11.1.6. Discrete Element¶
11.1.6.1. Discrete Element - Common¶
11.1.6.1.1. PARTICLES¶
11.1.6.1.2. GENER_PART_CONFIG¶
Generate particle configuration based on the initial condition parameters. Data provided in the particle_input.dat file, if present, is ignored. |
Particle position and velocity data are provided in the particle_input.dat file. A runtime error occurs if this file is not provided. |
11.1.6.1.3. DES_ONEWAY_COUPLED¶
- Run one-way coupled simulations [default .FALSE.].
11.1.6.1.4. DES_INTG_METHOD¶
Time stepping scheme.
First-order Euler scheme. |
Second-order ADAMS_BASHFORTH scheme (DEM only) |
11.1.6.1.5. DESGRIDSEARCH_IMAX¶
11.1.6.1.6. DESGRIDSEARCH_JMAX¶
11.1.6.1.7. DESGRIDSEARCH_KMAX¶
11.1.6.1.8. DES_INTERP_SCHEME¶
Do not use interpolation. |
Interpolate to/from a particle’s position using the corners (nodes) of the fluid cells. This was the default behavior prior to version 2015-1. See Garg et al. (2012) Documentation of the open-source MFiX-DEM software for gas-solids flows. |
Divided Particle Volume Method: Information is interpolated to/from a particles position using a square filter of size DES_INTERP_WIDTH. |
Linear interpolation: Hat functions are used to distribute particle information. PIC only. |
11.1.6.1.9. DES_INTERP_WIDTH¶
11.1.6.1.10. DES_INTERP_ON¶
11.1.6.1.11. DES_INTERP_MEAN_FIELDS¶
11.1.6.1.12. DES_DIFFUSE_WIDTH¶
The DES diffusion equation is listed as equation type 10 in the Numerical parameters section.
11.1.6.1.13. DES_EXPLICITLY_COUPLED¶
11.1.6.2. Discrete Element Model¶
11.1.6.2.1. NFACTOR¶
11.1.6.2.2. NEIGHBOR_SEARCH_N¶
11.1.6.2.3. DES_NEIGHBOR_SEARCH¶
11.1.6.2.4. NEIGHBOR_SEARCH_RAD_RATIO¶
11.1.6.2.5. FACTOR_RLM¶
11.1.6.2.6. USE_VDH_DEM_MODEL¶
11.1.6.2.7. DES_COLL_MODEL¶
The Hertzian model. Requires: DES_ET_INPUT, DES_ET_WALL_INPUT, E_YOUNG, EW_YOUNG V_POISSON, VW_POISSON. |
11.1.6.2.8. KN¶
11.1.6.2.9. KT_FAC¶
11.1.6.2.10. KN_W¶
11.1.6.2.11. KT_W_FAC¶
11.1.6.2.12. MEW¶
11.1.6.2.14. MEW_R¶
11.1.6.2.15. MEW_RW¶
11.1.6.2.16. DES_EN_INPUT(INDEX)¶
11.1.6.2.17. DES_EN_WALL_INPUT(INDEX)¶
\(1 \le Index \le MMAX\)
11.1.6.2.18. DES_ET_INPUT(INDEX)¶
11.1.6.2.19. DES_ET_WALL_INPUT(INDEX)¶
11.1.6.2.20. DES_ETAT_FAC¶
11.1.6.2.21. DES_ETAT_W_FAC¶
11.1.6.2.22. EW_YOUNG¶
11.1.6.2.23. VW_POISSON¶
11.1.6.2.24. E_YOUNG(PHASE)¶
11.1.6.2.25. V_POISSON(PHASE)¶
11.1.6.2.28. HAMAKER_CONSTANT¶
11.1.6.2.29. WALL_HAMAKER_CONSTANT¶
11.1.6.2.30. VDW_OUTER_CUTOFF¶
11.1.6.2.31. VDW_INNER_CUTOFF¶
11.1.6.2.32. WALL_VDW_OUTER_CUTOFF¶
11.1.6.2.33. WALL_VDW_INNER_CUTOFF¶
11.1.6.2.34. ASPERITIES¶
11.1.6.2.35. DES_CONV_CORR¶
11.1.6.2.36. DES_MIN_COND_DIST¶
11.1.6.2.37. FLPC¶
11.1.6.2.38. DES_EM(PHASE)¶
Emissivity of solids phase.
11.1.6.2.39. E_YOUNG_ACTUAL(PHASE)¶
11.1.6.2.40. EW_YOUNG_ACTUAL¶
11.1.6.2.41. V_POISSON_ACTUAL(PHASE)¶
11.1.6.2.42. VW_POISSON_ACTUAL¶
11.1.6.2.43. MINIMIZE_DES_FACET_LIST¶
11.1.6.2.44. REMOVE_ROGUE_PARTICLES¶
Flag to remove rogue particles. A rogue particle is defined as a particle that goes out of the MFiX box outside of a defined pressure or mass outlet BC.
11.1.6.2.45. DTSOLID_FACTOR¶
11.1.6.2.46. DTSOLID_UPDATE_DT¶
11.1.6.2.47. DES_BUFF_RESIZE_FACTOR¶
11.1.6.2.48. DLB_DT¶
11.1.6.2.49. DLB_EGW¶
11.1.6.3. Particles in Cell¶
11.1.6.3.1. FRIC_EXP_PIC¶
11.1.6.3.2. PSFAC_FRIC_PIC¶
11.1.6.3.3. MPPIC_COEFF_EN1¶
11.1.6.3.4. FRIC_NON_SING_FAC¶
11.1.6.3.5. MPPIC_COEFF_EN_WALL¶
11.1.6.3.6. MPPIC_COEFF_ET_WALL¶
11.1.6.3.7. MPPIC_VELFAC_COEFF¶
11.1.6.3.8. PIC_CFL¶
11.1.6.3.9. PIC_CFL_PARCEL_FRACTION¶
11.1.6.3.10. PIC_CFL_CONTROL¶
11.1.6.3.11. PIC_COLLISION_DAMPING¶
11.1.6.3.12. PIC_CD_E¶
