11.1.14. UDF Control¶
11.1.14.1. CALL_USR¶
Call user-defined subroutines. |
Do NOT call user-defined subroutines. |
11.1.14.2. CALL_USR_SOURCE(EQUATION ID NUMBER)¶
Call user-defined source. |
MFIX default: No additional source. |
11.1.14.3. USR_ROG¶
Call user-defined function. |
Use MFIX default calculation. |
11.1.14.4. USR_CPG¶
11.1.14.5. USR_KG¶
11.1.14.6. USR_DIFG¶
11.1.14.7. USR_MUG¶
11.1.14.8. USR_ROS(PHASE)¶
11.1.14.9. USR_CPS(PHASE)¶
11.1.14.10. USR_KS(PHASE)¶
11.1.14.11. USR_DIFS(PHASE)¶
11.1.14.12. USR_MUS(PHASE)¶
11.1.14.13. USR_GAMA(PHASE)¶
11.1.14.14. USR_FGS(PHASE)¶
11.1.14.15. USR_FSS(PHASE)¶
11.1.14.17. C_NAME(USER-DEFINED ID)¶
11.1.14.18. USR_DT(USR)¶
11.1.14.19. USR_X_W(USR)¶
11.1.14.20. USR_X_E(USR)¶
11.1.14.21. USR_Y_S(USR)¶
11.1.14.22. USR_Y_N(USR)¶
11.1.14.23. USR_Z_B(USR)¶
11.1.14.24. USR_Z_T(USR)¶
11.1.14.31. USR_TYPE(USR)¶
11.1.14.32. USR_VAR(USR)¶
- UDF hook:
Variable to be written in the user-defined output files.
11.1.14.33. USR_FORMAT(USR)¶
- UDF hook:
Format for writing user-defined (ASCII) output file.
11.1.14.34. USR_EXT(USR)¶
11.1.14.35. DES_USR_VAR_SIZE¶
