Hello everyone, I just simulate a single particle impact some particle layer, and the automatic particle generation will not set the particle in the middle, so I try to add particles at runtime.I study the method in Customize adding particles at runtime.
But In my question is 2D, so when I use the same code, the solver report that the distance between wall and particle center equal to zero, I think the problem come from code “usr3_des.f” line 77-78, because I must appoint the position where particle emission.
If there are any other method can I achieve the function I want,my project is attached.
vgas3.5_2023-06-16T144309.071081.zip (75.7 KB)
The program operation results are as follows:
Welcome to MFiX - https://mfix.netl.doe.gov
MFiX-GUI version 23.1
Ready
Loading V15.5.mfx from D:\MFIX\23.06.09_Single_injection\Vgas25.5\V15.5_4layer_U
Solver: MFiX-DEM
Reading mesh boundary: D:\MFIX\23.06.09_Single_injection\Vgas25.5\V15.5_4layer_U\VGAS3.5_boundary.vtk
Reading mesh stats: D:\MFIX\23.06.09_Single_injection\Vgas25.5\V15.5_4layer_U\MESH_STATS.LOG
Loaded V15.5.mfx
Mesh file VGAS3.5.msh not found
Solver: SMS Mesher
Ready
Starting D:\Anaconda\envs\mfix-23.1\Scripts\mfixsolver.exe -f D:\MFIX\23.06.09_Single_injection\Vgas25.5\V15.5_4layer_U\mesh_afjqx6q0.mfx.tmp
Using d3.dll
Using D:/Anaconda/envs/mfix-23.1/lib/site-packages/mfix_solver/mfixsolver.so
MFiX (23.1-0 ) simulation on host: DESKTOP-8MNC2MM
Run name: VGAS3.5 Time: 14:24 Date: 6-16-2023
Project version: 142
Message from open_files.f:360
This is a rectangular geometry simulation.
Mesh generation will be performed.
No mesh file will be written, only the [RUN_NAME]_boundary.vtk file will be written.
MESH STATISTICS:
NUMBER OF CELLS = 3000
NUMBER OF STANDARD CELLS = 3000 (100.00 % of Total)
NUMBER OF CUT CELLS = 0 ( 0.00 % of Total)
NUMBER OF FLUID CELLS = 3000 (100.00 % of Total)
NUMBER OF BLOCKED CELLS = 0 ( 0.00 % of Total)
WRITING VTU FILE : VGAS3.5_MESH.vtu .
WROTE BOUNDARY IN VTK FILE : VGAS3.5_boundary.vtk
PRE_PROCESSING COMPLETE.
Mesh accepted
ppo = False
Solver: MFiX-DEM
project_version = '143'
Saving D:\MFIX\23.06.09_Single_injection\Vgas25.5\V15.5_4layer_U\V15.5.mfx
Starting D:\MFIX\23.06.09_Single_injection\Vgas25.5\V15.5_4layer_U\mfixsolver.bat -s -f D:\MFIX\23.06.09_Single_injection\Vgas25.5\V15.5_4layer_U\V15.5.mfx
MFiX running: elapsed time 0:00:00
(mfix-23.1) D:/MFIX/23.06.09_Single_injection/Vgas25.5/V15.5_4layer_U>call python -m mfix_solver.pymfix -d "D:/MFIX/23.06.09_Single_injection/Vgas25.5/V15.5_4layer_U" -s -f D:/MFIX/23.06.09_Single_injection/Vgas25.5/V15.5_4layer_U/V15.5.mfx
Using d3.dll
Using D:/MFIX/23.06.09_Single_injection/Vgas25.5/V15.5_4layer_U/mfixsolver.so
MFiX (23.1 ) simulation on host: DESKTOP-8MNC2MM
Run name: VGAS3.5 Time: 14:33 Date: 6-16-2023
Project version: 143
Message from check_data/check_solids_dem.f:741
At time = 0.000000E+00 sec., setting DEM solids time step, DTSOLID (sec) = 0.121854E-07
Message from check_data/check_geometry.f:191
DES grid size:
DESGRIDSEARCH_IMAX = 60
DESGRIDSEARCH_JMAX = 50
DESGRIDSEARCH_KMAX = 1
DES MPI send/recv buffer: 0.8 MB
o 8192. Ghost particles/MB
o 3855. Particles/MB
o 11916. Neighbor pairs/MB
Pre-Processing geometry for DES.
DES geometry pre-processing complete.
MESH STATISTICS:
... WROTE BOUNDARY IN VTK FILE : VGAS3.5_boundary.vtk
Initial DES Particle array size: 480
Message from set_bc0.f:549
Compressible: IJK_P_g remaining undefined.
Message from des/read_particle_input.f:107
Reading DEM particle input file version: 2.0
Detecting number of columns from the first line in the data.
Expected number of columns = 3
Detected number of columns = 3
The following filters are applied to particle data:
Phase 1: EXCLUDE particles belonging to Phase 1
No filter is applied.
