11.1.13. Output Control¶
11.1.13.1. RES_DT¶
required
11.1.13.2. RES_BACKUP_DT¶
11.1.13.4. SPX_DT(SP VALUE)¶
\(1 \le SP Value \le 11\)
SP1: void fraction (EP_G)
SP2: Gas pressure (P_G) and Solids pressure (P_star)
SP3: Gas velocity (U_G, V_G, W_G)
SP4: Solids velocity (U_S, V_S, W_S)
SP5: Solids bulk density (ROP_s)
SP6: Gas and solids temperature (T_G, T_S)
SP7: Gas and solids mass fractions (X_G, X_S)
SP8: Granular temperature (THETA_M)
SP9: User defined scalars (SCALAR)
SPA: Reaction Rates (ReactionRates)
SPB: Turbulence quantities (K_TURB_G, E_TURB_G)
11.1.13.5. NRR¶
11.1.13.6. OUT_DT¶
- Time interval at which standard output (.OUT) file is updated.
11.1.13.8. REPORT_SOLID_INVENTORY_DT¶
required
11.1.13.9. BREAKDOWN_SOLID_INVENTORY_BY_PHASE¶
required
11.1.13.11. FULL_LOG¶
- Display the residuals on the screen and provide
messages about convergence on the screen and in the .LOG file. XXX FIXME issues/1504
11.1.13.12. TSS_HDR¶
- Write header every TSS_HDR iterations on screen.
11.1.13.13. RESID_STRING(RESIDUAL INDEX)¶
\(1 \le Residual Index \le 8\)
Gas pressure |
Solids phase M pressure |
Gas density |
Solids phase M density |
Gas phase U-velocity |
Gas phase V-velocity |
Gas phase W-velocity |
Solids phase M U-velocity |
Solids phase M V-velocity |
Solids phase M W-velocity |
Gas temperature |
Solids phase M temperature |
Solids phase M granular temperature |
Gas phase species NN mass fraction |
Solids phase M species NN mass fraction |
K-Epsilon model residuals |
11.1.13.15. REPORT_NEG_DENSITY¶
Do not log negative density errors. |
Log negative density errors. |
11.1.13.16. REPORT_NEG_SPECIFICHEAT¶
Do not log zero or negative specific heat errors. |
Log zero or negative specific heat errors. |
11.1.13.17. REPORT_MASS_BALANCE_DT¶
11.1.13.18. PHIP_OUT_JJ¶
11.1.13.19. BDIST_IO¶
11.1.13.20. BSTART_WITH_ONE_RES¶
11.1.13.21. MONITOR_X_W(MONITOR)¶
\(1 \le Monitor \le DIMENSION{\_}MONITOR\)
11.1.13.22. MONITOR_X_E(MONITOR)¶
11.1.13.23. MONITOR_Y_S(MONITOR)¶
11.1.13.24. MONITOR_Y_N(MONITOR)¶
11.1.13.25. MONITOR_Z_B(MONITOR)¶
11.1.13.26. MONITOR_Z_T(MONITOR)¶
11.1.13.27. MONITOR_NAME(MONITOR)¶
11.1.13.28. MONITOR_DT(MONITOR)¶
11.1.13.29. MONITOR_TAVG_DT(MONITOR)¶
11.1.13.30. MONITOR_TAVG_START(MONITOR)¶
11.1.13.31. MONITOR_TAVG_RESET_DT(MONITOR)¶
11.1.13.32. MONITOR_TAVG_SS_TOL(MONITOR)¶
11.1.13.33. MONITOR_TAVG_SS_SPAN(MONITOR)¶
11.1.13.34. MONITOR_TYPE(MONITOR)¶
Data monitor type.
