3.22. DEM initial conditions¶
3.22.1. Open the 3d hopper tutorial¶
New projectDouble click on the “3D DEM granular flow hopper” tutorial and specify the project location.
3.22.2. Change the initial condition configuration¶
Initial conditionspane, select the “Initial solids” region.Change the Solid 1 volume fraction to 0.4. Note that we are using an hexagonal lattice.
Runpane, changeStop timeto 0.001. We are only interested to look at the initial conditions.Run the simulation. Visualize the particles and take a look at the output in the console and verify that seeding was successful:
| IC Region: 2 |
Phase 1: Successful seeding
Initial conditionspane, select the “Initial solids” region.Change the lattice configuration to “Cubic”.
| IC Region: 2 |
Phase 1: Unsuccessful seeding
Initial conditionspane, select the “Initial solids” region.In the drop down menu, select “Inventory” and enter
100.0.Run the simulation and verify seeding was successful.
Initial conditionspane, select the “Initial solids” region.In the drop down menu, select “Particle count” and enter
10000.Run the simulation and verify seeding was successful.
0.1.Change the spacing to
0.5, run the simulation and observe how particles are more spaced out.Change the random factor to
1.0, run the simulation and observe how particles have randomly shifted from their lattice positions.
3.22.3. Particle size distribution¶
Initial conditionspane, select the “Initial solids” region.Make sure the Solid 1 volume fraction is
0.1, and the lattice isHexa.Change the spacing back to
0.05, and the random factor back to1.0.In the Solids>DEM pane, Click the
Fig. 3.1 PSD table.¶
Define a Normal psd:
Name:
Normal (mean = 0.01 m)(use a descriptive name).Distribution type:
NormalMean:
0.01Standard deviation:
0.001Minimum:
0.005Maximum:
0.015Plot from 0 to
0.020
Fig. 3.2 Normal PSD definition.¶
Plot the psd by clicking on
Plot distribution. Verify the plot corresponds to the parameters.
Fig. 3.3 Normal PSD plot.¶
OK.
Go to the
Initial conditionpane, go to the drop down menu under ‘Particle size distribution’ and select the psd we just defined,Normal (mean = 0.01 m).Run the simulation and visualize the particles.
Fig. 3.4 Example of a Custom file used to define a Particle Size Distribution.¶
Name:
Bimodal psd(use a descriptive name).Distribution type:
CustomSelect file: Choose
bimodal_psd.txtin the project directory.Click
Plot distribution.
Fig. 3.5 Custom PSD.¶
0.02, run the simulation and verify that we get a volume fraction of 0.1 (or near 0.1).While the simulation is running, we can visualize a histogram showing the particle size distribution. Open a new visualization viewport by clicking on the
Fig. 3.6 Opening a histogram view.¶
Fig. 3.7 Visualizing particle diameter histogram.¶
3.22.4. Reading initial particle data from a text file¶
not part of the data itself):
Lines 32-34: Data header
1 Version 2.0
3 Instructions:
19 Dimension: 3
20 Particles: 35361
25 Phase_ID: F 1
26 Diameter: T
27 Density: F 2500.0
28 Velocity: F 0.0 0.0 0.0
Enable automatic particle generation, and enter a data file particle count of35361. An entry is required to maintain compatibility with the old format, but the value on line 20 of the version 2.0 file will actually be used.In the
Initial conditionpane, delete theInitial solidsinitial condition.In the
Runpane, setStop timeto 1.0 seconds.Run the simulation. You should see the initial configuration shown below:
Fig. 3.8 Example of a DEM initial condition using particle_input.dat version 2.0.¶
