12.1.15. Chemical Reactions¶
12.1.15.1. STIFF_CHEMISTRY¶
Flag to use stiff chemistry solver (Direct integration).
12.1.15.2. STIFF_CHEM_MAX_STEPS¶
12.1.15.3. STIFF_CHEM_ABS_TOL¶
12.1.15.4. STIFF_CHEM_REL_TOL¶
12.1.15.5. STIFF_CHEM_MIN_RATE¶
Stiff chemistry minimum fluid reaction rate. If all fluid reaction rates are below this threshold, a cell is said to be non-reactive and no ODE is set for this cell.
12.1.15.6. STIFF_CHEM_MIN_RATE_DPM¶
- Stiff chemistry minimum DPM (Discrete phase model) reaction rate. If all DPM reaction
rates are below this threshold, a particle/parcel is said to be non-reactive and no ODE is set for this particle/parcel.
12.1.15.7. STIFF_CHEM_MIN_SPECIES¶
Stiff chemistry minimum species mass fraction. Reactions are switched off when reactants fall below this threshold.
12.1.15.8. USE_RRATES¶
12.1.15.9. SPECIES_NAME(PHASE)¶
12.1.15.10. NMAX(PHASE)¶