Point value |
Sum over region |
Minimum over region |
Maximum over region |
Arithmetic average over region |
Standard deviation over region |
Area-weighted average over surface |
Flow rate across surface |
Mass flow rate across surface |
Mass-weighted average over surface |
Volumetric flow rate over surface |
Volume integral |
Volume-weighted average |
Mass-weighted volume integral |
Mass-weighted volume average |
Sum over region |
Mass-weighted average over region |
Volume-weighted average over region |
Mass-weighted flow rate across surface |
Volume-weighted flow rate across surface |
11.1.13.35. MONITOR_EP_G(MONITOR)¶
11.1.13.36. MONITOR_RO_G(MONITOR)¶
11.1.13.37. MONITOR_P_G(MONITOR)¶
11.1.13.38. MONITOR_U_G(MONITOR)¶
11.1.13.39. MONITOR_V_G(MONITOR)¶
11.1.13.40. MONITOR_W_G(MONITOR)¶
11.1.13.41. MONITOR_T_G(MONITOR)¶
11.1.13.42. MONITOR_MW_MIX_G(MONITOR)¶
11.1.13.43. MONITOR_X_G(MONITOR, SPECIES)¶
\(1 \le Species \le 100\)
11.1.13.44. MONITOR_Y_G(MONITOR, SPECIES)¶
11.1.13.45. MONITOR_K_TURB_G(MONITOR)¶
11.1.13.46. MONITOR_E_TURB_G(MONITOR)¶
11.1.13.47. MONITOR_EP_S(MONITOR, PHASE)¶
11.1.13.48. MONITOR_U_S(MONITOR, PHASE)¶
11.1.13.49. MONITOR_V_S(MONITOR, PHASE)¶
11.1.13.50. MONITOR_W_S(MONITOR, PHASE)¶
11.1.13.51. MONITOR_ROP_S(MONITOR, PHASE)¶
11.1.13.52. MONITOR_RO_S(MONITOR, PHASE)¶
11.1.13.53. MONITOR_P_STAR(MONITOR)¶
11.1.13.54. MONITOR_P_S(MONITOR, PHASE)¶
11.1.13.55. MONITOR_T_S(MONITOR, PHASE)¶
11.1.13.56. MONITOR_X_S(MONITOR, PHASE, SPECIES)¶
11.1.13.57. MONITOR_THETA_M(MONITOR, PHASE)¶
11.1.13.58. MONITOR_SCALAR(MONITOR, SCALAR EQ.)¶
\(1 \le Scalar Eq. \le 100\)
Write scalar in region.
11.1.13.59. MONITOR_RRATE(MONITOR, RATE)¶
\(1 \le RATE \le NRRMAX\)
11.1.13.60. MONITOR_FLUID_RRATE(MONITOR, RATE)¶
- Write fluid reaction rates in region. This keyword replaces
11.1.13.61. MONITOR_DES_RRATE(MONITOR, RATE)¶
- Write particle/parcel reaction rates in region. Particle/parcel data
is converted to cell data.
11.1.13.62. MONITOR_PART_PHASE(MONITOR, PHASE)¶
11.1.13.63. MONITOR_RADIUS(MONITOR)¶
11.1.13.64. MONITOR_PMASS(MONITOR)¶
11.1.13.65. MONITOR_PCOUNT(MONITOR)¶
11.1.13.66. MONITOR_PVOL(MONITOR)¶
11.1.13.67. MONITOR_RO_P(MONITOR)¶
11.1.13.68. MONITOR_VEL_X(MONITOR)¶
11.1.13.69. MONITOR_VEL_Y(MONITOR)¶
11.1.13.70. MONITOR_VEL_Z(MONITOR)¶
11.1.13.71. MONITOR_ROT_X(MONITOR)¶
11.1.13.72. MONITOR_ROT_Y(MONITOR)¶
11.1.13.73. MONITOR_ROT_Z(MONITOR)¶
11.1.13.74. MONITOR_T_P(MONITOR)¶
11.1.13.75. MONITOR_X_P(MONITOR, SPECIES)¶
11.1.13.76. MONITOR_DES_USR_VAR(MONITOR, USR_VAR)¶
\(1 \le USR_VAR \le 100\)
Write des_usr_var in region.
