3.2. Two Dimensional Fluid Bed, Two Fluid Model (TFM)¶
This tutorial shows how to create a two dimensional fluidized bed simulation using the two fluid model. The model setup is:
10 cm x 30 cm |
20 x 60 |
0.25 m/s |
3.2.1. Create a new project¶
fig_new_project): On the main menu selectNew projectCreate a new project by double-clicking on “Blank” template.
Solverdrop-down menu.
3.2.3. Enter the geometry¶
2 DimensionalcheckboxEnter
3.2.4. Enter the mesh¶
20for the x cell valueEnter
60for the y cell value
visualize the results.
click the
button to create a new region to be used for the bed
initial condition.Enter a name for the region in the
ColorbuttonEnter
xmaxormaxin theTo XfieldEnter
zmaxormaxin theTo Zfield
button to create a new region with the FromandTofields already filled out for a region at the bottom of the domain, to be used by the gas inlet boundary condition.From YandTo Yshould equalymin, defining an XZ-plane.Enter a name for the region in the
Namefield (“inlet”)
button to create a new region with the FromandTofields already filled out for a region at the top of the domain, to be used by the pressure outlet boundary condition.From YandTo Yshould equalymax, defining an XZ-plane.Enter a name for the region in the
Namefield (“outlet”)
3.2.6. Create a solid¶
On the Solids pane:
button to create a new solidAccept the radial distribution setting (Carnahan-Starling)
buttonSelect the bed region created previously for the bed Initial Condition (“bed” region) and click the
OKbutton.
buttonOn the
buttonOn the
buttonSelect the “Background IC” region from the list to save all the cell data
OKto create the output
Volume fraction,Pressure, andVelocity vectorcheck-boxes on theFluidsub-sub-pane
3.2.12. Run the project¶
Save project by clicking the
buttonRun the project by clicking the
buttonOn the
3.2.13. View results¶
next to the Model tabSelect an item to view, such as plotting the time step (dt) or click the
Change frames with the
, and
buttonsClick the
button to play the available vtk files.Change the playback speed under the
section on the sidebar.
button and delete all simulation files.On the
Meshpane, change theX Cellsto 80 and theY Cellsto 180On the
Outputpane,VTKsub-pane, change the write interval to0.01Save and run the project.
