12.1.14. UDF Control
12.1.14.1. CALL_USR
Table 12.74 Valid Values
Call user-defined subroutines.
Do NOT call user-defined subroutines.
12.1.14.2. CALL_USR_SOURCE(EQUATION ID NUMBER)
  • 1EquationIDNumber10
Table 12.75 Valid Values
Call user-defined source.
MFIX default: No additional source.
12.1.14.3. USR_ROG
Table 12.76 Valid Values
Call user-defined function.
Use MFIX default calculation.
12.1.14.4. USR_CPG
Table 12.77 Valid Values
12.1.14.5. USR_KG
Table 12.78 Valid Values
12.1.14.6. USR_DIFG
Table 12.79 Valid Values
12.1.14.7. USR_MUG
Table 12.80 Valid Values
12.1.14.8. USR_ROS(PHASE)
  • 1Phase10
Table 12.81 Valid Values
12.1.14.9. USR_CPS(PHASE)
  • 1Phase10
Table 12.82 Valid Values
12.1.14.10. USR_KS(PHASE)
  • 1Phase10
Table 12.83 Valid Values
12.1.14.11. USR_DIFS(PHASE)
  • 1Phase10
Table 12.84 Valid Values
12.1.14.12. USR_MUS(PHASE)
  • 1Phase10
Table 12.85 Valid Values
12.1.14.13. USR_GAMA(PHASE)
  • 1Phase10
Table 12.86 Valid Values
12.1.14.14. USR_FGS(PHASE)
  • 1Phase10
Table 12.87 Valid Values
12.1.14.15. USR_FSS(PHASE)
  • 1PhaseDIM_LM
Table 12.88 Valid Values
12.1.14.16. C(USER-DEFINED ID)
  • 1UserdefinedIDDIMENSION_C
User defined constants.
12.1.14.17. C_NAME(USER-DEFINED ID)
12.1.14.18. USR_DT(USR)
  • 1USR5
12.1.14.19. USR_X_W(USR)
  • 1USR5
12.1.14.20. USR_X_E(USR)
  • 1USR5
12.1.14.21. USR_Y_S(USR)
  • 1USR5
12.1.14.22. USR_Y_N(USR)
  • 1USR5
12.1.14.23. USR_Z_B(USR)
  • 1USR5
12.1.14.24. USR_Z_T(USR)
  • 1USR5
12.1.14.25. USR_I_W(USR)
  • 1USR5
12.1.14.26. USR_I_E(USR)
  • 1USR5
12.1.14.27. USR_J_S(USR)
  • 1USR5
12.1.14.28. USR_J_N(USR)
  • 1USR5
12.1.14.29. USR_K_B(USR)
  • 1USR5
12.1.14.30. USR_K_T(USR)
  • 1USR5
12.1.14.31. USR_TYPE(USR)
  • 1USR5
12.1.14.32. USR_VAR(USR)
  • 1USR5
UDF hook:
Variable to be written in the user-defined output files.
12.1.14.33. USR_FORMAT(USR)
  • 1USR5
UDF hook:
Format for writing user-defined (ASCII) output file.
12.1.14.34. USR_EXT(USR)
  • 1USR5
12.1.14.35. DES_USR_VAR_SIZE
