12.1.19. Two-fluid model (TFM)
This section contains keywords relating to the Two-fluid model (TFM).
12.1.19.1. ADDED_MASS
12.1.19.2. BLENDING_FUNCTION
Table 12.94 Valid values
No blending
TANH_BLEND
Hyperbolic tangent function
SIGM_BLEND
Scaled sigmodial function
12.1.19.3. C_E
12.1.19.4. C_F
12.1.19.5. CLOSE_PACKED(PHASE)
Table 12.95 Valid values
The phase forms a packed bed with void fraction EP_STAR.
The phase can exceed close pack conditions so that it maybe behave like a liquid.
12.1.19.6. DIF_S0(PHASE)
12.1.19.7. E_W
12.1.19.8. EP_S_MAX(PHASE)
12.1.19.9. EP_STAR
12.1.19.10. EPS_F_MIN
12.1.19.11. FEDORS_LANDEL
Table 12.96 Valid values
Use the Fedors-Landel correlation.
Do not use the Fedors-Landel correlation.
12.1.19.12. FRICTION_MODEL
Table 12.97 Valid values
Only solids pressure
SCHAEFFER
Schaeffer friction model. 1987, Journal of Differential Equations 66, 19–50.
SRIVASTAVA
Srivastava and Sundaresan friction model. 2003, Powder Technology 129(1-3):72-85
GUO_BOYCE
Guo-Boyce friction model, 2021. Proceedings of the National Academy of Sciences, 118 (35).
12.1.19.13. JENKINS
Table 12.98 Valid values
Use standard boundary conditions.
Use Jenkins small frictional boundary condition.
12.1.19.14. KT_TYPE
Solids phase viscous stress model [Algebraic].
Table 12.99 Valid values
ALGEBRAIC
Granular energy algebraic formulation.
AHMADI
Cao and Ahmadi (1995). Int. J. Multiphase Flow 21(6), 1203.
GD_99
Garzo and Dufty (1999). Phys. Rev. E 59(5), 5895.
GHD
Garzo, Hrenya and Dufty (2007). Phys. Rev. E 76(3), 31304
GTSH
Garzo, Tenneti, Subramaniam, Hrenya (2012). J.Fluid Mech. 712, 129.
IA_NONEP
Iddir & Arastoopour (2005). AIChE J. 51(6), 1620
LUN_1984
Lun et al (1984). J. Fluid Mech., 140, 223.
SIMONIN
Simonin (1996). VKI Lecture Series, 1996-2
12.1.19.15. M_AM
12.1.19.16. MU_S0(PHASE)
  • kinetic theory calculations (granular_energy) are off, which
  • frictional/plastic calculations are off, which means zero
  • LAMBDA_S = -2/3 MU_S0
12.1.19.17. PHI
12.1.19.18. PHI_W
12.1.19.19. PHIP
12.1.19.20. PHIP0
12.1.19.21. R_P(PHASE, PHASE)
  • \(1 \le Phase \le 2\)
12.1.19.22. RDF_TYPE
Table 12.100 Valid values
CARNAHAN_STARLING
Carnahan, N.F. and Starling K.E., (1969). The Journal of Chemical Physics, Vol. 51(2):635-636. Only applies to monodisperse cases.
MA_AHMADI
Ma, D. and Ahmadi, G., (1986). The Journal of Chemical Physics, 84(6):3449. Only applies to monodisperse cases.
LEBOWITZ
Lebowitz, J.L. (1964) The Physical Review, A133, 895-899. Only applies to polydisperse cases.
MODIFIED_LEBOWITZ
Iddir, H. Y., Modeling of the multiphase mixture of particles using the kinetic theory approach. Doctoral Dissertation, Illinois Institute of Technology, Chicago, Illinois, 2004, (chapter 2, equations 2-49 through 2-52.) Only applies to polydisperse cases.
MANSOORI
Mansoori, GA, Carnahan N.F., Starling, K.E. Leland, T.W. (1971). The Journal of Chemical Physics, Vol. 54:1523-1525. Only applies to polydisperse cases.
MODIFIED_MANSOORI
van Wachem, B.G.M., Schouten, J.C., van den Bleek, C.M., Krishna, R. and Sinclair, J. L. (2001) AIChE Journal 47:1035–1051. Only applies to polydisperse cases.
12.1.19.23. SEGREGATION_SLOPE_COEFFICIENT
12.1.19.24. V_EX
Table 12.101 Valid values
0.0
Boyle-Massoudi stress is turned off.
12.1.19.25. YU_STANDISH
Table 12.102 Valid values
Use the Yu-Standish correlation.
Do not use the Yu-Standish correlation.
