12.1.4. Chemical reactions¶
12.1.4.1. ARRHENIUS_RRATES_DES¶
Flag to use Arrhenius reaction model for discrete particle reactions.
12.1.4.2. ARRHENIUS_RRATES_FLUID¶
Flag to use Arrhenius reaction model for fluid phase reactions.
12.1.4.3. CHEM_MIN_SPECIES_FLUID¶
Minimum species mass fraction in fluid. Reaction rates are not calculated when reactants fall below this threshold.
12.1.4.4. CHEM_MIN_SPECIES_SOLID¶
Minimum species mass fraction in solid. Reaction rates are not calculated when reactants fall below this threshold.
12.1.4.5. DES_MIN_PMASS_FRAC¶
Minimum particle mass fraction for reactions. When the ratio of particle mass to initial mass is below this threshold, reactions which consume particle species will be turned off for these particles. If a particle size distribution is in effect, the initial mass is the minimum mass for the distribution.
12.1.4.6. NMAX(PHASE)¶
\(0 \le Phase \le 10\)
12.1.4.7. SPECIES_NAME(PHASE)¶
12.1.4.8. STIFF_CHEM_ABS_TOL¶
12.1.4.9. STIFF_CHEM_MAX_STEPS¶
12.1.4.10. STIFF_CHEM_MIN_RATE¶
Stiff chemistry minimum fluid reaction rate. If all fluid reaction rates are below this threshold, a cell is said to be non-reactive and no ODE is set for this cell.
12.1.4.11. STIFF_CHEM_MIN_RATE_DPM¶
Stiff chemistry minimum DPM (Discrete Phase Model) reaction rate. If all DPM reaction rates are below this threshold, a particle/parcel is said to be non-reactive and no ODE is set for this particle/parcel.
12.1.4.12. STIFF_CHEM_REL_TOL¶
12.1.4.13. STIFF_CHEMISTRY¶
Flag to use stiff chemistry solver (Direct integration).
12.1.4.14. USE_RRATES¶
