) and click the
OKbutton.Select the solid (named previously as “glass beads”) sub-pane and enter a volume fraction of
OKOn the
Fluidsub-pane, enter a velocity in theY-axial velocityfield of0.25m/sCreate another Boundary condition by clicking the
Select regiondialog, select “No Slip Wall” from theBoundary typecombo-boxSelect the “wall” region and click
Basicsub-pane, check theWrite VTK output files (VTU/VTP)checkboxSelect the
Volume fraction,Pressure, andVelocity vectorcheck-boxes on theFluidtabCreate another output by clicking the
Select the “Slice” region from the list to save all the cell data
Stop timeto1.0secondsChange the
3.5.12. Run the project¶
Save project by clicking
3.5.13. View results¶
Close the VTK window
Modelpane, change the solver toMFiX-DEMOn the
Meshpane, coarsen the grid to 15, 45, and 15 cells in the in the x, y, and z direction, respectfully.
Solidspane, change that particle diameter to5.0000e-03to get a more reasonable particle count for tutorial purposes.On the
Solidspane,DEMsub-pane: - check theEnable automatic particle generation- enter a value of15in theSearch grid partitions,KMAXfield.On the
Boundary Conditionspane, change theinletY-axial velocityto0.6m/sOn the
Boundary Conditionspane, delete thewallsboundary condition and re-add it to write the correct wall parameters for the DEM simulation.On the
Outputpane,VTKsub-pane:Delete the
allorBackground_ICoutputCreate a new output, change the
Output typetoParticle dataand select theBackground_ICregion.Change the write frequency to
0.01Select the
DiameterandTranslational Velocitydata
Run the simulation
