11.1.3. Numerical Parameters¶
This section contains keywords for defining numerical parameters. Keywords
related to solving the governing equations (e.g., LEQ_IT, DISCRETIZE,
UR_FAC, etc.) are dimensioned for the ten types of equations:
Index |
Equation Type |
1 |
Gas Pressure |
2 |
Solids Volume Fraction |
3 |
Gas and Solids U Momentum Equation |
4 |
Gas and Solids V Momentum Equation |
5 |
Gas and Solids W Momentum Equation |
6 |
Gas and Solids Energy Equations (Temperature) |
7 |
Gas and Solids Species Mass Fractions |
8 |
Granular Temperature |
9 |
User-Defined Scalar and K-Epsilon Equation |
10 |
DES Diffusion Equation |
For example, LEQ_IT(3) = 10, specifies to use 10 iterations within the
linear equation solver for the U Momentum Equations (of type 3).
11.1.3.2. NORM_G¶
11.1.3.3. NORM_S¶
11.1.3.4. PPG_DEN¶
11.1.3.5. EPP_DEN¶
11.1.3.6. TOL_RESID¶
Maximum residual at convergence (Continuity + Momentum) [1.0d-3].
11.1.3.7. TOL_RESID_T¶
11.1.3.8. TOL_RESID_X¶
11.1.3.9. TOL_RESID_TH¶
11.1.3.10. TOL_RESID_SCALAR¶
11.1.3.11. TOL_RESID_K_EPSILON¶
11.1.3.12. TOL_DIVERGE¶
11.1.3.13. TOL_SUM_RESID_ABS¶
11.1.3.14. DETECT_STALL¶
Continue iterating if residuals stall. |
Reduce time step if residuals stall. |
11.1.3.15. LEQ_METHOD(EQUATION ID NUMBER)¶
SOR - Successive over-relaxation |
BiCGSTAB - Biconjugate gradient stabilized. |
GMRES - Generalized minimal residual method |
CG - Conjugate gradient |
11.1.3.16. LEQ_TOL(EQUATION ID NUMBER)¶
11.1.3.17. LEQ_IT(EQUATION ID NUMBER)¶
11.1.3.18. LEQ_SWEEP(EQUATION ID NUMBER)¶
(Red/Black Sweep, Send Receive) repeated twice |
(Sweep in I, Send Receive) repeated twice |
(Sweep in J, Send Receive) repeated twice |
(Sweep in K, Send Receive) repeated twice |
(All Sweep, Send Receive) repeated twice |
11.1.3.19. LEQ_PC(EQUATION ID NUMBER)¶
No preconditioner |
Line relaxation |
Diagonal Scaling |
11.1.3.20. UR_FAC(EQUATION ID NUMBER)¶
11.1.3.21. UR_F_GS¶
0 updates F_GS every time step
1 updates F_GS every iteration
11.1.3.22. UR_KTH_SML¶
11.1.3.23. DISCRETIZE(EQUATION ID NUMBER)¶
First-order upwinding. |
First-order upwinding (using down-wind factors). |
Smart. |
Superbee (recommended method). |
QUICKEST (does not work). |
ULTRA-QUICK. |
van Leer. |
MUSCL. |
minmod. |
Central (often unstable; useful for testing). |
11.1.3.24. DEF_COR¶
Use down-wind factor method (default). |
Use deferred correction method. |
11.1.3.25. CHI_SCHEME¶
Do not use the chi-scheme. |
Use the chi-scheme correction. |
11.1.3.26. CN_ON¶
Implicit Euler based temporal discretization scheme employed (first-order accurate in time). |
Two-step implicit Runge-Kutta method based temporal discretization scheme employed. This method should be second- order accurate in time excluding pressure terms and restart time step which are first-order accurate. However, as of 2015, testing shows that second-order accuracy is not observed. |
11.1.3.27. MAX_INLET_VEL_FAC¶
11.1.3.32. IS_SERIAL¶
Calculate dot-products more efficiently (Serial runs only.)
11.1.3.33. DIL_EP_S¶
11.1.3.34. ZERO_EP_S¶
11.1.3.35. ZERO_X_GS¶
11.1.3.36. TMIN¶
- Minimum temperature allowed in the system (K).
It is strongly encouraged to keep the default value of 250.0.
11.1.3.37. TMAX¶
- Maximum temperature allowed in the system (K).
It is strongly encouraged to keep the default value of 4000.0.
