Two-dimensional fluidized bed, Two Fluid Model (TFM) —–====——————————————-
This tutorial shows how to create a two dimensional fluidized bed simulation using the two fluid model. The model setup is:
Geometry |
10 cm x 30 cm |
Mesh |
20 x 60 |
Solid diameter |
Solid density |
Gas velocity |
0.25 m/s |
Temperature |
Pressure |
3.2. Create a new project¶
On the main menu select
3.3. Select model parameters¶
On the Model pane:
Solverdrop-down menu.
3.4. Enter the geometry¶
2 DimensionalcheckboxEnter
3.5. Enter the mesh¶
20for the x cell valueEnter
60for the y cell value
3.6. Create regions for initial and boundary condition specification¶
visualize the results.
ColorbuttonEnter
xmaxormaxin theTo XfieldEnter
zmaxormaxin theTo Zfield
FromandTofields already filled out for a region at the bottom of the domain, to be used by the gas inlet boundary condition.From YandTo Yshould equalymin, defining an XZ-plane.Enter a name for the region in the
Namefield (“inlet”)
FromandTofields already filled out for a region at the top of the domain, to be used by the pressure outlet boundary condition.From YandTo Yshould equalymax, defining an XZ-plane.Enter a name for the region in the
Namefield (“outlet”)
3.7. Create a solid¶
On the Solids pane:
button to create a new solid
3.8. Create Initial Conditions¶
OKbutton.
3.9. Create Boundary Conditions¶
3.10. Change numeric parameters¶
3.11. Select output options¶
OKto create the output
Volume fraction,Pressure, andVelocity vectorcheckboxes on theFluidsub-sub-pane
3.12. Change run parameters¶
3.13. Run the project¶
Save project by clicking the
3.14. View results¶
Change frames with the
, and
buttons
section on the sidebar.
3.15. Increase grid resolution¶
Meshpane, change theX Cellsto 80 and theY Cellsto 180On the
Outputpane,VTKsub-pane, change the write interval to0.01Save and run the project.