Message from des/read_particle_input.f:584
Number of particles read from particle_input.dat = 480
Number of particles left after filtering the data = 480
Beginning DEM settling period: 0 steps.
DEM settling period complete.
For mass inlet BC: 4
No. particles injected per solids time step = 1.44288359E-05
No. particles injected per second = 1184
PI_FACTOR = 6.93056641E+04 PI_COUNT = 1
start DES_MI_TIME = 8.44514198E-04
t= 0.000000 Wrote .RES; DES.RES;
WRITING VTP FILE : BACKGROUND_IC_0000.vtp .
.... VTP file not written (zero particles in vtk region).
WRITING VTU FILE : BACKGROUND_IC_1_0000.vtu .
.. WRITING VTP FILE : BACKGROUND_IC_2_0000.vtp .
.... Time = 0.00000 Dt = 0.10000E-05
Nit P0 U0 V0 Max res
1 5.1E-10 7.9E-05 0. U0
2 8.8E-02 5.9E-02 2.2E-07 P0
3 5.1E-02 3.2E-02 1.2E-07 P0
4 2.9E-02 1.7E-02 6.3E-08 P0
5 1.6E-02 9.2E-03 3.4E-08 P0
6 9.3E-03 4.9E-03 1.8E-08 P0
7 5.3E-03 2.6E-03 1.0E-08 P0
8 3.1E-03 1.4E-03 5.5E-09 P0
9 1.8E-03 7.7E-04 3.1E-09 P0
10 1.0E-03 4.2E-04 1.7E-09 P0
11 5.9E-04 2.3E-04 9.5E-10 P0
12 3.4E-04 1.3E-04 5.3E-10 P0
13 2.0E-04 7.0E-05 3.0E-10 P0
14 1.2E-04 3.9E-05 1.7E-10 P0
15 6.7E-05 2.2E-05 9.5E-11 P0
16 3.9E-05 1.2E-05 5.4E-11 P0
17 2.3E-05 6.7E-06 3.1E-11 P0
18 1.3E-05 3.8E-06 1.7E-11 P0
19 7.8E-06 2.1E-06 9.9E-12 P0
t= 0.0000 Dt= 0.1000E-05 NIT= 19 Sm= 0.0000 CPU= 0.s
Mass imbalance%(0,MMAX): -0.2188E-06
Timestep walltime, fluid solver: 0.134 s
DEM NITs: 83 Total PIP: 480
WRITING VTP FILE : BACKGROUND_IC_0001.vtp .
WRITING VTP FILE : BACKGROUND_IC_2_0001.vtp .
.... ==================================> INJECTING NEW PARTICLE <======================================
NITs/SEC = 1541.
Timestep walltime, DEM solver: 0.054 s
Time (s) DT (s) CV NIT Max Residual Fluid DEM NITs PIP Elapsed Left
0.0000 0.10E-05 C 19 P0=0.78E-05 0.13s 0.05s 83 480 0.19s 0.00s
WRITING VTU FILE : BACKGROUND_IC_1_0001.vtu .
1 6.0E-10 0.3 1.5E-06 U0
2 0.3 6.6E-02 6.7E-07 P0
3 0.2 3.4E-02 3.7E-07 P0
4 9.2E-02 1.8E-02 2.1E-07 P0
5 5.3E-02 9.9E-03 1.1E-07 P0
6 3.0E-02 5.5E-03 6.4E-08 P0
7 1.8E-02 3.0E-03 3.6E-08 P0
8 1.0E-02 1.7E-03 2.0E-08 P0
9 5.9E-03 9.3E-04 1.1E-08 P0
10 3.4E-03 5.2E-04 6.3E-09 P0
11 2.0E-03 2.9E-04 3.5E-09 P0
12 1.2E-03 1.6E-04 2.0E-09 P0
13 7.1E-04 8.9E-05 1.1E-09 P0
14 4.2E-04 5.0E-05 6.2E-10 P0
15 2.5E-04 2.8E-05 3.5E-10 P0
16 1.5E-04 1.5E-05 1.9E-10 P0
17 9.2E-05 8.6E-06 1.1E-10 P0
18 5.6E-05 4.8E-06 6.3E-11 P0
19 3.4E-05 2.7E-06 3.6E-11 P0
20 2.0E-05 1.5E-06 2.1E-11 P0
21 1.2E-05 8.7E-07 1.3E-11 P0
22 7.5E-06 4.9E-07 7.4E-12 P0
Timestep walltime, fluid solver: 0.104 s
DEM NITs: 83 Total PIP: 481
Error from des/calc_collision_wall_mod.f:253
Error: solver crash!
Error information:
**float divide by zero in __calc_collision_wall_MOD_calc_dem_force_with_wall_stl**
at des/calc_collision_wall_mod.f:253
Code for error location line 253:
