12.1.1. Run control¶
12.1.1.1. RUN_NAME¶
required
12.1.1.2. DESCRIPTION¶
12.1.1.3. PROJECT_VERSION¶
12.1.1.4. UNITS¶
required
All input and output in SI units (kg, m, s, J). |
All input and output in CGS units (g, cm, s, cal). DEPRECATED. |
12.1.1.5. RUN_TYPE¶
required
Type of run.
A new run. There should be no .RES, .SPx, .OUT, or .LOG files in the run directory. |
Traditional restart. The run continues from the last time the .RES file was updated and new data is added to the SPx files. |
Start a new run with initial conditions from a .RES file created from another run. No other data files (SPx) should be in the run directory. |
12.1.1.6. PPO¶
Flag to run the preprocessing (mesh generation) only and exit.
12.1.1.7. TIME¶
12.1.1.8. TSTOP¶
Simulation stop time.
12.1.1.9. OPTFLAG1¶
Use NREL-CU optimization routines?.
12.1.1.10. NICE_DT¶
Flag to use nice time step value.
12.1.1.11. DT¶
12.1.1.12. DT_MAX¶
Maximum time step size.
12.1.1.13. DT_MIN¶
Minimum time step size.
12.1.1.14. DT_FAC¶
The value must be less than or equal to 1.0.
A value of 1.0 keeps the time step constant which may help overcome initial non-convergence.
12.1.1.15. PERSISTENT_MODE¶
Force forward time-step when DT=DT_MIN and the maximum number of iterations are reached. |
Abort run when DT < DT_MIN. |
12.1.1.16. AUTO_RESTART¶
12.1.1.17. MOMENTUM_X_EQ(PHASE)¶
\(0 \le Phase \le 10\)
Solve X-momentum equations. |
The X velocity initial conditions persist throughout the simulation. |
12.1.1.18. MOMENTUM_Y_EQ(PHASE)¶
Solve Y-momentum equations. |
The Y velocity initial conditions persist throughout the simulation. |
12.1.1.19. MOMENTUM_Z_EQ(PHASE)¶
Solve Z-momentum equations. |
The Z velocity initial conditions persist throughout the simulation. |
12.1.1.20. JACKSON¶
Solve Jackson form of momentum equations. |
Default form. |
12.1.1.21. ISHII¶
Solve Ishii form of momentum equations. |
Default form. |
12.1.1.22. ENERGY_EQ¶
Solve energy equations.
Solve energy equations. |
Do not solve energy equations. |
12.1.1.23. SPECIES_EQ(PHASE)¶
Solve species equations. |
Do not solve species equations. |
12.1.1.24. TURBULENCE_MODEL¶
Numerical parameters (like underrelaxation) are the same as the ones for SCALAR (index = 9).
All walls must be defined (NSW, FSW or PSW) in order to use standard wall functions. If a user does not specify a wall type, the simulation will not contain the typical turbulent profile in wall-bounded flows.
No turbulence model. |
Turbulent length scale must be specified for the full domain using keyword IC_L_SCALE. |
K-epsilon turbulence model (for single-phase flow) using standard wall functions. |
12.1.1.25. MU_GMAX¶
12.1.1.26. DRAG_TYPE¶
Van der Hoef MA, Beetstra R, Kuipers JAM. (2005) Journal of Fluid Mechanics.528:233-254.
Beetstra, R., van der Hoef, M. A., Kuipers, J.A.M. (2007). AIChE Journal, 53:489-501.
Erratum (2007), AIChE Journal, Volume 53:3020
Beetstra, van der Hoef, Kuipers (2007). Chemical Engineering Science 62:246-255 |
G.H. Ganser, A rational approach to drag prediction of spherical and nonspherical particles, Powder Technol. 77 (1993) 143-152. This model requires specification of a sphericity and a reference length (typically the bed diameter) |
Gao, X., Li, T., Sarkar, A., Lu, L., Rogers, W.A. Development and Validation of an Enhanced Filtered Drag Model for Simulating Gas-Solid Fluidization of Geldart A Particles in All Flow Regimes. Chemical Engineering Science, 184, 33-51, 2018. |
Ding J, Gidaspow D (1990). AIChE Journal 36:523-538 |
(TFM only). see GIDASPOW |
Lathouwers D, Bellan J (2000). Proceedings of the 2000 U.S. DOE Hydrogen Program Review NREL/CP-570-28890. |
(TFM only). see GIDASPOW_BLEND |
Yin, X, Sundaresan, S. (2009). AIChE Journal 55:1352-1368 This model has a lubrication cutoff distance, LAM_HYS, that can be specified. (TFM only). |
Hill RJ, Koch DL, Ladd JC (2001). Journal of Fluid Mechanics, 448: 213-241. and 448:243-278. |
(TFM only). see KOCH_HILL |
Radl, S., Sundaresan, S., 2014. A drag model for filtered Euler-Lagrange simulations of clustered gas-particle suspensions. Chem. Eng. Sci., 117, 416-425. |
Sarkar, A., Milioli, F.E., Ozarkar, S., Li, T., Sun, X.,Sundaresan, S., 2016. Filtered sub-grid constitutive models for fluidized gas-particle flows constructed from 3-D simulations. Chem. Eng. Sci., 152, 443-456. |
Xi Gao, Jia Yu, Liqiang Lu, Cheng Li and William A Rogers, Development and validation of SuperDEM-CFD coupled model for simulating non-spherical particles hydrodynamics in fluidized beds, Chemical Engineering Journal, 2021,420: 127654. and G.H. Ganser, A rational approach to drag prediction of spherical and nonspherical particles, Powder Technol. 77 (1993) 143-152. This model requires specification of a sphericity and a reference length (typically the bed diameter) |
Xi Gao, Jia Yu, Liqiang Lu, Cheng Li and William A Rogers, Development and validation of SuperDEM-CFD coupled model for simulating non-spherical particles hydrodynamics in fluidized beds, Chemical Engineering Journal, 2021,420: 127654. and A. Hölzer, M. Sommerfeld, New simple correlation formula for the drag coefficient of nonspherical particles, Powder Technology 184 (2008) 361-365. |
Syamlal M, OBrien TJ (1988). International Journal of Multiphase Flow 14:473-481. Two additional parameters may be specified: DRAG_C1, DRAG_D1 |
Wen CY, Yu YH (1966). Chemical Engineering Progress Symposium Series 62:100-111. |
Tenneti, S., Garg, R., Subramaniam, S., 2011. Drag law for monodisperse gas solid systems using particle-resolved direct numerical simulation of flow past fixed assemblies of spheres. Int. J. Multiph. Flow, 37(9), 1072-1092. |
Tang, Peters, Kuipers, Kreibitzsch, & van der Hoef. AIChE J., 61(2), pp.688-698 (2015). |
(TFM only). see WEN_YU |
Invoke user-defined drag law. (usr_drag.f) |
12.1.1.27. DRAG_C1¶
12.1.1.28. DRAG_D1¶
12.1.1.29. LAM_HYS¶
12.1.1.30. SPHERICITY_DG¶
12.1.1.31. REF_LENGTH_DG¶
12.1.1.32. SUBGRID_TYPE¶
Subgrid models.
