3.10. Procedural Geometry¶
3.10.1. Create a new project¶
On the main menu click on the
New button.
3.10.2. Create the geometry¶
First, create a cylinder:
Go to the Geometry pane:
Choose
Procedural > Cylinderas the geometry input (namedcylinder).
Radius =
0.05m, Height =0.225m, Resolution =20Start angle=
0deg, end angle =360deg, resolution =32Check the
Bottom capandTop capcheck boxes and set the resolution to5for both caps.
button.
Next, create a bend:
Choose
Procedural > Bendas the geometry input (named “bend”).Enter the bend’s parameters:
Front section: Radius =
0.02m, Length =0.05m, Resolution =10Back section: Radius =
0.05m, Length =0.25m, Resolution =20Bend section: Major radius =
0.075m, Minor radius =0.02m, Start angle=0deg, end angle =90deg, resolution =16Circumference: Start angle=
0deg, end angle =360deg, resolution =16Check the
Bottom capandTop capcheck boxes and set the resolution to3for both caps. Leave Offset =0
Select the bend (named
bend)Add a filter:
transformSet a Translation of
0.025m in the X-direction,0.15m in the Y-direction, and0.05m in the Z-direction.Rotate
-90deg in the Z-direction.
Select the cylinder (named
cylinder)While holding the
ctrlkey, select the transformed bend (namedtranform)Press the
button.
Next, create another bend:
Choose
Procedural > Bendas the geometry input (namedbend1).Enter the bend’s parameters:
0.02m, Length =0.1m, Resolution =10Back section: Radius =
0.02m, Length =0.1m, Resolution =10Bend section: Major radius =
0.05m, Minor radius =0.02m, Start angle=0deg, end angle =90deg, resolution =10Circumference: Start angle=
bend1)Add a filter:
-0.005m in the X-direction,0.25m in the Y-direction, and-0.05m in the Z-direction.Rotate
Combine the bend and the previous geometry (union):
Select the transformed bend (named
transform1)While holding the
ctrlkey, select the previous geometry (namedunion)Press the
button. This will create a new
union1geometry.
button.
edges, opacity to 1.0, check theShow normalsbox, set theScaleto 0.01, setcountto 10,000 (to show all normals).
union1geometry,Add a filter:
flip normals. Now the vectors point towards the fluid region. The tips of the arrows are not visible, but we can see the origin (shown as a dot at the center of each face).
button.
In
Domain extent, enter the following:X-direction: Min =
-0.055m, Max =0.055m.Y-direction: Min =
0.01m, Max =0.35m.Z-direction: Min =
-0.1m, Max =0.18m.
button.
Go to the Regions pane:
There is already a
Mass inflowin the Boundary type drop down menu.Enter a name for the region in the Name field (“top inlet”).
Mass inflowin the Boundary type drop down menu.Enter a name for the region in the Name field (“bottom inlet”).
Pressure outflowin theBoundary typedrop down menu.Enter a name for the region in the Name field (“outlet”).
Namefield (“wall”).Change the region color to green.
Select facets (STL)andflip_normals, useallfor the selection method. You should see that there are 4003 facets selected.
Leave the
Boundary typeasNone.Enter a name for the region in the
Namefield (“init bed”).Change the region color to black.
Set the Y-extent form
yminto0.15m.Save the project by clicking the
button.
3.10.5. Setup the mesh¶
15for the x cell value.Enter
35for the y cell value.Enter
30for the z cell value.
0.0deg. (The geometry unions have created elongated triangles we need to keep).Click
Generate.Look at the console output to verify the mesh generation completed successfully.
Color bytobc_id, - setStyletoedgesand opacity to1.0.The Boundary_Mesh should look like a closed surface with colors matching the boundary conditions regions.
After inspection, the mesh is deemed acceptable and we can move to setting up the simulation (Solver mode). Click Accept. This will unlock the Modeler tab.
3.10.6. Model settings¶
3.10.7. Regions settings¶
3.10.8. Fluid settings¶
Change Density to
3.10.9. Solids settings¶
button to create a new solid.
2700kg/m3 in theDensityfield.Select the
Enable automatic particle generationcheckbox.Keep all other settings at their default values.
3.10.10. Initial conditions settings¶
There is already a
Background ICregion that initializes the entire domain as stagnant air. We only need to add solids at the bottom.Create a new initial condition region by clicking the
button.
init bedregion, go to theSolid 1tab and enter0.5for the volume fraction.
3.10.11. Boundary conditions settings¶
top inletregion. In theSolids 1tab, enter0.2for the volume fraction and-0.2for the Y-axial velocity.Select the
bottom inletregion. Stay on theFluidtab, enter4.0for the Y-axial velocity.The outlet Boundary Conditions is already set to atmospheric pressure. No changes are needed.
3.10.12. Numerics settings¶
On the Numerics pane:
0.0and the fluid pressure correction scale factor to1.0On the Preconditioner tab, set the preconditioner to
Nonefor all equations.
3.10.13. Output settings¶
Basicsub-pane, check theWrite VTK output files (VTU/VTP)checkbox.Select the
button.
OKto create the output.Enter a base name for the
DiameterandTranslational Velocitycheck-boxes.
3.10.14. Run settings¶
Set
Stop timeto1.0.Set
Time stepto0.001.Set
3.10.15. Run the simulation¶
button.
3.10.16. View results¶
next to the Model tab.
, and
buttons.
section on the sidebar.
