12.1.9. Initial Condition¶
Each initial condition (IC) is specified over a rectangular region (or
pie-shaped for cylindrical coordinates) that corresponds to the scalar numerical
grid. These are 3D regions: X_w X_e, Y_s Y_n, and Z_t Z_b. The
region is defined by the constant coordinates of each of the six faces, which
may be specified as the physical coordinates or the cell indices. The physical
coordinates are easier to specify than the cell indices. If cell sizes are not
small enough to resolve a region specified using physical coordinates, MFIX will
indicate this problem with an error message.
12.1.9.1. IC_X_W(IC)¶
\(1 \le IC \le 500\)
12.1.9.2. IC_X_E(IC)¶
12.1.9.3. IC_Y_S(IC)¶
12.1.9.4. IC_Y_N(IC)¶
12.1.9.5. IC_Z_B(IC)¶
12.1.9.6. IC_Z_T(IC)¶
Z coordinate of the top face.
12.1.9.7. IC_I_W(IC)¶
12.1.9.8. IC_I_E(IC)¶
12.1.9.9. IC_J_S(IC)¶
12.1.9.10. IC_J_N(IC)¶
12.1.9.11. IC_K_B(IC)¶
12.1.9.12. IC_K_T(IC)¶
K index of the top-most wall.
12.1.9.13. IC_TYPE(IC)¶
12.1.9.14. IC_EP_G(IC)¶
12.1.9.15. IC_P_G(IC)¶
12.1.9.16. IC_P_STAR(IC)¶
12.1.9.17. IC_L_SCALE(IC)¶
12.1.9.18. IC_ROP_S(IC, PHASE)¶
12.1.9.19. IC_EP_S(IC, PHASE)¶
12.1.9.20. IC_PSD_TYPE(IC, PHASE)¶
Uniform particle size. |
12.1.9.21. IC_PSD_MEAN_DP(IC, PHASE)¶
Initial mean value of particle size distribution of solids phase in the IC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.9.22. IC_PSD_STDEV(IC, PHASE)¶
Initial standard deviation of particle size distribution of solids phase in the IC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.9.23. IC_PSD_MAX_DP(IC, PHASE)¶
12.1.9.24. IC_PSD_MIN_DP(IC, PHASE)¶
12.1.9.25. IC_T_G(IC)¶
12.1.9.26. IC_T_S(IC, PHASE)¶
12.1.9.27. IC_THETA_M(IC, PHASE)¶
12.1.9.28. IC_GAMA_RG(IC)¶
12.1.9.29. IC_T_RG(IC)¶
12.1.9.30. IC_GAMA_RS(IC, PHASE)¶
12.1.9.31. IC_T_RS(IC, PHASE)¶
12.1.9.32. IC_U_G(IC)¶
Initial x-axial component of gas velocity in the IC region.
12.1.9.33. IC_U_S(IC, PHASE)¶
Initial x-axial component of solids-phase velocity in the IC region.
12.1.9.34. IC_V_G(IC)¶
Initial y-axial component of gas velocity in the IC region.
12.1.9.35. IC_V_S(IC, PHASE)¶
Initial y-axial component of solids-phase velocity in the IC region.
12.1.9.36. IC_W_G(IC)¶
Initial z-axial component of gas velocity in the IC region.
12.1.9.37. IC_W_S(IC, PHASE)¶
Initial z-axial component of solids-phase velocity in the IC region.
12.1.9.38. IC_X_G(IC, SPECIES)¶
\(1 \le Species \le 100\)
12.1.9.39. IC_X_S(IC, PHASE, SPECIES)¶
12.1.9.40. IC_SCALAR(IC, SCALAR EQ.)¶
\(1 \le Scalar Eq. \le 100\)
12.1.9.41. IC_K_TURB_G(IC)¶
12.1.9.42. IC_E_TURB_G(IC)¶
12.1.9.43. IC_DES_LATTICE(IC, PHASE)¶
Type of initial lattice distribution (simple cubic or hexagonal) to the entire IC region.
Particles are distributed on a hexagonal close-packed lattice. |
Particles are distributed on a cubical lattice. |
12.1.9.44. IC_DES_SPACING(IC, PHASE)¶
Spacing between particle within initial lattice distribution (expressed as a fraction of particle diameter) to the entire IC region.
12.1.9.45. IC_DES_SPACE_FACTOR_X(IC, PHASE)¶
12.1.9.46. IC_DES_SPACE_FACTOR_Y(IC, PHASE)¶
12.1.9.47. IC_DES_SPACE_FACTOR_Z(IC, PHASE)¶
12.1.9.48. IC_DES_RAND(IC, PHASE)¶
12.1.9.49. IC_DES_RAND_FACTOR_X(IC, PHASE)¶
12.1.9.50. IC_DES_RAND_FACTOR_Y(IC, PHASE)¶
12.1.9.51. IC_DES_RAND_FACTOR_Z(IC, PHASE)¶
12.1.9.52. IC_DES_SM(IC, PHASE)¶
12.1.9.53. IC_DES_NP(IC, PHASE)¶
12.1.9.54. IC_DES_ABORT_ON_FAILED_SEEDING(IC, PHASE)¶
Flag to abort if unsuccessful seeding occurs.
12.1.9.55. IC_DES_CHECK_STL_OVERLAP(IC, PHASE)¶
Check for particle overlap with SL geometry in the entire IC region.
12.1.9.56. IC_PIC_CONST_STATWT(IC, PHASE)¶
Flag to specify the initial constant statistical weight for computational particles/parcels. Actual number of parcels will be automatically computed.
12.1.9.57. IC_SQP_RANDOM_Q(IC, PHASE)¶
12.1.9.58. IC_GSP_RANDOM_Q(IC, PHASE)¶
Initialize GSP with random orientation (quaternion) in the IC region.
