11.1.11. Internal Surface¶
11.1.11.13. IS_TYPE(IS)¶
Type of internal surface
No gas or solids flow through the surface. |
Gas flows through the surface with an additional resistance. Solids velocity through the surface is set to zero or to a user- specified fixed value (i.e., solids momentum equation for this direction is not solved). |
No gas or solids flow in the X direction. |
Gas flows in the Z direction with additional resistance. Solids velocity in the Z direction is set to zero or to a user- specified fixed value (i.e., solids momentum equation for this direction is not solved). |
No gas or solids flow in the Y direction. |
Gas flows in the Y direction with additional resistance. Solids velocity in the Y direction is set to zero or to a user- specified fixed value (i.e., solids momentum equation for this direction is not solved). |
No gas or solids flow in the Z direction. |
Arbitrary shaped internal surface defined by an STL file. Only visible to DEM particles or PIC parcels. The fluid phase doesn’t feel this stl internal surface. |
11.1.11.14. IS_PC(IS, IDX)¶
IDX=1: Permeability [1.0E32]
IDX=2: Inertial resistance coefficient [0.0]
11.1.11.15. IS_VEL_S(IS, PHASE)¶