Igci, Y., Pannala, S., Benyahia, S., and Sundaresan S. (2012). Industrial & Engineering Chemistry Research, 2012, 51(4):2094-2103 |
Milioli, C.C., Milioli, F. E., Holloway, W., Agrawal, K. and Sundaresan, S. (2013). AIChE Journal, 59:3265-3275. |
12.1.1.33. FILTER_SIZE_RATIO¶
12.1.1.34. SUBGRID_WALL¶
Do not include wall correction. |
Include subgrid wall correction. |
12.1.1.35. MODEL_B¶
Use Model A. See J.X. Bouillard and R.W. Lyczkowski (1991), Powder Tech, 68:31-51. |
Use Model B. See Bouillard, J.X., Lyczkowski, R.W., Folga, S., Gidaspow, D., Berry, G.F. (1989). Canadian Journal of Chemical Engineering 67:218-229. |
12.1.1.36. NSCALAR¶
- The number of user-defined scalar transport equations
to solve.
12.1.1.37. PHASE4SCALAR(SCALAR EQUATION)¶
\(1 \le Scalar Equation \le 100\)
12.1.1.38. KEYFRAME(KEYFRAME FILE ID)¶
\(1 \le Keyframe file ID \le 100\)
Read a keyframe data file. Example: KEYFRAME(3) = .TRUE. will read the keyframe file keyframe_0003.csv. The first column of keyframe_0003.csv stores the independent variable. The next columns of keyframe_0003.csv store the dependent variables.
Read keyframe data file. |
Do not read keyframe data file. |
12.1.1.39. KF_KEYWORD(KEYFRAME FILE ID, COLUMN NUMBER IN CSV KEYFRAME FILE)¶
\(1 \le Column number in CSV keyframe file \le 20\)
Name of keyword controlled by a Keyframe datafile. Example: KF_KEYWORD(3,1)=’bc_v_g’ First index (3) means the keyframe data file is keyframe_0003.csv. Second index (1) means the first dependent variable (second column) controls keyword bc_v_g. See documentation for list of keywords that can be controlled by a keyframe.
12.1.1.40. KF_IV(KEYFRAME FILE ID)¶
Dependent variable identifier for a Keyframe datafile. Example: KF_IV(3)=0 Means the first column (independent variable) of keyframe data file keyframe_0003.csv represents time.
Keyframe file dependent variable is time. |
Keyframe file dependent variable is x-coordinate. |
Keyframe file dependent variable is y-coordinate. |
Keyframe file dependent variable is z-coordinate. |
12.1.1.41. KF_INTERP(KEYFRAME FILE ID)¶
Keyframe interpolation method (applies to all variables in a Keyframe datafile. Example: KF_INTERP(3)=’LINEAR’ First index (3) means the keyframe data file is keyframe_0003.csv.
Linearly interpolate data between keyframes (default). |
Keep data constant between keyframes. |
12.1.1.42. OMEGA_UNIT¶
Angular velocity unit. This is only meant to be used for granular DEM, CGP, SQP or GSP models to move STL files or group of particles. Example: OMEGA_UNIT = ‘REV/S’ means the angular velocity is expressed in revolutions per second.
Radian per second |
Degree per second |
Revolution per second |
Radian per minute |
Degree per minute |
Revolution per minute |
12.1.1.43. DES_RIGID_MOTION(PHASE)¶
Prescribe rigid body motion to particles belonging to this phase. Default value is .FALSE., meaning the particle motion is computed by integrating acceleration to velocity and velocity to position.
12.1.1.44. DES_RIGID_MOTION_VEL(PHASE, COMPONENT)¶
\(1 \le Component \le 3\)
Particle rigid motion translational velocity. The first index is the phase ID, the second index is the component (1=x, 2=y, 3=z)
12.1.1.45. DES_RIGID_MOTION_OMEGA(PHASE, COMPONENT)¶
Particle rigid motion angular velocity. The first index is the phase ID, the second index is the component (1=x, 2=y, 3=z)
12.1.1.46. DES_RIGID_MOTION_ROT_CENTER(PHASE, COMPONENT)¶
Particle rigid motion center of rotation. The first index is the phase ID, the second index is the component (1=x, 2=y, 3=z)
