12.1.16. Thermochemical Properties¶
polynomials). The directory model/thermochemical
contains the database of Burcat and
the necessary thermo-chemical data from files in the following order:
mfix.dat
BURCAT.THR
file in the run directorymodel/thermochemical/BURCAT.THR
BURCAT.THR
exactly; alternatively aliases can be defined for common species,
such as O2, in read_therm.f. See tests/thermo
for a sample case that
accesses the database. The format of BURCAT.THR
file resembles CHEMKIN
THERMO DATA.
Each entry in the database starts with a unique CAS identifier (74-82-8) for the
species, followed by several lines of comments highlighted in green. The data
section starts with the species name in columns 1-18 (CH4 RRHO). Common species
names may be followed by strings (RRHO) that identify the method used to
determine the coefficients. Additional information follows the species name. The
numbers toward the end of the line are the temperature limits (200.000 6000.000)
in degrees Kelvin where the property calculation is valid and the molecular
weight (16.04246). Unlike CHEMKIN the common temperature for the high and low
temperature branches are not recorded; it is always 1000 K. The next three lines
give the fourteen coefficients (seven coefficients each for the high and low
temperature branches) and the formation enthalpy at 298 K (which is also not
included in CHEMKIN format). All the coefficients and the enthalpy of formation
are normalized with the gas constant R (cal/mol/K). The low temperature
coefficients (
where
The coefficients
Instead, MFiX integrates model/thermochemical/intro.pdf
Additional database comments:
A number of species in the database have a lower temperature limit of 300K which is 2 degrees above the reference temperature (298 K) used for formation enthalpy calculation. For those species MFiX relaxes the lower limit for
calculations to 298 K to enable heat of reaction calculation (see read_database.f). The database reader is set up such that the database is read only if necessary.
