11.1.1. Run control¶
11.1.1.1. RUN_NAME¶
required
11.1.1.4. UNITS¶
required
All input and output in SI units (kg, m, s, J). |
All input and output in CGS units (g, cm, s, cal). DEPRECATED. |
11.1.1.5. RUN_TYPE¶
required
Type of run.
A new run. There should be no .RES, .SPx, .OUT, or .LOG files in the run directory. |
Traditional restart. The run continues from the last time the .RES file was updated and new data is added to the SPx files. |
Start a new run with initial conditions from a .RES file created from another run. No other data files (SPx) should be in the run directory. |
11.1.1.9. DT¶
11.1.1.12. DT_FAC¶
The value must be less than or equal to 1.0.
A value of 1.0 keeps the time step constant which may help overcome initial non-convergence.
11.1.1.13. PERSISTENT_MODE¶
Force forward time-step when DT=DT_MIN and the maximum number of iterations are reached. |
Abort run when DT < DT_MIN. |
11.1.1.15. MOMENTUM_X_EQ(PHASE)¶
\(0 \le Phase \le 10\)
Solve X-momentum equations. |
The X velocity initial conditions persist throughout the simulation. |
11.1.1.16. MOMENTUM_Y_EQ(PHASE)¶
Solve Y-momentum equations. |
The Y velocity initial conditions persist throughout the simulation. |
11.1.1.17. MOMENTUM_Z_EQ(PHASE)¶
Solve Z-momentum equations. |
The Z velocity initial conditions persist throughout the simulation. |
11.1.1.18. JACKSON¶
Solve Jackson form of momentum equations. |
Default form. |
11.1.1.19. ISHII¶
Solve Ishii form of momentum equations. |
Default form. |
11.1.1.20. ENERGY_EQ¶
Solve energy equations.
Solve energy equations. |
Do not solve energy equations. |
11.1.1.21. SPECIES_EQ(PHASE)¶
Solve species equations. |
Do not solve species equations. |
11.1.1.22. TURBULENCE_MODEL¶
Numerical parameters (like underrelaxation) are the same as the ones for SCALAR (index = 9).
All walls must be defined (NSW, FSW or PSW) in order to use standard wall functions. If a user does not specify a wall type, the simulation will not contain the typical turbulent profile in wall-bounded flows.
No turbulence model. |
Turbulent length scale must be specified for the full domain using keyword IC_L_SCALE. |
K-epsilon turbulence model (for single-phase flow) using standard wall functions. |
11.1.1.23. MU_GMAX¶
11.1.1.24. DRAG_TYPE¶
Van der Hoef MA, Beetstra R, Kuipers JAM. (2005) Journal of Fluid Mechanics.528:233-254.
Beetstra, R., van der Hoef, M. A., Kuipers, J.A.M. (2007). AIChE Journal, 53:489-501.
Erratum (2007), AIChE Journal, Volume 53:3020
Syamlal M, OBrien TJ (1988). International Journal of Multiphase Flow 14:473-481. Two additional parameters may be specified: DRAG_C1, DRAG_D1 |
Ding J, Gidaspow D (1990). AIChE Journal 36:523-538 |
Lathouwers D, Bellan J (2000). Proceedings of the 2000 U.S. DOE Hydrogen Program Review NREL/CP-570-28890. |
Wen CY, Yu YH (1966). Chemical Engineering Progress Symposium Series 62:100-111. |
Hill RJ, Koch DL, Ladd JC (2001). Journal of Fluid Mechanics, 448: 213-241. and 448:243-278. |
Beetstra, van der Hoef, Kuipers (2007). Chemical Engineering Science 62:246-255 |
Tang, Peters, Kuipers, Kreibitzsch, & van der Hoef. AIChE J., 61(2), pp.688-698 (2015). |
Yin, X, Sundaresan, S. (2009). AIChE Journal 55:1352-1368 This model has a lubrication cutoff distance, LAM_HYS, that can be specified. (TFM only). |
Gao, X., Li, T., Sarkar, A., Lu, L., Rogers, W.A. Development and Validation of an Enhanced Filtered Drag Model for Simulating Gas-Solid Fluidization of Geldart A Particles in All Flow Regimes. Chemical Engineering Science, 184, 33-51, 2018. |
Sarkar, A., Milioli, F.E., Ozarkar, S., Li, T., Sun, X.,Sundaresan, S., 2016. Filtered sub-grid constitutive models for fluidized gas-particle flows constructed from 3-D simulations. Chem. Eng. Sci., 152, 443-456. |
Radl, S., Sundaresan, S., 2014. A drag model for filtered Euler-Lagrange simulations of clustered gas-particle suspensions. Chem. Eng. Sci., 117, 416-425. |
Tenneti, S., Garg, R., Subramaniam, S., 2011. Drag law for monodisperse gas solid systems using particle-resolved direct numerical simulation of flow past fixed assemblies of spheres. Int. J. Multiph. Flow, 37(9), 1072-1092. |
G.H. Ganser, A rational approach to drag prediction of spherical and nonspherical particles, Powder Technol. 77 (1993) 143-152. This model requires specification of a sphericity and a reference length (typically the bed diameter) |
Invoke user-defined drag law. (usr_drag.f) |
(TFM only). see GIDASPOW |
(TFM only). see GIDASPOW_BLEND |
(TFM only). see WEN_YU |
(TFM only). see KOCH_HILL |
11.1.1.25. DRAG_C1¶
11.1.1.26. DRAG_D1¶
11.1.1.27. LAM_HYS¶
11.1.1.28. SPHERICITY_DG¶
11.1.1.29. REF_LENGTH_DG¶
11.1.1.30. SUBGRID_TYPE¶
Subgrid models.
Igci, Y., Pannala, S., Benyahia, S., and Sundaresan S. (2012). Industrial & Engineering Chemistry Research, 2012, 51(4):2094-2103 |
Milioli, C.C., Milioli, F. E., Holloway, W., Agrawal, K. and Sundaresan, S. (2013). AIChE Journal, 59:3265-3275. |
11.1.1.31. FILTER_SIZE_RATIO¶
11.1.1.32. SUBGRID_WALL¶
Do not include wall correction. |
Include subgrid wall correction. |
11.1.1.33. MODEL_B¶
Use Model A. See J.X. Bouillard and R.W. Lyczkowski (1991), Powder Tech, 68:31-51. |
Use Model B. See Bouillard, J.X., Lyczkowski, R.W., Folga, S., Gidaspow, D., Berry, G.F. (1989). Canadian Journal of Chemical Engineering 67:218-229. |
11.1.1.34. NSCALAR¶
- The number of user-defined scalar transport equations
to solve.
11.1.1.35. PHASE4SCALAR(SCALAR EQUATION)¶
\(1 \le Scalar Equation \le 100\)
