3.20. DEM granular flow chutes¶
1.75 m x 0.94 m x 0.2 m |
20 x 20 x 10 |
12.5 mm (0.0125 m) |
3.20.1. Create a new project¶
3.20.2. Select model parameters¶
On the Model pane:
Disable Fluid Solvercheckbox.
3.20.3. Enter the geometry¶
primitives->cylinderEnter
30for the cylinder resolution
Select the larger radius cylinder (named
cylinder)While holding the
ctrlkey, select the smaller radius cylinder (namedcylinder1)Press the
(difference) button
Slice the tube in half:
Add a box:
primitives->box
Y Lengthto1.2m
Select the tube (named
difference)While holding the
ctrlkey, select the box (namedbox)Press the
Rotate the chute:
Select the chute (named
difference1)Add a filter:
transformEnter a value of
0.8m in theTranslate Yfield.Enter a value of
70in theRotation Zfield.
transform)Enter a value of
120in theRotation Zfield
transform1)Enter a value of
Press the
3.20.4. Enter the mesh¶
On the Mesh pane:
Backgroundsub-pane
20for the x cell valueEnter
20for the y cell valueEnter
10for the z cell value
3.20.5. Create regions for initial and boundary condition specification¶
Select the Regions pane.
(all) button to create a new region
Namefield (“walls”)Change the color by pressing the
ColorbuttonCheck the
Select facets (STL)checkbox
(top) button to create a new region
Namefield (“inlet”)Enter a value of
-0.4m in theFrom XfieldEnter a value of
-0.2m in theTo Xfield
3.20.6. Create a solid¶
On the Solids pane:
button to create a new solid
On the DEM sub pane:
check the
3.20.7. Create Initial Conditions¶
3.20.8. Create Boundary Conditions¶
OKOn the
Select regiondialog, select “No Slip Wall” from theBoundary typecombo-boxSelect the “walls” region and click
3.20.9. Select output options¶
Particle Datain theOutput typecombo box.Select the “Background IC” region from the list to save all the cell data
3.20.10. Run the project¶
Save project by clicking
3.20.11. View results¶
