11.1.14. UDF Control¶
11.1.14.1. CALL_USR¶
Call user-defined subroutines. |
Do NOT call user-defined subroutines. |
11.1.14.2. CALL_USR_SOURCE(EQUATION ID NUMBER)¶
Call user-defined source. |
MFIX default: No additional source. |
11.1.14.3. USR_ROG¶
Flag to use the User Defined Function, USR_PROP_ROg, in model/usr_prop.f for calculating the gas phase density, RO_g.
Call user-defined function. |
Use MFIX default calculation. |
11.1.14.4. USR_CPG¶
Flag to use the User Defined Function, USR_PROP_CPg, in model/usr_prop.f for calculating the gas phase constant pressure specific heat, C_pg.
11.1.14.5. USR_KG¶
Flag to use the User Defined Function, USR_PROP_Kg, in model/usr_prop.f for calculating the gas phase conductivity, K_g.
11.1.14.6. USR_DIFG¶
Flag to use the User Defined Function, USR_PROP_Difg, in model/usr_prop.f for calculating the gas phase diffusivity.
11.1.14.7. USR_MUG¶
Flag to use the User Defined Function, USR_PROP_Mug, in model/usr_prop.f for calculating the gas phase viscosity, Mu_g.
11.1.14.8. USR_ROS(PHASE)¶
Flag to use the User Defined Function, USR_PROP_ROs, in model/usr_prop.f for calculating the solids phase density, RO_s.
11.1.14.9. USR_CPS(PHASE)¶
Flag to use the User Defined Function, USR_PROP_CPs, in model/usr_prop.f for calculating the solids phase constant pressure specific heat, C_ps.
11.1.14.10. USR_KS(PHASE)¶
Flag to use the User Defined Function, USR_PROP_Ks, in model/usr_prop.f for calculating the solids phase conductivity, K_s.
11.1.14.11. USR_DIFS(PHASE)¶
Flag to use the User Defined Function, USR_PROP_Difs, in model/usr_prop.f for calculating the solids phase diffusivity, Dif_s.
11.1.14.12. USR_MUS(PHASE)¶
Flag to use the User Defined Function, USR_PROP_Mus, in model/usr_prop.f for calculating the solids phase viscosity, Mu_s; second viscosity, lambda_s; and pressure, P_s.
11.1.14.13. USR_GAMA(PHASE)¶
Flag to use the User Defined Function, USR_PROP_Gama, in model/usr_prop.f for calculating the gas-solids phase heat transfer coefficient, Gama_gs.
11.1.14.14. USR_FGS(PHASE)¶
Flag to use the User Defined Function, USR_PROP_Fgs, in model/usr_prop.f for calculating the gas-solids phase drag coefficient due to relative velocity differences, F_gs. Currently unavailable.
11.1.14.15. USR_FSS(PHASE)¶
\(1 \le Phase \le DIM{\_}LM\)
Flag to use the User Defined Function, USR_PROP_Fss, in model/usr_prop.f for calculating the solids-solids phase drag coefficient due to relative velocity differences, F_ss. Currently unavailable.
11.1.14.16. C(USER-DEFINED ID)¶
\(1 \le User-defined ID \le DIMENSION{\_}C\)
User defined constants.
11.1.14.17. C_NAME(USER-DEFINED ID)¶
11.1.14.18. USR_DT(USR)¶
\(1 \le USR \le 5\)
11.1.14.19. USR_X_W(USR)¶
\(1 \le USR \le 5\)
11.1.14.20. USR_X_E(USR)¶
\(1 \le USR \le 5\)
11.1.14.21. USR_Y_S(USR)¶
\(1 \le USR \le 5\)
11.1.14.22. USR_Y_N(USR)¶
\(1 \le USR \le 5\)
11.1.14.23. USR_Z_B(USR)¶
\(1 \le USR \le 5\)
11.1.14.24. USR_Z_T(USR)¶
\(1 \le USR \le 5\)
11.1.14.25. USR_I_W(USR)¶
\(1 \le USR \le 5\)
11.1.14.26. USR_I_E(USR)¶
\(1 \le USR \le 5\)
11.1.14.27. USR_J_S(USR)¶
\(1 \le USR \le 5\)
11.1.14.28. USR_J_N(USR)¶
\(1 \le USR \le 5\)
11.1.14.29. USR_K_B(USR)¶
\(1 \le USR \le 5\)
11.1.14.30. USR_K_T(USR)¶
\(1 \le USR \le 5\)
11.1.14.31. USR_TYPE(USR)¶
\(1 \le USR \le 5\)
11.1.14.32. USR_VAR(USR)¶
\(1 \le USR \le 5\)
- UDF hook:
Variable to be written in the user-defined output files.
11.1.14.33. USR_FORMAT(USR)¶
\(1 \le USR \le 5\)
- UDF hook:
Format for writing user-defined (ASCII) output file.
11.1.14.34. USR_EXT(USR)¶
\(1 \le USR \le 5\)
11.1.14.35. DES_USR_VAR_SIZE¶
