3.1. First Tutorial¶
It is also assumed that the terminal shell on Linux and Mac is bash. If
this is not the case, type bash at the prompt before activating the
environment.
3.1.1. Starting the MFiX GUI¶
On Windows, open the Anaconda Prompt and activate the mfix environment
On Linux open a terminal and activate the mfix environment from bash.
On macOS open a terminal and activate the mfix environment from bash.
# Windows
conda activate mfix-21.1.4
(mfix-21.1.4) C:\> mfix
# Linux or Mac
(mfix-21.1.4) > mfix
3.1.2. Creating a Project¶
(New)
Icon |
Single phase Model |
Two Fluid Model (TFM) |
Hybrid Model (TFM + DEM) |
Chemistry |
(single phase), and
(chemistry) iconsDouble-click on
Click Ok
3.1.3. Running the Solver¶
(Start) button to open the Run Dialog.Click Ok to use the default mfixsolver:
[default]/mfixsolver
3.1.4. View results¶
VTKresults tab. The visibility and representation of the*.vtkfiles can be controlled with the menu on the side.Change frames with the
, and
buttonsClick the
button to play the available vtk files.Change the playback speed under the
section on the sidebar.
3.1.5. Pausing/Unpausing¶
(pause) button to pause the solver.MFiX pausedwill be displayed in the Terminal window. The solver process still exists, but is waiting for you to unpause it.While the solver is paused, you can change the project. For instance, on the Run Pane you could change
stop timeto another value to have the solver run for a different amount of time.Click the
3.1.6. Stopping/Resuming¶
(stop) button to stop the solver.
Clicking the
(run) button to open the Run Dialog.Check
