12.1.11. Internal Surface¶
12.1.11.1. IS_X_W(IS)¶
\(1 \le IS \le 500\)
12.1.11.2. IS_X_E(IS)¶
12.1.11.3. IS_Y_S(IS)¶
12.1.11.4. IS_Y_N(IS)¶
12.1.11.5. IS_Z_B(IS)¶
12.1.11.6. IS_Z_T(IS)¶
12.1.11.7. IS_I_W(IS)¶
12.1.11.8. IS_I_E(IS)¶
I index of the east-most cell
12.1.11.9. IS_J_S(IS)¶
J index of the south-most cell
12.1.11.10. IS_J_N(IS)¶
J index of the north-most cell
12.1.11.11. IS_K_B(IS)¶
K index of the bottom-most cell
12.1.11.12. IS_K_T(IS)¶
K index of the top-most cell
12.1.11.13. IS_TYPE(IS)¶
Type of internal surface
No gas or solids flow through the surface. |
Gas flows through the surface with an additional resistance. Solids velocity through the surface is set to zero or to a user-specified fixed value (i.e., solids momentum equation for this direction is not solved). |
No gas or solids flow in the X direction. |
Gas flows in the Z direction with additional resistance. Solids velocity in the Z direction is set to zero or to a user-specified fixed value (i.e., solids momentum equation for this direction is not solved). |
No gas or solids flow in the Y direction. |
Gas flows in the Y direction with additional resistance. Solids velocity in the Y direction is set to zero or to a user-specified fixed value (i.e., solids momentum equation for this direction is not solved). |
No gas or solids flow in the Z direction. |
Arbitrary shaped internal surface defined by an STL file. Only visible to DEM particles or PIC parcels. The fluid phase doesn’t feel this stl internal surface. |
12.1.11.14. IS_PC(IS, IDX)¶
\(1 \le IDX \le 2\)
IDX=1: Permeability [1.0E32]
IDX=2: Inertial resistance coefficient [0.0]
12.1.11.15. IS_VEL_S(IS, PHASE)¶
12.1.11.16. IS_WALL_VEL(IS, COMPONENT)¶
\(1 \le Component \le 3\)
Internal surface translational velocity. This is only meant to be used for granular DEM, CGP, SQP or GSP models to move internal surfaces defined by STL files. Example: a valve moving up and down. The first index is the IS ID, the second index is the component (1=x, 2=y, 3=z)
12.1.11.17. IS_WALL_OMEGA(IS, COMPONENT)¶
Internal surface angular velocity. This is only meant to be used for granular DEM, CGP, SQP or GSP models to move internal surfaces defined by STL files. The rotation occurs around the center point defined with IS_WALL_ROT_CENTER. Example: a smooth rotating drum. The first index is the IS ID, the second index is the component (1=x, 2=y, 3=z)
12.1.11.18. IS_WALL_ROT_CENTER(IS, COMPONENT)¶
Internal surface center of rotation. This is only meant to be used for granular DEM, CGP, SQP or GSP models to move internal surfaces defined by STL files. This keywords is used in conjunction with IS_WALL_OMEGA. Example: a mixer with rotating paddles. The first index is the IS ID, the second index is the component (1=x, 2=y, 3=z)
12.1.11.19. IS_REBIN_N¶
Frequency of STL facets binning to the DES grid. This is only meant to be used for granular DEM, CGP, SQP or GSP models to move internal surfaces defined by STL files.