11.1.13.77. MONITOR_PART_RRATE(MONITOR, RATE)¶
\(1 \le rate \le 100\)
11.1.13.78. MONITOR_PART_RESIDENCE_TIME(MONITOR)¶
11.1.13.79. WRITE_VTK_FILES¶
Do not write VTK files. If there are cut cells, they will not be displayed from the usual .res file |
Valid only if Cartesian_grid = .TRUE. |
11.1.13.80. TIME_DEPENDENT_FILENAME¶
The VTK file overwrites the previous file (recommended for steady-state computation). |
A sequential integer is appended to the VTK filenames as they are written to create a series of files (recommended for transient computation). |
11.1.13.81. VTK_DT(VTK)¶
\(1 \le VTK \le 100\)
11.1.13.82. VTK_T_START(VTK)¶
11.1.13.83. VTK_T_END(VTK)¶
11.1.13.84. VTK_DBG_FILE(VTK)¶
- When VTK_DBG_FILE is .TRUE., the VTK region file is only written
11.1.13.85. VTK_VAR(IDX)¶
\(1 \le IDX \le 20\)
Void fraction (EP_g) |
Gas pressure, solids pressure (P_g, P_star) |
Gas velocity (U_g, V_g, W_g) |
Solids velocity (U_s, V_s, W_s) |
Solids density (ROP_s) |
Gas and solids temperature (T_g, T_s) |
Gas and solids mass fractions (X_g, X_s) |
Granular temperature (Theta_m) |
Scalar |
Reaction rates |
K and Epsilon |
Vorticity magnitude and lambda_2 |
Grid Partition |
Boundary Condition ID |
Distance to wall |
DEM facet count |
DEM Neighboring facets |
Cell IJK index |
Cut face normal vector |
11.1.13.86. VTK_X_W(VTK)¶
11.1.13.87. VTK_X_E(VTK)¶
11.1.13.88. VTK_Y_S(VTK)¶
11.1.13.89. VTK_Y_N(VTK)¶
11.1.13.90. VTK_Z_B(VTK)¶
11.1.13.91. VTK_Z_T(VTK)¶
11.1.13.92. VTK_FILEBASE(VTK)¶
11.1.13.93. VTK_DATA(VTK)¶
Cell data (VTU file). |
Particle data (VTP file). |
Geometry data (STL file). |
Force chain data (VTP file). |
11.1.13.94. VTK_GEO(VTK, GEO)¶
\(1 \le GEO \le VTK{\_}GEO{\_}MAX\)
11.1.13.95. VTK_SELECT_MODE(VTK)¶
Select particles with centers inside the VTK region. |
Select particles that are entirely inside the VTK region. |
Select particles that are inside or intersect the edges of the VTK region. |
11.1.13.96. VTK_NXS(VTK)¶
11.1.13.97. VTK_NYS(VTK)¶
11.1.13.98. VTK_NZS(VTK)¶
11.1.13.99. VTK_SLICE_TOL(VTK)¶
11.1.13.100. VTK_EP_G(VTK)¶
11.1.13.101. VTK_RO_G(VTK)¶
11.1.13.102. VTK_P_G(VTK)¶
11.1.13.103. VTK_VEL_G(VTK)¶
11.1.13.104. VTK_U_G(VTK)¶
11.1.13.105. VTK_V_G(VTK)¶
11.1.13.106. VTK_W_G(VTK)¶
11.1.13.107. VTK_P_STAR(VTK)¶
11.1.13.108. VTK_P_S(VTK, PHASE)¶
11.1.13.109. VTK_VEL_S(VTK, PHASE)¶
11.1.13.110. VTK_U_S(VTK, PHASE)¶
11.1.13.111. VTK_V_S(VTK, PHASE)¶
11.1.13.112. VTK_W_S(VTK, PHASE)¶
11.1.13.113. VTK_ROP_S(VTK, PHASE)¶
11.1.13.114. VTK_RO_S(VTK, PHASE)¶
11.1.13.115. VTK_EP_S(VTK, PHASE)¶
11.1.13.116. VTK_T_G(VTK)¶
11.1.13.117. VTK_T_S(VTK, PHASE)¶
11.1.13.118. VTK_MW_MIX_G(VTK)¶
11.1.13.119. VTK_X_G(VTK, GAS SPECIES)¶
\(1 \le Gas Species \le DIM{\_}N{\_}g\)
11.1.13.120. VTK_Y_G(VTK, GAS SPECIES)¶
11.1.13.121. VTK_X_S(VTK, PHASE, SOLIDS SPECIES)¶
\(1 \le Solids Species \le DIM{\_}N{\_}s\)
11.1.13.122. VTK_THETA_M(VTK, PHASE)¶
11.1.13.123. VTK_SCALAR(VTK, SCALAR)¶
\(1 \le Scalar \le DIM{\_}scalar\)
11.1.13.124. VTK_RRATE(VTK, RATE)¶
\(1 \le rate \le nRRmax\)
11.1.13.125. VTK_RRATE_LABEL(VTK, RATE)¶
11.1.13.126. VTK_FLUID_RRATE(VTK, RATE)¶
11.1.13.127. VTK_DES_RRATE(VTK, RATE)¶
- Write Lagrangian (DEM, CGDEM, PIC) reaction rates in region. Particle/parcel data is
accumulated in fluid cells.
