3.7. DEM Granular Flow Chutes¶
1.75 m x 0.94 m x 0.2 m |
20 x 20 x 10 |
12.5 mm (0.0125 m) |
3.7.1. Create a new project¶
fig_new_project): On the main menu, selectNew projectCreate a new project by double-clicking on “Blank” template.
Disable Fluid Solvercheckbox.
3.7.3. Enter the geometry¶
fig_add_cylinder): Create the cylindrical geometry by pressing
-> primitives->cylinderEnter
30for the cylinder resolution
fig_difference): Subtract the smaller radius cylinder from the larger radius cylinder bySelect the larger radius cylinder (named
cylinder)While holding the
ctrlkey, select the smaller radius cylinder (namedcylinder1)Press the
Slice the tube in half by:
Add a box:
-> primitives->box
Y Lengthto1.2m
Select the tube (named
difference)While holding the
ctrlkey, select the box (namedbox)Press the
Rotate the chute by:
Select the chute (named
difference1)(
fig_add_transform): Add a filter:
-> transformEnter a value of
0.8m in theTranslate Yfield.Enter a value of
70in theRotation Zfield.
transform)Enter a value of
120in theRotation Zfield
(named transform1)Enter a value of
Press the
3.7.4. Enter the mesh¶
On the Mesh pane:
Backgroundsub-pane
20for the x cell valueEnter
20for the y cell valueEnter
10for the z cell value
Select the Regions pane.
click the
button to create a new regionEnter a name for the region in the
Namefield (“walls”)Change the color by pressing the
ColorbuttonCheck the
Select Facets (STL)checkbox
Namefield (“inlet”)Enter a value of
-0.4m in theFrom XfieldEnter a value of
-0.2m in theTo Xfield
3.7.6. Create a solid¶
On the Solids pane:
button to create a new solidEnter a descriptive name in the
On the DEM sub pane:
check the
buttonOn the
OKOn the
buttonOn the
Select Regiondialog, select “No Slip Wall” from theBoundary typecombo-boxSelect the “walls” region and click
3.7.9. Select output options¶
buttonSelect
Particle Datain theOutput typecombo box.Select the “Background IC” region from the list to save all the cell data
3.7.10. Run the project¶
Save project by clicking
buttonRun the project by clicking the
buttonOn the
3.7.11. View results¶
in the upper
right hand corner.Select an item to view, such as plotting the time step (dt) or click the
