3.3. Two Dimensional Fluid Bed, Discrete Element Model (DEM)¶
15 cm x 90 cm x 0.4 cm |
15 x 45 x 1 |
2700 kg/m2 |
42.0 m/s |
3.3.1. Create a new project¶
Solverdrop-down menu.
3.3.3. Enter the geometry¶
0.15meters for the maximum x valueEnter
0.90meters for the maximum y valueEnter
0.004meters for the maximum z value
3.3.4. Enter the mesh¶
15for the x cell valueEnter
45for the y cell valueEnter
1for the z cell value
On the Regions pane:
click the
button to create a new region that covers the entire
domain to be used for the bed initial condition.Enter a name for the region in the
Namefield (“bed”)Change the
To Yfield to be “ymax/2”Click the
button to create a new region to be used by the gas
inlet boundary condition.Enter a name for the region in the
Namefield (“inlet”)Enter
0.07in theFrom Xfield and0.08in theTo Yfield.Click the
button to create a new region to be used by pressure
outlet boundary condition.Enter a name for the region in the
Namefield (“outlet”)
3.3.6. Create a solid¶
button to create a new solidEnter a descriptive name in the
Namefield (“solids”)Enter the particle diameter of
0.004m in theDiameterfieldEnter the particle density of
2700kg/m2 in theDensityfield
Solidspane,DEMsub-paneCheck the
Enable automatic particle generationcheckbox, so that the bed Initial Condition, defined later, will be filled with solids
buttonSelect the bed region created previously for the bed Initial Condition (“bed” region) and click the
OKbutton.
0.4in theVolume Fractionfield. This will fill the bottom half of the domain with solids.Note the estimated number of particles and inventory (around 3,200 particles or 0.3 kg). When running DEM simulations on a single core machine, it is recommended to stay below 100,000 particles to get reasonable run times.
buttonOn the
Y-axial velocityfield of “42” m/s
buttonOn the
3.3.9. Select output options¶
buttonSelect “Particle Data” from the ‘Output type’ drop-down menu.
OKto create the output
*.vtufiles in theFilename basefield (“particles”)Change the
DiameterandTranslational Velocitycheck-boxes
Stop Time stepto1.0secondsChange the
Time stepto1e-2secondsChange the
3.3.11. Run the project¶
Save project by clicking the
buttonRun the project by clicking the
buttonOn the
Rundialog, select the executable from the combo-boxClick the
3.3.12. View results¶
next to the Model tabSelect an item to view, such as plotting the time step (dt) or click the
Change frames with the
, and
buttonsClick the
button to play the available vtk files.Change the playback speed under the
section on the sidebar.