11.1.13.128. VTK_K_TURB_G(VTK)¶
11.1.13.129. VTK_E_TURB_G(VTK)¶
11.1.13.130. VTK_VORTICITY(VTK)¶
11.1.13.132. VTK_PARTITION(VTK)¶
11.1.13.133. VTK_BC_ID(VTK)¶
11.1.13.134. VTK_DWALL(VTK)¶
11.1.13.135. VTK_FACET_COUNT_DES(VTK)¶
11.1.13.136. VTK_NB_FACET_DES(VTK)¶
11.1.13.138. VTK_SCALAR_CC(VTK)¶
11.1.13.139. VTK_NORMAL(VTK)¶
11.1.13.140. VTK_DEBUG(VTK, IDX)¶
\(1 \le IDX \le 15\)
11.1.13.141. VTK_PART_DIAMETER(VTK)¶
11.1.13.142. VTK_PART_PHYSICAL_DIAMETER(VTK)¶
11.1.13.143. VTK_PART_CGP_STAT_WT(VTK)¶
11.1.13.144. VTK_PART_VEL(VTK)¶
11.1.13.145. VTK_PART_ANGULAR_VEL(VTK)¶
11.1.13.146. VTK_PART_ORIENTATION(VTK)¶
11.1.13.147. VTK_PART_USR_VAR(VTK, USR_VAR)¶
\(1 \le USR_VAR \le VTK{\_}PART{\_}USRmax\)
11.1.13.148. VTK_PART_TEMP(VTK)¶
11.1.13.149. VTK_PART_X_S(VTK, DES_SPECIES)¶
\(1 \le Des_species \le 100\)
11.1.13.150. VTK_PART_RRATE(VTK, RATE)¶
11.1.13.151. VTK_PART_DENSITY(VTK)¶
11.1.13.152. VTK_PART_COHESION(VTK)¶
11.1.13.153. VTK_PART_RANK(VTK)¶
11.1.13.154. VTK_PART_ID(VTK)¶
Write particle ID in region.
11.1.13.155. VTK_PART_RESIDENCE_TIME(VTK)¶
11.1.13.156. VTK_PART_PHASE_ID(VTK)¶
11.1.13.157. VTK_PART_PHASE(VTK, PHASE)¶
11.1.13.158. VTK_FCMAX_ONLY(VTK)¶
11.1.13.159. VTK_PART_COL_FORCE(VTK)¶
11.1.13.160. VTK_CUTCELL_ONLY(VTK)¶
11.1.13.161. FRAME(VTK)¶
11.1.13.162. VTU_DIR¶
- Directory where VTK files are stored. By default,
11.1.13.163. DES_REPORT_MASS_INTERP¶
11.1.13.164. PRINT_DES_DATA¶
Allows writing of discrete particle data to output files. Relevant to both granular and coupled simulations.
