3.3. Two-dimensional fluidized bed, Discrete Element Model (DEM)¶
15 cm x 90 cm x 0.4 cm |
15 x 45 x 1 |
4000 microns ( |
2700 kg/m2 |
42.0 m/s |
3.3.1. Create a new project¶
Model
drop-down menu.
3.3.3. Enter the geometry¶
0.15
0.90
meters for the maximum y valueEnter
0.004
3.3.4. Enter the mesh¶
pane, Background
15
45
for the y cell valueEnter
for the z cell value
On the Regions
field (“bed”)Change the
To Y
field to be “ymax/2”Click the
field (“inlet”)Enter
0.07
in theFrom X
field and0.08
in theTo X
field.Click the
field (“outlet”)
3.3.6. Create a solid¶
pane, Materials
field (“solids”)Enter the particle diameter of
0.004
2700
kg/m2 in theDensity
Solids
pane,DEM
sub-paneCheck the
checkbox, so that the bed Initial Condition, defined later, will be filled with solids
101325
Pa in thePressure (optional)
button.
0.4
in theVolume Fraction
field. This will fill the bottom half of the domain with solids.Note the estimated number of particles and inventory (around 3,200 particles or 0.3 kg). When running DEM simulations on a single core machine, it is recommended to stay below 100,000 particles to get reasonable run times.
Select region
Y-axial velocity
field of “42” m/s
Select region
3.3.9. Select output options¶
checkbox
sub-paneSelect “Particle Data” from the ‘Output type’ drop-down menu.
to create the output
*.vtu
files in theFilename base
field (“particles”)Change the
to0.01
secondsSelect the
Diameter
andTranslational Velocity
checkboxes
Change
Stop time
to1.0
secondsChange
to1e-2
secondsChange
to1e-2
seconds
3.3.11. Run the project¶
3.3.12. View results¶
3D view
