Losing particles in the simulation domain
Hi Mfixers! I am trying to modify the souce code in calc_force_dem.f by changing the van der waals model. However, with the modified source code, I lost particles in the fluidized beds (see the figure below). I am new with MFIX. I hope somebody can help with solving this problem. Thanks!
The bug report is attached here.
2d-dem-fluidizedbed_2022-09-07T195524.533039.zip (277.2 KB)
There are several common reasons for particles leaving the defined domain. Here’s a few previous forum threads covering this topic:
Please see https://mfix.netl.doe.gov/forum/t/sigsegv-segmentation-fault/2631/2
and
https://mfix.netl.doe.gov/forum/t/error-invalid-memory-reference/2322
If none of the above helps, please follow up here. Thanks.