11.1.13.165. VTP_DIR¶
11.1.13.166. DES_OUTPUT_TYPE¶
ParaView formatted files (.vtp) |
Tecplot formatted files (.dat) |
11.1.13.167. DEBUG_DES¶
11.1.13.168. FOCUS_PARTICLE¶
11.1.13.169. WRITE_PART_OUT¶
11.1.13.170. PART_OUT_ZERO_VEL¶
11.1.13.171. PART_OUT_X_MIN¶
11.1.13.172. PART_OUT_X_MAX¶
11.1.13.173. PART_OUT_X_EXCLUDE¶
11.1.13.174. PART_OUT_Y_MIN¶
11.1.13.175. PART_OUT_Y_MAX¶
11.1.13.176. PART_OUT_Y_EXCLUDE¶
11.1.13.177. PART_OUT_Z_MIN¶
11.1.13.178. PART_OUT_Z_MAX¶
11.1.13.179. PART_OUT_Z_EXCLUDE¶
11.1.13.180. PART_OUT_PHASE(PHASE)¶
11.1.13.181. PART_OUT_DIAMETER_MIN¶
11.1.13.182. PART_OUT_DIAMETER_MAX¶
11.1.13.183. PART_OUT_DIAMETER_EXCLUDE¶
11.1.13.184. PART_OUT_DENSITY_MIN¶
11.1.13.185. PART_OUT_DENSITY_MAX¶
11.1.13.186. PART_OUT_DENSITY_EXCLUDE¶
11.1.13.187. PART_OUT_U_MIN¶
11.1.13.188. PART_OUT_U_MAX¶
11.1.13.189. PART_OUT_U_EXCLUDE¶
11.1.13.190. PART_OUT_V_MIN¶
11.1.13.191. PART_OUT_V_MAX¶
11.1.13.192. PART_OUT_V_EXCLUDE¶
11.1.13.193. PART_OUT_W_MIN¶
11.1.13.194. PART_OUT_W_MAX¶
11.1.13.195. PART_OUT_W_EXCLUDE¶
11.1.13.196. PART_OUT_TEMP_MIN¶
11.1.13.197. PART_OUT_TEMP_MAX¶
11.1.13.198. PART_OUT_TEMP_EXCLUDE¶
11.1.13.199. PART_OUT_X_S_MIN(INDEX)¶
\(1 \le Index \le 100\)
11.1.13.200. PART_OUT_X_S_MAX(INDEX)¶
11.1.13.201. PART_OUT_X_S_EXCLUDE(INDEX)¶
11.1.13.202. PART_OUT_USR_VAR_MIN(INDEX)¶
11.1.13.203. PART_OUT_USR_VAR_MAX(INDEX)¶
11.1.13.204. PART_OUT_USR_VAR_EXCLUDE(INDEX)¶
11.1.13.205. PART_IN_X_MIN¶
11.1.13.206. PART_IN_X_MAX¶
11.1.13.207. PART_IN_X_EXCLUDE¶
11.1.13.208. PART_IN_Y_MIN¶
11.1.13.209. PART_IN_Y_MAX¶
11.1.13.210. PART_IN_Y_EXCLUDE¶
11.1.13.211. PART_IN_Z_MIN¶
11.1.13.212. PART_IN_Z_MAX¶
11.1.13.213. PART_IN_Z_EXCLUDE¶
11.1.13.214. PART_IN_PHASE(PHASE)¶
11.1.13.215. PART_IN_DIAMETER_MIN¶
11.1.13.216. PART_IN_DIAMETER_MAX¶
11.1.13.217. PART_IN_DIAMETER_EXCLUDE¶
11.1.13.218. PART_IN_DENSITY_MIN¶
11.1.13.219. PART_IN_DENSITY_MAX¶
11.1.13.220. PART_IN_DENSITY_EXCLUDE¶
11.1.13.221. PART_IN_U_MIN¶
11.1.13.222. PART_IN_U_MAX¶
11.1.13.223. PART_IN_U_EXCLUDE¶
11.1.13.224. PART_IN_V_MIN¶
11.1.13.225. PART_IN_V_MAX¶
11.1.13.226. PART_IN_V_EXCLUDE¶
11.1.13.227. PART_IN_W_MIN¶
11.1.13.228. PART_IN_W_MAX¶
11.1.13.229. PART_IN_W_EXCLUDE¶
11.1.13.230. PART_IN_TEMP_MIN¶
11.1.13.231. PART_IN_TEMP_MAX¶
11.1.13.232. PART_IN_TEMP_EXCLUDE¶
11.1.13.233. PART_IN_X_S_MIN(INDEX)¶
11.1.13.234. PART_IN_X_S_MAX(INDEX)¶
11.1.13.235. PART_IN_X_S_EXCLUDE(INDEX)¶
11.1.13.236. PART_IN_USR_VAR_MIN(INDEX)¶
11.1.13.237. PART_IN_USR_VAR_MAX(INDEX)¶
11.1.13.238. PART_IN_USR_VAR_EXCLUDE(INDEX)¶
