11.1.16. Thermochemical Properties¶
polynomials). The directory model/thermochemical contains the database of Burcat and
the necessary thermo-chemical data from files in the following order:
mfix.datBURCAT.THRfile in the run directorymodel/thermochemical/BURCAT.THR
BURCAT.THR exactly; alternatively aliases can be defined for common species,
such as O2, in read_therm.f. See tests/thermo for a sample case that
accesses the database. The format of BURCAT.THR file resembles CHEMKIN
THERMO DATA.
\(a^1_H\) |
\(a^2_H\) |
\(a^3_H\) |
\(a^4_H\) |
\(a^4_H\) |
\(a^6_H\) |
\(a^7_H\) |
\(a^1_L\) |
\(a^2_L\) |
\(a^3_L\) |
\(a^4_L\) |
\(a^4_L\) |
\(a^4_L\) |
\(a^4_L\) |
\(\Delta H^{\circ}_f\) |
Instead, MFiX integrates \(C_p\) to determine changes in enthalpy. See
Burcat Introduction
document for more details, which is also included in the source,
model/thermochemical/intro.pdf.
Additional database comments:
A number of species in the database have a lower temperature limit of 300K which is 2 degrees above the reference temperature (298 K) used for formation enthalpy calculation. For those species MFiX relaxes the lower limit for \(C_p\) calculations to 298 K to enable heat of reaction calculation (see read_database.f).
The database reader is set up such that the database is read only if necessary.
