12.1.6. Gas phase¶
12.1.6.1. ALPHA_TRANSPORT(SPECIES)¶
\(1 \le Species \le 100\)
The polarizability in transport data. [in cubic Angstroms].
12.1.6.2. C_PG0¶
12.1.6.3. CONFIG_TRANSPORT(SPECIES)¶
Geometrical configuration of molecule.
Monatomic |
Linear |
Nonlinear |
12.1.6.4. DABG(SPECIES, SPECIES)¶
Set constant binary diffusion coefficients if known [m^2/s in SI]
12.1.6.5. DIF_COEFF_KT¶
Compute diffusion coefficients from kinetic theory.
Use constant diffusion coefficients. Diffusion data can be obtained from:
Compute diffusion coefficients from kinetic theory. Parameters in Lennard-Jones intermolecular potential model can be obtained from:
12.1.6.6. DIF_G0¶
12.1.6.7. DIF_THERMAL¶
Include thermal diffusion in multicomponent diffusion model.
Compute thermal diffusion. |
Ignore effects of thermal diffusion. |
12.1.6.8. HB_GAMA_C¶
Strain rate cutoff [1/s] in Herschel-Bulkley viscosity law.
12.1.6.9. HB_K0¶
Consistency factor [Pa.s^n] in Herschel-Bulkley viscosity law.
12.1.6.10. HB_N¶
Power law index (dimensionless) in Herschel-Bulkley viscosity law.
0 < HB_n < 1 : Shear thinning fluid
HB_n = 1 : Bingham fluid
HB_n > 1 : Shear thickening fluid
12.1.6.11. HB_TAU0¶
Bingham yield stress [Pa] in Herschel-Bulkley viscosity law.
12.1.6.12. K_G0¶
12.1.6.13. KG_MODEL¶
Gas thermal conductivity model (default is temperature-dependent value for air).
Constant thermal conductivity. K_g0 must be specified. |
Temperature-dependent model for air |
Lennard-Jones model. Bird, R., Stewart, W. and Lightfoot, E. (2002) Transport Phenomena.2nd Edition, John Wiley and Sons, New York. Eq.(9.3-13) on Page 275 for the calculation of thermal conductivity. Eq.(E.2-1) on Page 866 for the collision integral. |
Polynomial fit from species transport data using cantera. https://cantera.org/dev/cxx/d8/d58/classCantera_1_1GasTransport.html#a267d20cdea7486fe84e722ee82d84b20 |
User-defined function |
12.1.6.14. LJEPS(SPECIES)¶
Epsilon/k coefficient in Lennard-Jones potential [in Kelvin].
12.1.6.15. LJSIG(SPECIES)¶
Sigma coefficient in Lennard-Jones potential [in Angstrom].
12.1.6.16. MU_G0¶
Specified constant gas viscosity [Pa.s in SI].
12.1.6.17. MU_G_MODEL¶
Gas viscosity model (default is Sutherland’s law).
Constant viscosity |
Sutherland’s law |
Herschel-Bulkley (non-Newtonian) model |
Lennard-Jones model. Bird, R., Stewart, W. and Lightfoot, E. (2002) Transport Phenomena.2nd Edition, John Wiley and Sons, New York. Eq.(1.4-14) on Page 26 for the calculation of viscosity. Eq.(E.2-1) on Page 866 for the collision integral. |
12.1.6.18. MU_TRANSPORT(SPECIES)¶
The dipole moment in transport data. [in Debye].
12.1.6.19. MULTI_COMPONENT_DIFFUSION¶
Solve the multicomponent diffusion model.
Include multicomponent diffusion model in species equation. |
Do not include multicomponent diffusion model. |
12.1.6.20. MW_AVG¶
12.1.6.21. MW_G(SPECIES)¶
12.1.6.22. NMAX_G¶
12.1.6.23. POLY_KG(SPECIES, INDEX)¶
\(1 \le Index \le 5\)
The fitted polynomial for species thermal conductivity from Cantera based on the transport data.
12.1.6.24. POLY_MU_G(SPECIES, INDEX)¶
The fitted polynomial for species viscosity from Cantera based on the transport data.
12.1.6.25. RO_G0¶
12.1.6.26. SL_MUREF¶
Reference gas viscosity [Pa.s in SI] in the Sutherland’s law.
12.1.6.27. SL_S¶
Sutherland constant [K] in the Sutherland’s law.
12.1.6.28. SL_TREF¶
Reference temperature [K] in the Sutherland’s law.
12.1.6.29. SPECIES_ALIAS_G(SPECIES)¶
12.1.6.30. SPECIES_G(SPECIES)¶
12.1.6.31. ZROT_TRANSPORT(SPECIES)¶
The rotational relaxation collision number at 298K. It is dimensionless.
