11.1.8. Solids Phase¶
11.1.8.1. SOLIDS_MODEL(PHASE)¶
Two-fluid model (continuum) |
Discrete element model |
Coarse-grained particle |
Multiphase particle-in-cell |
11.1.8.3. D_P0(PHASE)¶
Applies to Solids Model(s): TFM, DEM
11.1.8.4. RO_S0(PHASE)¶
11.1.8.5. X_S0(PHASE, SPECIES)¶
\(1 \le Species \le DIM{\_}N{\_}s\)
11.1.8.6. RO_XS0(PHASE, SPECIES)¶
11.1.8.7. INERT_SPECIES(PHASE)¶
11.1.8.8. DIL_INERT_X_VSD(PHASE)¶
11.1.8.9. DIL_FACTOR_VSD¶
11.1.8.10. K_S0(PHASE)¶
11.1.8.11. KS_MODEL(PHASE)¶
(TFM or DEM). K_s0 is set to 0 (no conduction). In DEM, calculations are skipped. |
(TFM only). K_s0 specifies a constant effective solids phase conductivity. |
(TFM only). K_s0 is set based on user defined function. |
(TFM only). K_s0 specifies the material conductivity. See Bauer, R. and Schlünder, E.U. (1978). Int. Chem. Eng. 18(2), 181. |
(DEM only). K_s0 specifies the material conductivity. See Musser, J. (2011), PhD Dissertation, WVU. Chapter 3 (3.6). |
11.1.8.12. C_PS0(PHASE)¶
11.1.8.13. MW_S(PHASE, SPECIES)¶
11.1.8.14. NMAX_S(PHASE)¶
11.1.8.15. SPECIES_S(PHASE, SPECIES)¶
11.1.8.16. SPECIES_ALIAS_S(PHASE, SPECIES)¶
11.1.8.17. CGP_STAT_WT(PHASE)¶
11.1.8.18. CGP_D_P0(PHASE)¶
