11.1.5. Two-Fluid Model¶
This section contains keywords relating to the Two-Fluid Model.
11.1.5.1. KT_TYPE¶
Solids phase stress model [Algebraic].
Granular energy algebraic formulation. |
Cao and Ahmadi (1995). Int. J. Multiphase Flow 21(6), 1203. |
Garzo and Dufty (1999). Phys. Rev. E 59(5), 5895. |
Garzo, Hrenya and Dufty (2007). Phys. Rev. E 76(3), 31304 |
Garzo, Tenneti, Subramaniam, Hrenya (2012). J.Fluid Mech. 712, 129. |
Iddir & Arastoopour (2005). AIChE J. 51(6), 1620 |
Lun et al (1984). J. Fluid Mech., 140, 223. |
Simonin (1996). VKI Lecture Series, 1996-2 |
11.1.5.2. FRICTION_MODEL¶
Only solids pressure |
Schaeffer friction model. 1987, Journal of Differential Equations 66, 19–50. |
Srivastava and Sundaresan friction model. 2003, Powder Technology 129(1-3):72-85 |
Guo-Boyce friction model, 2021. Proceedings of the National Academy of Sciences, 118 (35). |
11.1.5.3. BLENDING_FUNCTION¶
No blending |
Hyperbolic tangent function |
Scaled sigmodial function |
11.1.5.4. YU_STANDISH¶
Use the Yu-Standish correlation. |
Do not use the Yu-Standish correlation. |
11.1.5.5. FEDORS_LANDEL¶
Use the Fedors-Landel correlation. |
Do not use the Fedors-Landel correlation. |
11.1.5.6. RDF_TYPE¶
Carnahan, N.F. and Starling K.E., (1969). The Journal of Chemical Physics, Vol. 51(2):635-636. Only applies to monodisperse cases. |
Ma, D. and Ahmadi, G., (1986). The Journal of Chemical Physics, 84(6):3449. Only applies to monodisperse cases. |
Lebowitz, J.L. (1964) The Physical Review, A133, 895-899. Only applies to polydisperse cases. |
Iddir, H. Y., Modeling of the multiphase mixture of particles using the kinetic theory approach. Doctoral Dissertation, Illinois Institute of Technology, Chicago, Illinois, 2004, (chapter 2, equations 2-49 through 2-52.) Only applies to polydisperse cases. |
Mansoori, GA, Carnahan N.F., Starling, K.E. Leland, T.W. (1971). The Journal of Chemical Physics, Vol. 54:1523-1525. Only applies to polydisperse cases. |
van Wachem, B.G.M., Schouten, J.C., van den Bleek, C.M., Krishna, R. and Sinclair, J. L. (2001) AIChE Journal 47:1035–1051. Only applies to polydisperse cases. |
11.1.5.7. ADDED_MASS¶
11.1.5.8. M_AM¶
11.1.5.9. C_E¶
11.1.5.10. R_P(PHASE, PHASE)¶
\(1 \le Phase \le 2\)
11.1.5.11. E_W¶
11.1.5.12. PHIP¶
11.1.5.13. PHIP0¶
11.1.5.14. C_F¶
11.1.5.15. PHI¶
11.1.5.16. PHI_W¶
11.1.5.17. EPS_F_MIN¶
11.1.5.18. EP_S_MAX(PHASE)¶
11.1.5.19. SEGREGATION_SLOPE_COEFFICIENT¶
11.1.5.20. V_EX¶
Boyle-Massoudi stress is turned off. |
11.1.5.21. MU_S0(PHASE)¶
- kinetic theory calculations (granular_energy) are off, which
- frictional/plastic calculations are off, which means zero
LAMBDA_S = -2/3 MU_S0
11.1.5.22. DIF_S0(PHASE)¶
11.1.5.23. EP_STAR¶
11.1.5.24. CLOSE_PACKED(PHASE)¶
The phase forms a packed bed with void fraction EP_STAR. |
The phase can exceed close pack conditions so that it maybe behave like a liquid. |
11.1.5.25. JENKINS¶
Use standard boundary conditions. |
Use Jenkins small frictional boundary condition. |
