12.1.10. Numerical parameters¶
This section contains keywords for defining numerical parameters. Keywords
related to solving the governing equations (e.g., LEQ_IT, DISCRETIZE,
UR_FAC, etc.) are dimensioned for the ten types of equations:
Index |
Equation Type |
1 |
Gas Pressure |
2 |
Solids Volume Fraction |
3 |
Gas and Solids U Momentum Equation |
4 |
Gas and Solids V Momentum Equation |
5 |
Gas and Solids W Momentum Equation |
6 |
Gas and Solids Energy Equations (Temperature) |
7 |
Gas and Solids Species Mass Fractions |
8 |
Granular Temperature |
9 |
User-Defined Scalar and K-Epsilon Equation |
10 |
DES Diffusion Equation |
For example, LEQ_IT(3) = 10, specifies to use 10 iterations within the
linear equation solver for the U Momentum Equations (of type 3).
12.1.10.1. CHI_SCHEME¶
Do not use the chi-scheme. |
Use the chi-scheme correction. |
12.1.10.2. CN_ON¶
Implicit Euler based temporal discretization scheme employed (first-order accurate in time). |
Two-step implicit Runge-Kutta method based temporal discretization scheme employed. This method should be second- order accurate in time excluding pressure terms and restart time step which are first-order accurate. However, as of 2015, testing shows that second-order accuracy is not observed. |
12.1.10.3. DEF_COR¶
Use down-wind factor method (default). |
Use deferred correction method. |
12.1.10.4. DETECT_STALL¶
Continue iterating if residuals stall. |
Reduce time step if residuals stall. |
12.1.10.5. DIL_EP_S¶
12.1.10.6. DISCRETIZE(EQUATION ID NUMBER)¶
Central (often unstable; useful for testing). |
First-order upwinding (default). |
First-order upwinding (using down-wind factors). |
minmod. |
MUSCL. |
Smart. |
Superbee. |
ULTRA-QUICK. |
van Leer. |
12.1.10.7. DO_TRANSPOSE¶
12.1.10.8. EPP_DEN¶
12.1.10.9. FPE_TRAP_INVALID¶
Terminate simulation and print stack trace on math domain errors (square root or log of negative value, etc).
12.1.10.10. FPE_TRAP_OVERFLOW¶
Terminate simulation and print stack trace on numerical overflow.
12.1.10.11. FPE_TRAP_ZERO¶
Terminate simulation and print stack trace on zero division errors.
12.1.10.12. ICHECK_BICGS¶
12.1.10.13. LEQ_IT(EQUATION ID NUMBER)¶
12.1.10.14. LEQ_METHOD(EQUATION ID NUMBER)¶
SOR - Successive over-relaxation |
BiCGSTAB - Biconjugate gradient stabilized. |
GMRES - Generalized minimal residual method |
CG - Conjugate gradient |
12.1.10.15. LEQ_PC(EQUATION ID NUMBER)¶
No preconditioner |
Line relaxation |
Diagonal Scaling |
12.1.10.16. LEQ_SWEEP(EQUATION ID NUMBER)¶
(Red/Black Sweep, Send Receive) repeated twice |
(Sweep in I, Send Receive) repeated twice |
(Sweep in J, Send Receive) repeated twice |
(Sweep in K, Send Receive) repeated twice |
(All Sweep, Send Receive) repeated twice |
12.1.10.17. LEQ_TOL(EQUATION ID NUMBER)¶
12.1.10.18. MAX_INLET_VEL_FAC¶
The code declares divergence if the velocity anywhere in the domain exceeds a maximum value. This maximum value is automatically determined from the boundary values. By default it is 100 times the maximum inlet velocity. This can be scaled value by adjusting this additional multiplier [1.0d0].
12.1.10.19. MAX_NIT¶
12.1.10.20. NORM_G¶
12.1.10.21. NORM_S¶
12.1.10.22. OPT_PARALLEL¶
12.1.10.23. PPG_DEN¶
12.1.10.24. REPEATABLE¶
Initialize random number generator with a fixed seed, to ensure repeatable results.
12.1.10.25. TMAX¶
Maximum temperature allowed in the system (K). It is strongly encouraged to keep the default value of 4000.0.
12.1.10.26. TMIN¶
Minimum temperature allowed in the system (K). It is strongly encouraged to keep the default value of 50.0.
12.1.10.27. TOL_DIVERGE¶
12.1.10.28. TOL_RESID¶
Maximum residual at convergence (continuity + momentum) [1.0d-3].
12.1.10.29. TOL_RESID_SCALAR¶
12.1.10.30. TOL_RESID_T¶
12.1.10.31. TOL_RESID_TH¶
12.1.10.32. TOL_RESID_X¶
12.1.10.33. TOL_SUM_RESID_ABS¶
12.1.10.34. UR_F_GS¶
0 updates F_GS every time step
1 updates F_GS every iteration
12.1.10.35. UR_FAC(EQUATION ID NUMBER)¶
12.1.10.36. UR_KTH_SML¶
12.1.10.37. USE_DOLOOP¶
12.1.10.38. ZERO_EP_S¶
12.1.10.39. ZERO_X_GS¶
